Old 09-30-2013, 08:40 PM   #76
_Ogre
_Ogre's Avatar
Re: 59 Panelmania
Originally Posted by arturo7 View Post
mounted the body on a rotisserie
that has to be one huge rotisserie
shop air compressor timer
Old 09-30-2013, 09:36 PM   #77
buggy5872
buggy5872's Avatar
Re: 59 Panelmania
progress looks great. I'm with _Ogre on the rotisserie has to be huge.....we need to see a pic of that.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
Old 10-01-2013, 12:21 AM   #78
arturo7
arturo7's Avatar
Re: 59 Panelmania
Pics are all cued up waiting for the mods to get off their arses and fix the gallery.
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 10-04-2013, 12:02 PM   #79
arturo7
arturo7's Avatar
Re: 59 Panelmania
Not quite sure how to handle the floor removal and replacement. Can't post any pics here without the gallery, so I started a thread over on the HAMB. Any input is appreciated.
http://www.jalopyjournal.com/forum/s...d.php?t=836687
ever forward
Old 10-06-2013, 08:33 PM   #80
arturo7
arturo7's Avatar
Re: 59 Panelmania
Perused the assembly manual again and figured out the problem. The pieces on the front and back of the bed are not C-channels. (guess I should wear the readers more often) The bottom rail is an extension of the floor and the top is a retaining strip. Since only the rear top strip needs replacement, it doesn't make much sense to hack up the supports. Instead I hacked up the plywood floor. Problem solved.
Guess the door is wide open on how to replace it now.
ever forward
Old 10-07-2013, 12:16 PM   #81
_Ogre
_Ogre's Avatar
Re: 59 Panelmania
use photobucket like most of us do. one upload for many forums.
if you right click on most photos and open in new window, you will see most of us use photobucket.
Old 10-07-2013, 01:14 PM   #82
arturo7
arturo7's Avatar
Re: 59 Panelmania
Photobucket is evil. The security monitor on my browser lights up like the Vegas Strip whenever I visit that site. Plus, I'm not a fan of anything cloud.
ever forward
Old 10-07-2013, 02:00 PM   #83
ghettoluxury
ghettoluxury's Avatar
Re: 59 Panelmania
Here is how to upload pictures now.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 10-07-2013, 02:30 PM   #84
Ferrofil
Ferrofil's Avatar
Re: 59 Panelmania
What Arturo said!
Totally agree...and think he's funny as f*** too! :-D
Ferrofil is offline   Reply With Quote
Old 10-08-2013, 03:28 PM   #85
_Ogre
_Ogre's Avatar
Re: 59 Panelmania
yeah, i don't run any security or antivirus on my pc
never had a problem since the kids moved out
Old 11-19-2013, 10:57 PM   #86
arturo7
arturo7's Avatar
Re: 59 Panelmania
The gallery is back, yay!
Here is the body dolly, made with .081 tubing, weld nuts and Harbor Freight casters. It worked just fine, although the HF wheels are a bit weak. This was my first MIG project. The welds ain't pretty, but they didn't fail.
ever forward
Old 11-20-2013, 01:58 AM   #87
arturo7
arturo7's Avatar
Re: 59 Panelmania
Here's a pic of the electrolysis tank.
More here http://67-72chevytrucks.com/vboard/s...d.php?t=605050
ever forward
Old 11-20-2013, 11:19 AM   #88
_Ogre
_Ogre's Avatar
Re: 59 Panelmania
what part of the floor are you replacing?
if your plywood floor is decent, don't remove it.
you can't buy plywood that wide to fix it in one piece and a seam will delaminate.
if your tubbing, c-notching the frame and raising the floor over the axle, i'd still only cut out what you need to.
if it's the metal floor up front, everything is the same as the truck
Old 11-20-2013, 11:38 AM   #89
Kim57
Kim57's Avatar
Re: 59 Panelmania
Nice cab dolly.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 11-20-2013, 12:25 PM   #90
arturo7
arturo7's Avatar
Re: 59 Panelmania
The plywood had holes in it. No choice but to replace it. Unfortunately, the plywood does not come out easily, it is welded in place. Because of this it needs to be cut up for removal and the new floor must be installed in segments. I'll post some pics of the removal later today.
ever forward
Old 12-03-2013, 07:34 PM   #91
arturo7
arturo7's Avatar
Re: 59 Panelmania
Here are the rotisserie pics.
ever forward
Old 12-03-2013, 07:44 PM   #92
Kim57
Kim57's Avatar
Re: 59 Panelmania
That is slick.
Kim
My build thread
Old 03-05-2014, 03:56 PM   #93
miltonseven
Re: 59 Panelmania
Updates?
miltonseven is offline   Reply With Quote
Old 08-16-2014, 04:31 PM   #94
arturo7
arturo7's Avatar
Re: 59 Panelmania
After giving it a try, I realized bodywork is not something I'm good at. This significantly raised the cost of the project. Couple this with the fact that I quit my job earlier in the year to start a business, the project is on hold for a while. On the bright side, I'm getting some projects done around the house that were back burnered. You know, those minor jobs that pile up while you're obsessing on your truck; house painting, landscaping, firepit...
ever forward
Old 07-25-2019, 09:38 PM   #95
arturo7
arturo7's Avatar
Re: 59 Panelmania
Greetings all. Long time no see.
I've decided to move on from this project. Another vehicle came my way that I couldn't pass up. It's not a cool old Chevy truck, but it's not a project either.
The search begins to find someone who might be interested in finishing the build. A lot of the heavy lifting on the chassis has been done. But there is still quite a bit more work to do.
I'm not sure how to value the vehicle in it's present condition. I've got about $10k into it, but I doubt if it's worth that in it's present condition. I post it in the classifieds once I figure out a reasonable asking price.
ever forward
