Old 06-26-2015, 08:43 AM   #76
bigguy
Re: 86 GMC, Porterbuilt Mild front and rear
bigguy is offline   Reply With Quote
Old 06-26-2015, 08:47 AM   #77
bigguy
Engine bay. Name:  image.jpg
Old 06-26-2015, 01:12 PM   #78
SCOTI
SCOTI's Avatar
Very nice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-28-2015, 07:28 PM   #79
tinydb84
tinydb84's Avatar
Man that is gorgeous!
David
Instagram: myfabguy
Old 06-28-2015, 07:31 PM   #80
mooseknuckles
mooseknuckles's Avatar
looks awesome!
mooseknuckles is offline   Reply With Quote
Old 07-25-2015, 03:13 PM   #81
Hankster
Hankster's Avatar
Originally Posted by bigguy View Post
Oh my! looks good!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 08-12-2015, 05:40 PM   #82
bigguy
Got most of it back together. Just need to finish the interior and fix the exhaust. Name:  image.jpg
Old 08-12-2015, 05:41 PM   #83
bigguy
Quick shot of what the seat looks like. Name:  image.jpg
Old 08-12-2015, 06:20 PM   #84
SCOTI
SCOTI's Avatar
Turning out super clean! Was hoping to see the smaller sport mirrors on this one but it looks great. I like the seat. Black door panels, trim, & dash?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-12-2015, 07:25 PM   #85
bigguy
The mirrors were one of the tougher decisions. The ones I had were in good shape so I just reused them. The interior is all black.
Old 11-16-2015, 08:17 PM   #86
willyp
willyp's Avatar
Great to meet you last weekend. This truck is beautiful in person, super clean and your attention to detail is spot on. Well done brother!
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 11-21-2015, 11:09 AM   #87
bigguy
Thanks Willyp! I had a blast hanging out with you guys. Hopefully we can all get out to a few more soon. BTW your truck looks killer!
Old 01-04-2016, 09:13 PM   #88
Hart_Rod
Hart_Rod's Avatar
Looks great! What did you do with your wheel rear tubz?
Hart_Rod is offline   Reply With Quote
Old 01-04-2016, 09:53 PM   #89
stepside83
stepside83's Avatar
truck looks killer man nice clean build.
stepside83 is offline   Reply With Quote
Old 01-04-2016, 10:32 PM   #90
91short
Yeah Man, you did an awesome job and have a really nice truck! Thank you for your service as well!
91short is offline   Reply With Quote
Old 01-05-2016, 08:53 AM   #91
LT7A
You did a ton of work in a pretty short amount of time and it looks great. I like the combination of stock and custom features. Also, echoing 91short -- thank you for serving. One of my best friends is career Marine Corps. You guys sacrifice a lot.
Old 01-05-2016, 10:54 AM   #92
mooseknuckles
I like the seat...nice work!
Old 01-06-2016, 01:49 PM   #93
bigguy
I appreciate all the kind words. Hart rod I'm not exactly sure what you're asking?
Old 01-06-2016, 01:55 PM   #94
Hart_Rod
Hart_Rod's Avatar
Since you raised your bed floor, the rear wheel tubs will probably need sectioned like ones in these pictures. I am producing them in fiberglass if you need a set. Here's a link to my thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=675754
Old 01-07-2016, 08:39 PM   #95
slotard
Why do you think the extreme drop member would be easier and involve less fab?
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-08-2016, 11:29 AM   #96
bigguy
I just trimmed the inner part of the factory tub and bolted them back in place. plenty of clearance with the amount I raised the bed.
slotard - I went with the Mild version because I was under the assumption that there was no modifications to the cab necessary. With my setup I had to fab a tunnel from front to back for drive shaft clearance. My main issue was the steering linkage. The stock column sticks out fairly far and causes the first joint angle to be a little extreme. Other then that, the install was pretty straight forward. So since I had to do all the modifications anyway, I think the extreme version would have been easier for the simple steering connections and header fitment.
Old 04-12-2020, 01:04 PM   #97
G-NUT
G-NUT's Avatar
Fabbed ECM mount. Headers are Hedman Muscle rod. I had to notch the dropmember to get the correct angles for the steering. The drivers side header has the front tube rerouted to clear the joints.
Attachment 1213729
Attachment 1213730
Attachment 1213731
How did you connect your first u-joint at the steering column? Did you cut a piece of steering shaft stock and mount it in the residing location, and then mount the u-joint to that?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 04-12-2020, 01:36 PM   #98
bigguy
No. The factory column has a DD shaft end already. These columns usually have the DD end or a splined end.
Old 04-12-2020, 01:41 PM   #99
G-NUT
G-NUT's Avatar
Thanks for the response. Mine does hav ethe DD end. When I ordered my PB front kit several years ago I ordered through CPP Classic Performance Parts. They sent me their rack and pinion and steering kit. The kit came with a u-joint that fits the rack. The second u-joint doesn't fit my stock steering DD end. The u-joint has a 3/4 DD on both ends. I just now tried to put it on the stock steering DD end but the u-joint 3/4DD opening wasn't large enough. My stock end is larger.
Did you modify or what u-joint did you use?
Old 04-12-2020, 02:27 PM   #100
bigguy
I believe you need a 1” dd to 3/4” dd u joint. I bought all of my gear through Porterbuilt. I did end up getting some extra u joints because of the geometry of the shafts.
headers, steering
