Old 02-23-2015, 01:24 PM   #76
newstedcomeback
newstedcomeback's Avatar
Re: 1971 C/10 to K/20 Conversion
Call me crazy. But this seems like more than a 4" lift.. Tires are 33's. I'm sure it will settle a little bit. Looks like I am for sure gonna do the 40 gallon suburban swap
1971 Chevy K30 / 454 / TH400 / NP205 / Dana 60/14 bolt FF on BFG Baja 37's - Build Thread : http://67-72chevytrucks.com/vboard/s...d.php?t=647877
2018 Silverado 1500 5.3 LTZ Z71 - daily driver
2019 Tahoe Z71 5.3 - (Wifes daily driver)
newstedcomeback is offline   Reply With Quote
Old 02-23-2015, 01:26 PM   #77
newstedcomeback
Me and my buddy Eston, and my dog the crotch sniffer. She loves Eston. Dirty girl
Old 02-23-2015, 02:14 PM   #78
swamp rat
swamp rat's Avatar
My truck has BDS 4" lidt and 33" tires in 16.5 rims, it measures about 12 1/4" at the front fender well, i didn't measure the rear but its pretty symmetrical front to back.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-23-2015, 07:49 PM   #79
jeffahart
jeffahart's Avatar
Can't tell from your picture but how's it hangin'? Did you move make rear of springs compression hangers from tension. That could account for exta height.
But in the end you might like a couple extra inches.
White K20
jeffahart is offline   Reply With Quote
Old 02-23-2015, 09:20 PM   #80
newstedcomeback
The frame is stock. I bought a 4" lift kit from rough country. Its an all leaf spring lift. no blocks. the frame is a bare roller, so I think it will settle down with some more weight.
Old 02-23-2015, 10:34 PM   #81
Bladeboy1998
Subbed! Love the 1911 man, love my colt
keep up the good work!
Bladeboy1998 is offline   Reply With Quote
Old 03-03-2015, 12:56 AM   #82
newstedcomeback
Here's mine
Old 03-09-2015, 11:57 PM   #83
mattbert56
mattbert56's Avatar
Thumbs up Re: 1971 C/10 to K/20 Conversion
I guess I can join To.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline   Reply With Quote
Old 03-10-2015, 12:34 AM   #84
newstedcomeback
Very nice, Back to the truck stuff. This weekend Jimbo and I went to pick-n-pull and scored a 40 gallon rear mount gas tank with a wonderful 1/8 thick steel protection shield from a suburban. It had EFI so the TBI fuel pump is in the tank. I will just need to run a pressure regulator and it will work for my carb. We also scored the filler neck and even brought the Milwaukee death wheel with us so we could hack the fuel door assembly from the Suburban. Im very excited to pick this one up. I think the weight of all the fuel will help level out the truck and now I feel much better about going on long camping trips with a 383 under the hood. AND!!! the sending unit is the same ohms as my old tank so the gauge works perfect!! : Good Old GM...
There was a NV4500 and a couple 4l80e's at pick n pull, but they were all for 2wd. I am still tempted to pick them up and convert them to 4x4....
Old 03-10-2015, 12:44 AM   #85
mattbert56
mattbert56's Avatar
I say pick them up and convert them if there in good shape. Those are not cheap.
Old 03-12-2015, 03:19 PM   #86
72 Copper C-10
72 Copper C-10's Avatar
Its looking great! its kinda similar to my build. I guess great minds think alike!
To convert an NV4500 to 4 wheel drive you need a 4 wheel drive main shaft.
72 Copper C-10 is offline   Reply With Quote
Old 03-12-2015, 05:16 PM   #87
newstedcomeback
Im gonna keep my current setup for now. when I blow up the 700r4 or the np208 then I will look into upgrading to a 4l80e/np205 setup. I really enjoy the automatic transmission. My truck came with a th350 and I swapped to a Super t-10 4 speed, but it wasnt as awesome as I had hoped, I had to baby the clutch or it would burn out on accident all the time. I would break tires loose when shifting, it was just too fast and not as plesant to drive. not my style anymore. the 700r4 is a wonderful transmission. The next one will be a 4l80E. but ill cross that bridge when I come to it.
Old 03-13-2015, 11:11 AM   #88
72 Copper C-10
I agree with your plan, I think that the 700r4 np208 is a great combination! There are many reasons I'm using a 700r4 and np241 combonation my self
Old 03-17-2015, 12:27 PM   #89
newstedcomeback
Well. when I first got the gas tank from the suburban I figured I could just make my own crossmembers to install it, But the straps were stuck to the old ones, So over the weekend we went back to cut out the front and rear gas tank crossmembers from the suburban. it was no fun. I had to borrow some extra batteries for my grinder. we ended up cutting sections out of the floor so that we could reach the 8 top rivets. but we finally got them. Im happy. now my tank install should be very simple. drill a couple holes. yay!
Old 04-13-2015, 01:40 AM   #90
newstedcomeback
Well. It's been a while. But I have been working on the truck every weekend. I have made serious progress on the wiring, and yesterday I got the cab back on the body. It's pretty exciting to me. Seeing it like this. Really makes me wanna throw it back together and drive it asap! Today I patched the gas tank holes that were stabbed by the wonderful employees at pick n pull, we got the 40 gallon suburban tank ready to go.
Old 04-13-2015, 01:42 AM   #91
newstedcomeback
Wiring
Old 04-13-2015, 11:50 AM   #92
mattbert56
mattbert56's Avatar
Dude! That's looking sick! starting to look like a truck now
Old 04-13-2015, 12:27 PM   #93
americanmusc1e
americanmusc1e's Avatar
I'm liking this build! I have a very similar project. A 70 2wd going to 4x4, except I'm using lighter axles and a sm465 because I've had some bad experiences with the old 700r4
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 04-29-2015, 05:25 PM   #94
newstedcomeback
Well the past few days I have been working on project 40 gallon suburban gas tank... I had to remove the rear crossmember (6 rivets) from my truck, and I also had to remove the rear brake line bracket from the frame (2 rivets). the front crossmember from the suburban is put in the rear of my truck (in order for the fuel filler to be on the drivers side) and it is taller than the old one. so I had to cut relief notches in the suburban crossmember. I finally got it up in place and its going to work out! Yesterday I started running the fuel and brake lines along the frame rail. I will update with more pics later.
Old 05-05-2015, 12:17 PM   #95
newstedcomeback
Engine in, doors back on, Fuel lines and brake lines all done.
Old 05-05-2015, 12:24 PM   #96
mattbert56
mattbert56's Avatar
VERY NICE man. I'll have to swing by one of these days to check it out now that it's not just a frame. Do you know what your going to run for exhaust?
Old 05-05-2015, 12:43 PM   #97
newstedcomeback
Sounds good, I have the old exhaust that I put together about 2 years ago. I just need to chop it up and make a few adjustments.. Its 2 1/2 dual with an H pipe and walker quiet flow SS mufflers. Im gonna run cast iron manifolds from a 70's or 80's truck.
Old 05-05-2015, 12:46 PM   #98
mattbert56
mattbert56's Avatar
That should sounds good. I'm sure regardless of how big a muffler u put on. That 383 will still Rip when it comes alive. How far do you think you have till its on the road again?
Old 05-05-2015, 12:48 PM   #99
newstedcomeback
Not Sure, I moved to the day shift, so now im home by 4:30 every day. its been giving me alot more time to work on it. I think it should take me a few more months
Old 05-05-2015, 12:52 PM   #100
mattbert56
mattbert56's Avatar
Nice. Just in time for Summer. can't wait to see it
14 bolt, 1971 71, 383, 4x4 conversion, 8 lug
