Old 03-22-2013, 06:40 PM   #76
85burb
85burb's Avatar
Re: 85 lwb turbo 5.3 build
Not really. I did get a harness and ECM that has been reworked for a ls1 type intake. TRYING to save up for the cast turbo manifold I want. That is all.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-27-2013, 12:11 PM   #77
85burb
85burb's Avatar
Well kinda a progress update. Sold the turbo. Work is slow right now. Almost had the money for the turbo manifold and had to spend money on a unexpected large bill. So we are going to get the truck running and driving and then deside if we still want the turbo or not. So the truck should be on the road faster. Need intake and fuel system. What are people using for headers now?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-27-2013, 01:54 PM   #78
79shortbed
79shortbed's Avatar
Schoenfeld headers for LS1 swap for 89-98 trucks. Lots of people say they fit just right.
1979 Custom Deluxe C10 SWB Fleetside
Help encourage me in my build.
LS 5.3 swap in progress!
79shortbed is offline   Reply With Quote
Old 03-28-2013, 11:06 PM   #79
85burb
85burb's Avatar
Ordered a ls1 intake and throttle body and maf sensor. Need to find some stock ls1 type injectors cheap.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-29-2013, 12:31 AM   #80
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
IIRC the cars used the EV6 plugs, tall narrow injectors. You can use the Blue F*rd SVO injectors. They run about 39-42lb/hr at our rail pressures. I'm running a set on my lq4 right now (trucks came with a MultecII clip instead)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-30-2013, 11:31 AM   #81
85burb
85burb's Avatar
I found injectors tps iac and pulley relocation kit to put car in take on a truck motor. And a maf. Looks like all I need is air filter and pipes. And fuel and exhaust. I have 5 different boxes coming to me. I should lay off the ordering stuff for a while.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-30-2013, 04:20 PM   #82
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Did you buy the injector clips as well?
Old 03-31-2013, 04:08 PM   #83
85burb
85burb's Avatar
No. If you are talking about the clips that hold the injector to the rail. The intake is coming with billet fuel rails. I am pretty sure i dont need them. I do infact need the clips that hold the injector electical connector on to the injector. 4 of mine are missing.
I found these on line. Does any one have any idea if they will work?
http://www.ebay.com/itm/1967-81-Cama...item1e78190483
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-02-2013, 10:18 PM   #84
85burb
85burb's Avatar
Got intake and fuel rails today. Looks really clean. I also love the color on the fuel rails. It is like a gun metal color.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-03-2013, 12:07 AM   #85
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I meant the EV6 electrical connectors, since the old truck setup would have used the MultecII clips (unless you had the harness setup for car/ev6 injectors in the first place.
Old 04-03-2013, 12:12 AM   #86
85burb
85burb's Avatar
The harness I am using i was told is made to work with ls1 intake. When he told me that I figured that ment they kept the truck injector plugs. Boy was I wronge. It has ev1 injector connectors with the fancy metal wire retainers that 4 are missing and I can't find anyware.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-03-2013, 10:26 AM   #87
aggie91
I'm just glad to be here!
aggie91's Avatar
Is this the connector you are looking for:
http://www.eficonnection.com/eficonn...spx?ItemId=539
Here might be another source:
http://currentperformance.com/Connec...rtec4_5_6.html
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-03-2013, 10:49 AM   #88
Wasted Income
Boosted Member
Wasted Income's Avatar
I get injector connectors at the local boneyard. Pretty much any GM EFI car from the 90s/2000s have them.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-03-2013, 02:53 PM   #89
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
like he said the late 90's early 2000's stuff should have it, and you can check the F*rds there as well; the connector is not proprietary to the brand.
Old 04-03-2013, 06:07 PM   #90
85burb
85burb's Avatar
They are like the ones in the top link but i really dont want to pay that much to just take the metal spring clip thing out.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-03-2013, 06:14 PM   #91
85burb
85burb's Avatar
I got my dirtydingo idler relocation kit today. I trimmed the bracket way down and bolted it on. Works prety nice. But my throttle body still hits the water pump hose connection. I have heard new truck water pumps will work with ls1 intake. I looked at wifes water pump on her 08 and it LOOKS like it will work. My suburban needs a water pump anyways so I am gonna get one for hers and put the old style on my burb and the new one on this truck. I would not want to do the grinding i did with out air tools. It took a while with them could not imagine doing it without them.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-03-2013, 09:48 PM   #92
85burb
85burb's Avatar
Got my fuel injectors!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-04-2013, 11:18 AM   #93
85burb
85burb's Avatar
Slow day at work today so i stayed home. Busted out the wire wheel and went to town. The motor looks 100% better. Now the ls1 intake will actually look good on it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-04-2013, 01:45 PM   #94
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
well then........you ought to clean up and paint that firewall and power booster while you're at it!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-04-2013, 01:47 PM   #95
85burb
85burb's Avatar
I will when i pull the motor to paint it. This swap will be much cleaner then my suburbans swap. I hope it runs better too. I should have all the vss crap worked out by then.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-04-2013, 02:13 PM   #96
68GMCCustom
oh ...your just mocking things up right now?
Kurt -
Old 04-04-2013, 02:18 PM   #97
85burb
85burb's Avatar
Yes. Cause i was not really sure where to put the turbo stuff. Yall like the crazy scrathes in the fire wall. I bet the chain broke or something when the po put the motor in. Cause the ac box was also crushed in.
The only thing i dont know what to do with is the exhaust. I really dont want to spend 600 bucks on doug thorlys again to put a trubo on it later possibly.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-04-2013, 05:52 PM   #98
79shortbed
79shortbed's Avatar
Schoenfelds? <$300
Old 04-04-2013, 05:54 PM   #99
85burb
85burb's Avatar
Originally Posted by 79shortbed View Post
Schoenfelds? <$300
Plus the coating at 250 or so. I found some shortys for camaros that are 199 and they are stainless I am trying to make up my mind about.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-04-2013, 10:24 PM   #100
79shortbed
79shortbed's Avatar
I wouldn't worry with coating them. But that's just me. Would offer better performance than shorties, too.
