Old 04-16-2015, 04:46 PM   #76
murd969
Re: 1956 Chevy 3100 Corvette Suspension
Thanks Kim.
1956 Chevy 3100 C4 Suspension Build
Instagram: murd969
murd969 is offline   Reply With Quote
Old 04-16-2015, 11:07 PM   #77
oldman3
oldman3's Avatar
Christmas in April, ah the joys of truck building...Jim
oldman3 is offline   Reply With Quote
Old 04-17-2015, 08:53 AM   #78
samples45
samples45's Avatar
Sweet build I'm doin the same thing.. What's your steering look like from the rack to the firewall? Trying to make mine clear
Cameron
samples45 is offline   Reply With Quote
Old 04-20-2015, 08:06 PM   #79
murd969
I got the rest of the parts in. Now I just need to get it all installed.
Instagram: murd969
Old 04-20-2015, 08:20 PM   #80
murd969
samples45
The steering is going to be tight. I had to run a couple of DD joints to get the steering to clear my headers and mounts. I will try and get some close up pics for you.
Instagram: murd969
Old 04-21-2015, 09:35 PM   #81
samples45
samples45's Avatar
Originally Posted by murd969 View Post
samples45
Okay thanks buddy!
Old 04-22-2015, 01:32 AM   #82
hp1957
hp1957's Avatar
Murd969, looking forward to seeing your 56 Chevy layed out !
Harvey
1957 Chevy Stepside
1958 GMC Fleetside C4 build thread: http://67-72chevytrucks.com/vboard/s...=535686&page=6
hp1957 is offline   Reply With Quote
Old 04-30-2015, 09:05 AM   #83
murd969
After what seems like an eternity I finally got my fedex tracking number for my wheels. Looks like it will be Christmas in May as well.
Instagram: murd969
Old 05-04-2015, 08:15 PM   #84
murd969
Finally I have wheels and a steering wheel. The steering wheel is the half wrap so I can add the leather to it once I get my interior done. 20 x 8.5 and 20 x 10 Raceline Burst 5 with matching steering wheel.
Instagram: murd969
Old 05-05-2015, 08:27 AM   #85
Kim57
Kim57's Avatar
Real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-05-2015, 10:04 AM   #86
oldman3
oldman3's Avatar
New wheels always look great....Jim
Old 05-08-2015, 01:08 AM   #87
murd969
I got the tires mounted on today. I was also able to test fit them and they look pretty good. The rear will need some modifications. Either widening the fenders (which I don't really want to do) or narrow he rear end. Either way I think once everything is setup correctly it will look awesome on the air bags.
Instagram: murd969
Old 05-08-2015, 01:11 AM   #88
murd969
I couldn't set the truck on the ground because it was sitting on jack stands and the coil overs were taken off. Also the rear tire is hitting the fender so some modifications will be needed. Seems like there's always something else that comes up that requires more time.
Instagram: murd969
Old 05-08-2015, 01:13 AM   #89
murd969
Here's a pic showing how close the tire is to the fender. Not too happy about it but also not much that I can do.
Instagram: murd969
Old 05-08-2015, 08:24 AM   #90
Kim57
Kim57's Avatar
Wheels look nice.
That rear tire is a bit close.
Kim
My build thread
Old 05-08-2015, 08:35 AM   #91
murd969
Kim57
The rear tire took up more room than I anticipated. I knew I was going to have to make some modifications but I wasn't expecting it to be like that. I have to widen the fender or narrow the rear end. Not sure either option is ideal. Widening the fender is the easiest but then you mess with the body line of the truck. Not sure what to do.
Instagram: murd969
Old 05-08-2015, 07:04 PM   #92
Kim57
Kim57's Avatar
I have no idea what it would take to narrow a vette rear.
Can you exchange the wheels for ones with a different offset?
Kim
My build thread
Old 05-08-2015, 07:13 PM   #93
murd969
Can't exchange the wheels. They are custom ordered. I'm not too concerned. Worse case I widen the fenders. I found some info today about how to narrow the rear end so I might try that.
Instagram: murd969
Old 05-09-2015, 02:05 AM   #94
Nut Case
Nut Case's Avatar
Great build, I'll be headed down a very similar path, except I'll be doing 57 GMC. How did you establish ride height, front & rear? What is the set back on those shinny new rims?
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 05-09-2015, 04:05 AM   #95
Daze57
Daze57's Avatar
Murd969
something you might want to think about - for your back fenders being too close to your tires .take the 2 or 3 fender braces off and add a inch to the brace in the middle -cut it -add it - weld it bk up- fit it .
i think its the 2 top braces only - it'll push the fender out just a tad - possibly giving you the lil extra room for your tire - just a thought
lemmee know what ya think
v v nice wheels sir .
Daze57 is offline   Reply With Quote
Old 05-10-2015, 02:58 PM   #96
murd969
Nut Case
When we set up the ride height we knew someone using the flat out engineering bracket kit so we modeled ours from that but made our own brackets. Definitely a lot cheaper way to go and you can design it however you like.
Daze57
Thanks for the idea. I will look into it and see what happens.
Instagram: murd969
Old 05-27-2015, 09:40 PM   #97
murd969
We started work on the step notch. We're making a little bit of progress. Hope to have it done this week.
Instagram: murd969
Old 05-28-2015, 08:23 AM   #98
Kim57
Kim57's Avatar
Nice progress.
Kim
My build thread
Old 05-28-2015, 10:15 PM   #99
murd969
More progress on the rear of the frame.
Instagram: murd969
Old 05-28-2015, 10:16 PM   #100
murd969
A couple more.
Instagram: murd969
