#76 |
Re: 1987 R20 Suburban LQ4 4L80E swap
Sorry I haven't posted in a bit.
The Suburban is home now after having the driveshaft and exhaust wrapped up. Today found a couple hours to get some things done on the suburban. Installed the radiator and realized it is still an inch or so too short! Ordered some side mount radiator brackets from LMC hope these will work, if not going to have to get creative and go to Home Depot and see if I can make something. Also found out the nipple on the back of my intake manifold for my brake booster is larger than the nipple on my brake booster so have to figure something out there. Any suggestions? Got my regulator/filter installed and installed all the fittings for the fuel system and trans cooler lines. Also replaced the inline fuel filter under the truck.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 Last edited by Nodnarb76; 03-28-2016 at 08:53 PM. |
#77 |
Here is a pic of one of my new Magnaflow exhaust tips installed.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
#78 |
Looks good. Any more exhaust pics? Sorry can't help on the vacuum line. I've been all hydroboost for some time.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
#79 | |
Should sound great. Dual 2.5" exhaust, magnaflow mufflers and tips, with no cats.
#80 |
I know the pieces fit
Can you post the muffler part number? I'm curious what model you bought and how you like it. I have a pair of them in my parts pile, but since I bought them I've read several posts about how obnoxious they are. And mine are on the small side...
#81 | |
I'm sorry I haven't started it yet so I can't comment on how they sound.
#82 |
Awesome - I'm just glad you have the part number and also aren't running cats. I'll be curious to see how you like them. I'll sheepishly admit the pair I bought have a 14" case and 3" in/out...
#83 |
Well, new radiator brackets from LMC won't work either. They are for a radiator way smaller than mine. I have bought every bracket from LMC and nothing works. The stock one piece top bracket is still too short also. Looks like I am going to have to start making some sort of spacer. This is frustrating, spending all this $$$ on such a nice radiator and the damn thing doesn't fit. I currently have some pieces of rubber hose wedged between the radiator and the rubber mounting pads and it seems to be secure for now, but sure would feel better if I knew it was more secure.
#84 |
Seems like this is very common. I saw this video while radiator shopping, it's changed my mind about aftermarket aluminum radiators: http://www.rockauto.com/en/moreinfo....050635&jsn=423
#85 | |
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
#86 |
Well that's annoying. Could you build some simple spacers out of square stock to go under the bottom mounts?
#87 | |
Glad to know this problem is not unique to me!
#88 |
Good news found a creative solution for my radiator problem.
Using the small block LMC brackets I bought, some neat aluminum spacers I found on an old sign at work, my old exhaust manifold springs, some extra radiator pads I had laying around and two small bolts.
#89 |
Bad news, I got the wrong fittings for my radiator cooler lines!
Does anyone know what fittings I need to connect 6an hoses to my radiator?
#90 |
I'm not sure what your radiator takes, but my stock one has inverted flare fittings. Link below.
http://m.summitracing.com/parts/AER-FBM2111
#91 | |
Just ordered two of those!
#92 |
Well got a little more done today, relocated the fuel regulator, mounted my overflow tank, then ran into a problem. When attaching the nipple to the radiator for the overflow tank, I found out the radiator was dented in where the filler neck is and the hole for the overflow nipple was too low and I couldn't thread it in. I pulled the neck up a little using a prybar and was able to install the nipple, but broke the weld where the filler neck meets the tank!!! In a panic I grabbed some JB weld and patched it up. Because the crack was so small and close to the filler neck, I could reach the crack from the inside and I was able to JB weld it from the inside and out. Going to wait a few days and re- apply. Wish me luck.
Good news, connected my fuel pump and turned the key and squirted fuel on the ground for a few seconds. I have been meaning to do that to make sure I have fuel comming out of my feed line. Without the engine running I am supposed to only get fuel for a few seconds right? when the engine is running it will Keep pumping correct? Figured it was a safety thing in case of an accident.
#93 |
Yeah pretty sure they just prime for a few seconds unless it sees rpm.
#94 |
Mine fit. Hope yours do too.
#95 |
The more I have thought about it, I just don't trust JB weld to last forever.
I am worried I would have a problem at the perfectly wrong time. Going to a shop on Monday to have it properly welded up. My two month build estimate is gone for sure now (going into month 4 soon), no big deal, as my dad is very kind to let me use his truck until mine is done.
#96 |
Junior Member
![]() Join Date: Sep 2013
Nice build. You probably already covered this but what did you use for the ac Comp bracket?
My build thread! http://67-72chevytrucks.com/vboard/s...d.php?t=665907 |
#97 | |
used the Dirty Dingo Compressor mount: http://www.dirtydingo.com/shop/produ...oducts_id=1418 let me know if you have any more questions.
#98 |
Here is a pic of where the crack in my filler neck is (can't see the crack now because of the JB weld I foolishly tried to fix).
Taking it to a shop Monday to get welded. also another pic of how the motor looks now. Getting close, only a few fuel lines to connect once the radiator is done!
#99 |
You are close. I think in the long run you will be happy you had it welded. When you're blasting down the highway in Mississippi doing 80 when its 90 degrees out and the AC is cranked up you will know the system will hold 15 psi... Speaking of AC, what is your plan there?
#100 | |
Glad I had that done. Will pick it up tomorrow. For A/C going with the Sadden 508 Compressor w/Dirty Dingo brackets. Keeping everything else stock, but will have some A/C hoses made once it's up and running again.
