#76 | |
Re: Build thread, 70 c10 my first ride
I know some people use spacers under one spring to level out the truck. If it bothers you too much.....that is probably the answer.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#77 |
yeah but then I will end up with having different gaps in my wheel well.. lol i will be addressing it some more this weekend... I will post what I decide to do with it.. on a side note I just did my taxes and my return will be coming in soon and then I will have the money to buy the majority of the parts I need
70 C10 working on a LSx swap ![]() 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
#78 | |
![]() I haven't measured at the wheel wells.....I just checked frame to floor. With my old droopy springs the lean was about an inch, now its less than 1/4".
#79 |
sounds good shawn, i dont expect it to be perfect... but I dont want it to look thrown together
#80 |
well I suppose I forgot to update.. I bought my trailing arm and panhard bar bushing also energy suspension poly urethane..
#81 |
well didnt get a whole lot accomplished this weekend..... dad finally got the hitch off. it was welded to the frame.... and imagine that.. the frame is now within 1/4" from side to side.. then we started to remove the tow furthest back frame braces to fit the new tank in/notch the frame, then we will put the one brace back... also got the gas tank out of the cab. other then that I had my body guy come out and check the truck out and tell me what all I needed to replace... I bought a MS3 cam and some 32# injectors this weekend for the 4.8l getting pretty excited bout that!
#82 |
sorry no pics... will take some today or tomorrow
#83 |
well my goal is:
have the engine/ trans/ wiring harness in pcm tuned cab floor door skins rocker panels cab corners bumpers on re-assembled entirely then paint all the patch sections with some sort of green just for the rest of the year.. I want to be done with that stuff by September 15th so I can have a couple of days driving it around then to take it to the Indianapolis Good Guys car show!!! she wont be done by then but it will be a whole truck again ![]() ![]() guna take some serious knuckling down to make that goal but i think it might be doable! then next year I will completely repaint it back to the original green
#84 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I wonder how they welded that hitch and loaded the frame. Maybe it wasn't on level ground or something.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#85 |
my dad is guessing that they had it on stands and on was up higher then the other? or the steering wheel was turned all the way to one side, anyways its fixed im super stocked!
#86 |
well progress seems to be slow even though i spent all day yesterday working on stuff.. got the tank mounted where we want it still going to have to take it back down to make some top straps and add some camper weather strip as a bumper to keep the straps from cutting the tank, once that is done my hands are tied on the fuel system til my filter/reg comes in (hopefully tomorrow). also we started to remove the pass side trailing arm with intentions of welding the seem together, painting, then polyurethane bushings, but we couldn't get the u bolts to let the arm drop even though I had the nuts off ant the shock mount off... also cleaned up/painted the steering column bracket, panhard bar, and the little brackets that hold the hood bump stops. tried to install poly bushings in the panhard and damaged one side so now i have to get new ones... on a side not my girlfriend is awesome (she called one of my buddies, he got me really into the ls swap idea... she asked him what i need for my swap...) she ordered me a early anniversary gift (April 17 will be 3 years) new pacesetter ls1 headers
#87 |
Any progress is progress. But you're going to really have to keep on it to make your goal. Not that it isn't possible, but when the weather warms up, you're going to need to stay focused and not get sidetracked by all the other things there are to do. (That means partying
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#88 |
i know its a high expectation! lol but me and dad make a kick butt team, and you dont have to worry bout the partying.. im not really that kinda guy I have a handful of friends that Ashley (my gf) and I hang with every weekend and go cruising etc in the summer... anyways yes Ashley is a keeper! I will say I wish I was farther along then I am... but the warmer it gets the more that will get done
#89 |
got my filter/regulator in last night, so we will be working on the fuel system and the trailing arms tonight, having a hard time getting them to separate from the u-bolt..
#90 |
not doing AC this year but just guna use my thread to save some ideas i have gotten off the site
http://www.nostalgicairparts.com/air...ht-out-333.php http://www.oldairproducts.com/catalo...ng-p-3865.html http://67-72chevytrucks.com/vboard/s...d.php?t=555465
#91 |
Those 4th gen F-body tanks already have a regulator built in to the tank, you dont need to corvette filter. If you use the vette filter you have to take out the in-tank one
#92 |
i was not aware of the in tank regulator... not trying to question your knowledge.... but i didnt see anything that looked like a regulator, can you show me where its located or refer me to a web page? so i know for sure.. because this sending unit has 3 connections on top one i assume is pressure, one is return, and one is for evap?
#93 |
well over the weekend I finally got my control arms off... they were a real pain to remove without cutting the ubolts... anyways they had SERIOUS rust issues... some holes were 1x2 or even 1.5x3 holes in the side of the arms... so i carefully seperated them and cut the bad sections out and added some 10 gauge in place... took forever... and i only got one side done in about 5 hours worth of work... and i still need to replace the bushings and weld the two sides together... anyways.. i have a bunch of pics of the carnage
#94 |
Looking good, but looks like a pain, lots of work ahead keep it up
#95 |
more carnage
#96 |
Ashley (my gf) did me a favor and painted the needles for my gauge cluster
#97 |
thanks dale, how do ya think i did? i think it looks good for the first time i have ever done any rust repair..
#98 |
well sorry I haven't been posting.. havent gotten much accomplished... haven't been given much time to work on the truck... although I did get the driver side trailing arm ready to be cleaned welded then painted.. pass side I am still working on im bout half way done with it, and all week I have spent about an hour a night working on the wiring harness I'm close to having all the extras removed.. then I will have to change the wiring harness layout... I don't like how it looks...
#99 |
Well on monday I ordered my carpet, gauge bezel and lens, and last night i finally pulled the trigger on most of the parts I needed... So I have something to do now... LOL like I needed more stuff to do lol... well coming up pretty soon here I will be doing the full floor board replacement, and many other things...
#100 | |
