Old 01-13-2013, 08:49 PM   #76
roushinator
roushinator's Avatar
Re: Roushinator's 72 C10 Stepside Restore/Build
Ordered Front calipers today. Did a little test fitting as well....
Ran into a small issue. The holes on the new POL trans mount dont line up with existing holes.
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 01-13-2013, 10:17 PM   #77
Xeen
Xeen's Avatar
That transmission crossmember will stretch out enough for you to put the bolts in you will just have to lean on it a little bit, dont drill its not necessary.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 01-13-2013, 10:18 PM   #78
Zoomin
Man of Mini-Talents
Zoomin's Avatar
There was so much variation on frames between years and plants, it would have been a miracle if they did line up. I'd drill a couple new holes in the frame and mount and call it good.
Or do what Xeen said.
Zoomin is offline   Reply With Quote
Old 01-24-2013, 10:50 AM   #79
roushinator
Brakes came in....
Rear Calipers Top.... Front Calipers Bottom.
Rear Rotors..
Going to order the front rotors sometime this week. Frame is going to paint tomorrow.
Ryan...
Old 01-30-2013, 03:54 PM   #80
roushinator
Frame is painted....
Ryan...
Old 01-31-2013, 11:43 AM   #81
67cheby
67cheby
67cheby's Avatar
nice clean work ! looking good !
67cheby is offline   Reply With Quote
Old 01-31-2013, 05:32 PM   #82
gdavis
gdavis's Avatar
Nice. I enjoy seeing a build thatis so clean. Mine is outside under a canopy. It gets dusty a lot. I tink I will give it a wash as soon as we get over this cold snap. 65 here today. Happy building my friend.
gdavis is offline   Reply With Quote
Old 02-01-2013, 03:36 PM   #83
roushinator
Front rotors came in...
Ryan...
Old 02-01-2013, 04:27 PM   #84
Low Elco
Maaan, this all looks good! One thing, If I may- If you go way down on these trucks, those LT headers are about the closest thing to the road. Lower than the crossmember, in some cases. If you haven't installed them, you may wanna consider shorties, or mid-length. Just my .02... Cool Project!
Low Elco is offline   Reply With Quote
Old 02-09-2013, 09:15 PM   #85
roushinator
So got some work done today..... Left off the rear calipers. The rims i have now wont clear them so will leave them off until i get new rims.
Ryan...
Old 02-10-2013, 02:10 PM   #86
roushinator
Installed my ECE Super Trac bar Kit.
It looks nice but i think i will have some clearance issues with the diff cover. Will sell my ECE Kit and buy this one.
Ryan...
Old 02-12-2013, 01:36 PM   #87
Bomp
Bomp's Avatar
Read and now hooked
Subscribed
Bomp is offline   Reply With Quote
Old 02-12-2013, 01:40 PM   #88
67cheby
67cheby
67cheby's Avatar
looks good !
Old 03-02-2013, 10:22 PM   #89
roushinator
Take two.... Apparently i did not realize that when the instructions say right side and left side they are referring to as if you were sitting in the truck. So i had to break it down again and swap the disc brake brackets.
All Done...
So i had a problem with my ECE trac bar and the diff cover clearance. So i ordered the CPP Bent Trac Bar kit. Took it all apart and found out that the CPP brackets wont work with the ECE trailing arms. So what did i do? I used the brackets from the ECE kit and the bar from the CPP kit. Should have plenty of clearance now..
Old..
New..
And here are my New rear Disc brakes...
Old and nasty...
New....
Ryan...
Old 03-03-2013, 08:04 AM   #90
Xeen
Xeen's Avatar
Lookin really good man, how did that transmission crossmember fit, did you have to drill it to get it to work?
Old 03-03-2013, 03:03 PM   #91
Low Elco
That oughta boogie down now!
Old 04-23-2013, 03:07 PM   #92
roushinator
Not a whole lot going on but....
I purchased some tubular engine mounts and a tubular transmission mount...
Oh yeah a friend had these Boyd's in his attic sitting around for a few years. I need to polish them up. Brand new Nitto tires on them. 18's up front and 20's in rear.
Ryan...
Old 04-23-2013, 03:10 PM   #93
67cheby
67cheby
67cheby's Avatar
Sweet, nice score on the wheels !
Old 04-25-2013, 12:40 PM   #94
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Sweet!! The frames looking good and I love the wheels
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 05-24-2013, 11:41 AM   #95
roushinator
An opportunity came up to get a clean (originally from AZ) cab that requires very minimal work to get ready for paint. Will save me weeks of work plus i can sell mine to offset the price. Got it today....
Ryan...
Old 05-24-2013, 12:02 PM   #96
VA72C10
VA72C10
VA72C10's Avatar
Nice score on the cab! That's the way to do it. Frame looks excellent also!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-25-2013, 02:05 PM   #97
chopnchaneled
chopnchaneled's Avatar
Just found this thread, I'm in for the rest of the journey.
Nice score on the cab.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 05-25-2013, 11:38 PM   #98
hatred
hatred's Avatar
Nice to see a sweet local build!!!
05 QSM GTO - M6, Corsa, King Springs
70 SWB CST - 350/Auto, Foose 18/17
I upset whiners too....
hatred is offline   Reply With Quote
Old 06-21-2013, 03:53 PM   #99
roushinator
Not much progress lately but this came in the mail....
The old and busted carb set up.
Shiney new Holley Stealth Ram Jet (fuel injection)
Ryan...
Old 06-21-2013, 08:52 PM   #100
Xeen
Xeen's Avatar
Holy Smokes that Holley Stealth Ram Jet system by itself costs nearly as much as my entire Vortec swap.
I'm guessing you are going with a Vortec Head, so this is the 550-827 model?
