Old 02-02-2015, 10:26 AM   #76
reaper71
reaper71's Avatar
Re: Blake's 67 GMC stepside build
Pic #1. getting the Rot all cutout..
Pic #2. The new metal being welded in place..
Pic #3. the new brace installed..
All the new metal was coated with rust inhibitor and the old metal was all cleaned before coating..
reaper71 is offline   Reply With Quote
Old 02-02-2015, 12:08 PM   #77
RockinKees
RockinKees's Avatar
Looks great Mark!
Nice new metal
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-02-2015, 03:48 PM   #78
Advanced Design
Advanced Design's Avatar
Better and better! Really like new metal.
Advanced Design is offline   Reply With Quote
Old 02-02-2015, 08:37 PM   #79
reaper71
reaper71's Avatar
AAHH!!! makes you fell all warm and fuzzy
Originally Posted by RockinKees View Post
Looks great Mark!
Nice new metal
Old 02-02-2015, 08:37 PM   #80
reaper71
reaper71's Avatar
Yes sir...always a good thing..
Old 02-03-2015, 10:59 AM   #81
reaper71
reaper71's Avatar
Onto the Passenger side..
Pic #1. Removing the old (sorry for bad pic)
Pic #2. The new template..
Pic #3. All welded in..
Pic #4. The new brace welded in and all pretty again...
Old 02-03-2015, 11:10 AM   #82
nuke1
nuke1's Avatar
Nothing better than 4 eyes!! keep up the good work
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-03-2015, 02:03 PM   #83
Advanced Design
Nice piece Mark. Looking forward to more...truck is going to be nice.
Old 02-03-2015, 04:20 PM   #84
yj4000
yj4000's Avatar
Very nice patch work. What gauge metal are you using?
Thanks, Ryan
yj4000 is offline   Reply With Quote
Old 02-04-2015, 10:45 AM   #85
reaper71
reaper71's Avatar
Nuke1 and A.D. Thank's guys..
Old 02-04-2015, 10:46 AM   #86
reaper71
reaper71's Avatar
Ryan....I used 18g for my patch work..
Thanks, Ryan
Old 02-04-2015, 10:58 AM   #87
reaper71
reaper71's Avatar
Next Update...
Pic #1. The new drivers side cab corner...
Pic #2. The old piece marked and cut out...
Pic #3. Welding in.. As you can see I had to do some slicing to relieve some spots for a better fit..
Pic #4. Another view.
Pic #5. All metal finished..
Till next time..
Mark...
Old 02-04-2015, 04:35 PM   #88
JGood
JGood's Avatar
didn't the 67 models also have the small back window? nice work by the way! very tedious with what you do!
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 02-04-2015, 04:36 PM   #89
Advanced Design
Looks good Mark!
Old 02-05-2015, 09:51 PM   #90
reaper71
reaper71's Avatar
not 100% sure on that....as I stated before things are all different. On this thing I'm going by what I see on the numbers on the truck..
Old 02-05-2015, 09:52 PM   #91
reaper71
reaper71's Avatar
Thanks A.D
Old 02-10-2015, 10:01 AM   #92
reaper71
reaper71's Avatar
Updates....
Pic #1. Passenger side corner...
Pic #2. After all the work was done on the corner and cab set in place, so I could check out the door fitment..
Pic #3. If you go way back to the first shots of the truck when it was dropped off the drivers door was caved in pretty good.
They tried to fix the "A" pillar with heat and it was all F'd up so it needed to be replaced..
Pic #4. The old piece cut out and new plate made..
Pic #5. Tacked in place with cage nuts for hinge.. (Bad pics sorry)
Old 02-11-2015, 10:01 AM   #93
reaper71
reaper71's Avatar
Here are some more pics....
Pic #1. The lower section being replaced that was bad..
Pic #2. The upper section was badly crushed and they used a torch to try and fix it at some point. (so it came out as well so the door will close)
Pic #3. The old piece removed and the cage nuts as well..
Pic #4. All fixed..
Next up....Firewall
Mark...
Old 02-11-2015, 12:45 PM   #94
RockinKees
RockinKees's Avatar
Again nice work Mark!
Cheers!! Kees.
Kool Guyz CC
Old 02-11-2015, 03:21 PM   #95
yj4000
yj4000's Avatar
Thanks for showing your progress. I like the way you number the pics with a description than show the pics.
Ryan.
Old 02-11-2015, 07:12 PM   #96
Advanced Design
Nice repair on the pillar Mark!
Old 02-11-2015, 07:46 PM   #97
swamp rat
swamp rat's Avatar
Nice work all around!
EDIT: I think the large window on a 67 was an option, it as placed into law in 68 for safety reasons (visablity)
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-12-2015, 10:11 AM   #98
reaper71
reaper71's Avatar
Kees,Ryan,Doug and swamp rat Thank's guys for the compliments!!!
Old 02-12-2015, 10:12 AM   #99
reaper71
reaper71's Avatar
Did not know that! Thank's for the info..
Mark...
Old 02-12-2015, 10:19 AM   #100
reaper71
reaper71's Avatar
Onto the fun stuff!!
I wanted to smooth out the firewall on this truck and get rid of the UGLY on it!
Pic #1. Stock
Pic #2. Side view of the Massive unit sticking out from firewall (Needs to go!!)
Pic #3. Already looks better!!
Pic #4. paint stripper used to get all the Years of multi colors of paint..
Next up, making filler panels to clean it up...
Mark...
