10-25-2016, 01:32 AM | #76 |
70+ ( Old Skool Club )
Re: 1972 Medium Blue Highlander Blazer Resto
I'm jumping on. Thanks for the link Pete lots of great info here.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
10-25-2016, 11:52 AM | #77 |
Those bolts do look much better!
I will have to organize my ziploc bagged bolts and bite the bullet on this one. Thanks. |
10-29-2016, 12:24 PM | #78 |
Carpe manana
Thanks for the good words and for following along.
Since my last post the Blazer was sandblasted revealing sheet metal that really isn't in bad shape and essentially no bondo. The RH rear quarter had bondo that appeared to be an attempt at smoothing contour of the wheel opening and not related to damage repair. The windshield frame has some tiny perforations along the gasket gutter at the top that will serve as access for a POR-15 treatment before getting welded over. Rust primarily involves the outer rockers, anterior inferior rear quarters, and the sides of the floor pan at the tail gate. The wonky appearance of the LH B-pillar relates to a poor welding job when the rear quarter was replaced then some filler added to mask the malalignment. These spot welds have been drilled allowing the components to be mobilized and once re-welded should appear good as new. The replacement LH rear quarter is a GM piece as evidenced by the captured nuts for use with a 1x wall top (I'm told that repro K5 quarters do not have the captured nuts for 1x wall mounting). Interestingly, the bed rail holes for a 2x wall top were not pre-drilled and only two were placed at the time of initial repair.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
10-29-2016, 12:30 PM | #79 |
Carpe manana
I've decided to keep base (sport) mirrors as the Blazer was originally equipped though I much prefer the DF2 camper mirrors.
10-29-2016, 12:33 PM | #80 |
Carpe manana
The blaster warped my hood but compensated me for another hood I found locally that's straight and in original paint.
Am using NOS inner fenders and outer rockers. Remainder of patch pieces I've sourced from Wes @ Classic Heartbeat.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 10-29-2016 at 12:46 PM. |
10-29-2016, 01:52 PM | #81 |
Looks good Pete!
Funny yours came with the small mirror and you prefer the camper. Mine came with camper Mirrors and I'm leaving the small mirror. Just pulled those seats I got from you apart. Should have new foams and covers In a couple weeks!
1972 Dark blue, Cst, Highlander |
10-31-2016, 11:28 AM | #82 |
Pete,
Your making great progress. Nothing alittle love can't fix. Eric |
10-31-2016, 03:15 PM | #83 |
I'm trying....
For some reason I'm not getting email updates on this thread...seems like I've missed a lot of progress this month. Glad I stopped by. Tough luck on the hood Pete. Good thing you had a line on a replacement (you always do) and that the blaster was willing to make good. Love those Genuine GM Parts. You are first class all the way. This is going to be a show stopper. Keep it up. Can't wait for more!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
11-02-2016, 12:41 PM | #84 |
Great progress! I'm not getting updates either.
My son's 1970 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=703733 Iron Canine's Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 Iron Canine's little girl's tractor http://67-72chevytrucks.com/vboard/s...d.php?t=766665 1969 SWB 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=786335 |
11-04-2016, 01:42 PM | #85 | |
11-04-2016, 09:43 PM | #86 | |
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
11-23-2016, 11:38 PM | #87 |
I'm watching...
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
12-27-2016, 12:13 AM | #88 |
Looking good.
01-09-2017, 01:10 AM | #89 |
Carpe manana
Big thanks to you guys for following along and sorry for my lengthy delay. Hope 2017 is off to a good start for y'all!
I've got the Blazer back with Eric and the guys at Mild to Wild here in Albuquerque. They did a great job on my K20 and we had a lot of fun in the process so taking the Blazer back to them was a no-brainer. Making progress on the sheet metal repair and there were no unpleasant surprises once the paint was blasted away. Barry did a great job re-aligning the previously replaced LH rear quarter at the B pillar so a pillar patch wasn't necessary. Fortunately, the replacement quarter was a GM piece and likely done a long while ago so the caged nuts are present for a single wall top in addition to the holes for a double wall top. I've collected various parts, had the carb rebuilt by Sean Murphy Induction, am taking the motor to the machine shop tomorrow, and am awaiting the front seat upholstery and rear panels (rear seat cover is in-hand). The initial set of front bucket seat covers did not have the plaid aligned as per OEM and are being redone (I'm told the OEM style takes more fabric incurring more expense so not typically done). I'll try to post more frequently. More pics available through the Mild to Wild site: http://www.mildtowildinc.com/index.c...=cat/cat72.htm
01-09-2017, 01:12 AM | #90 |
Carpe manana
More...
01-09-2017, 01:18 AM | #91 |
Carpe manana
More....
01-09-2017, 01:22 AM | #92 |
Carpe manana
More...website only letting me post once per 5 minutes?!
01-09-2017, 01:31 AM | #93 |
Carpe manana
More...
01-09-2017, 09:16 AM | #94 |
I'm trying....
Now this is how I like to start my week. Looking great Pete. Thanks for the update. Beautiful metal work. Can't wait for more. Future TOTY in progress.
01-11-2017, 11:35 AM | #95 |
Carpe manana
Thanks Brad!
Loaded the motor into my gmc and delivered it to the folks at Automotive Machine Services, a local shop that's been in business here for many decades. Provided the block and heads check out, the engine will be more-or-less stock but with a roller cam/rockers and a "RV" cam (eke out some more torque).
01-11-2017, 11:37 AM | #96 |
Carpe manana
Dang - I'll flip these later
01-25-2017, 01:39 AM | #97 |
Looks awesome! I hope to be dropping off my block in another month or so. I'm excited to see your interior, I love that highlander look.
Full top blazer or bust.... |
01-31-2017, 11:03 PM | #98 | |
02-01-2017, 11:12 PM | #99 |
Carpe manana
Thanks Chris and Glenn.
I couldn't easily find a fuel neck in the garage tonight but I do have this pic if it helps. The clamps are tower clamps and an OEM black zip tie secures the smaller diameter (vapor?) hose to the adjacent fuel neck. Below the floor pan, tower clamps are used as well. Good to know about the "A" - suspect OEM and will keep tabs. I'm debating whether or not to replate the tank in zinc. I'm told galvanizing is zinc plating but the crystal structure is larger.
02-01-2017, 11:49 PM | #100 |
Thank you, that picture helps me a lot.
72 Chevy K5 CST |
