Old 08-27-2014, 12:51 PM   #76
61K10
61K10's Avatar
Re: 4x4 Power Steering
you have to mod yours or have a machine shop make you one. no aftermarket avl.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-27-2014, 01:52 PM   #77
tugster67
tugster67's Avatar
what was wrong with the last one?
tugster67 is offline   Reply With Quote
Old 08-27-2014, 09:18 PM   #78
61K10
61K10's Avatar
don't understand? what last one?
1961 chevy K10
Old 09-05-2014, 11:21 AM   #79
tugster67
tugster67's Avatar
Originally Posted by 61K10 View Post
My steering box and pitman arm are like Ron's pic (88 up with o-ring hoses) which shouldn't make any diff. is the hole in the stock steering arm(on axle) tapered? the info i got was the rod end will fit the hole and it is from a 85 blazer. also their was no mention of shortening the steering arm on axle. haven't pulled my stuff apart yet as i pulled my acl and am gimping around. here are some pics of the new drag link and part #'s. post all your info you find out too. i have captfab's plate and i do have the front eng mount cross-member. hope this helps some.
can you tell me the lenth of your right and left tie rods after its put together with the drag link? I need it to be 12 inches so it will fit from my steering arm to my pitman arm?
Old 09-06-2014, 03:34 PM   #80
61K10
61K10's Avatar
I guess this is what you are asking? you drag is adjustable. you cannot use the org one.
1961 chevy K10
Old 09-06-2014, 06:17 PM   #81
tugster67
tugster67's Avatar
yes that is what i was asking and where did you find a new steering arm, I looked all over and couldnt find anything!!! See My body is a 67 c-10 but my frame is from another year because it has the closed knuckle with the dana rears and I cant tell what year it is but my guess is early 1960's?
Old 09-06-2014, 08:31 PM   #82
padresag
67 had the closed knuckle.
ron
padresag is offline   Reply With Quote
Old 09-07-2014, 01:46 AM   #83
Captainfab
60-66 Nut
The closed knuckle Dana 44 front differential was used thru at least '69.
Old 09-07-2014, 09:45 AM   #84
tugster67
tugster67's Avatar
The new steering arm? Can you tell me where you purchased it?
Old 09-07-2014, 12:58 PM   #85
61K10
61K10's Avatar
my steering arm is the stock one. it has been shortened as been said in this thread.
1961 chevy K10
Old 09-07-2014, 02:18 PM   #86
tugster67
tugster67's Avatar
i know its stock but where can i get one?
Old 11-07-2018, 03:12 AM   #87
James61K10
James61K10's Avatar
my modded steering arm and the piece that got cut out
Adding one more build to the 4x4 channel. I was inspired by the thought of re-machining the steering arm instead of cutting/welding. Ended up looking fairly sensible; I was able to keep the original angle and machine a flat for the nut to clamp against without losing any x-section where the load is applied.
Sorry pics are rotated 90° - Apple “thing.”
James61K10 is offline   Reply With Quote
Old 11-07-2018, 02:50 PM   #88
61K10
61K10's Avatar
I thought about doing something similar to mine also. Thanks for posting.
1961 chevy K10
