Old 08-08-2017, 12:55 AM   #76
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Got the box lifted and started measuring contact points.
I still have to complete the previously mentioned list (brakes, etc...) but I couldn't help myself to start preparing for this step.
fishnixon is offline   Reply With Quote
Old 08-09-2017, 03:04 PM   #77
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
So, a simple oil change was a little more arduous than expected.
Old 08-09-2017, 03:12 PM   #78
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I had sprayed some penetrant on the filter/block junction which helped, and as I did that, I noticed that my alternator belt was a little loose...I sprayed down the bolts and then tried to loosen them...Arrrrrgh...busted them off and created more work. So, with that, I started spraying every bolt on the block for future work... I will do this off and on now. Bummer.
Also, took off the carb so as to put in an accelerator pump.
Old 08-09-2017, 07:21 PM   #79
rustytruck50
rustytruck50's Avatar
Re: Dumptruck Dolly
That's frustrating....I've been fortunate enough to not have that happen and need to use an easy out....looks like you're making progress, though !
-Doug
'05 RCSB Sierra 2WD
'71 Sierra 2WD Longbed
'98 Silverado K1500 Xcab...sold
'72 Highlander"Raymond"...sold
rustytruck50 is offline   Reply With Quote
Old 08-09-2017, 08:42 PM   #80
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Yes, I am making some headway and to quote from an Eastwood film, I will "endeavor to persevere".
Tonight, I am going to research the carb rebuild. My primary goal is to get the accelerator pump replaced, but depending on how things come apart, I may have to go all the way with the rebuild. Haven't done that in quite awhile, and that being just once. (On a 1955 big window Chevy truck with a 235ci).
Old 08-21-2017, 01:01 AM   #81
junksaver
Re: Dumptruck Dolly
Any updates? Did you get the carb rebuilt?
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 08-27-2017, 07:01 PM   #82
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
I got it put together, and back on the manifold...but that's been about it for now, as I've had to do some of my landscaping at my place and also at a neighbors.
I put a 1956 Crestliner Viking runabout into the water, so I had some fun with that too...it's been a 2 year project.
Now hopefully the rain stops...geez
Old 10-14-2017, 05:09 PM   #83
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Ok, got back to the project, in between the kids school sporting events, reffing high school and college football, and of course my everyday job...
1. Put brakes on all four corners, as well as brake line.
2. Fuel pump replaced after the original sprung a leak.
3. Ordered new upper and lower radiator hoses and new choke cable...not put on yet.
4. I enlisted a fabricator that I’ve worked with to put the dump box onto Dolly. He’ll put on new hydraulic hose and align everything up. Whew, winter is fast approaching and his help will make things manageable.
Old 10-14-2017, 05:13 PM   #84
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Here are a couple of pictures of Dolly and the dump box.
Old 10-17-2017, 07:05 PM   #85
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
A leak in the thermostat housing calls for a spare from a truck out back.
Old 10-17-2017, 07:09 PM   #86
68panelman
68panelman's Avatar
Re: Dumptruck Dolly
Looking good!, I miss the days of having multiple Parts trucks in the back to pull parts off of.
68panelman is offline   Reply With Quote
Old 10-17-2017, 07:18 PM   #87
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
While extracting the broken bolt from the block (see previous pics), the water pump had a wobble in it and the radiator’s over flow and drain bung came apart, and with inspection, the bottom of the radiator was toast. New items will arrive in 4 days and 1 day respectfully. Notice a fuel filter in line. New plugs and wires too.
Now I have to find a gas tank...the 2 gallon tank under the hood won’t do...I’ve got a couple feelers out there, and also priced a new one, with neck grommet and a sending unit for about $255. A 4 day waiting period.
Old 10-17-2017, 07:21 PM   #88
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thank you vary much. They’re good to have...I actually thought I had the radiator issue taken care of, but when I went to pull it out, it had been bent and most of the fins were crushed...bummer.
Old 10-18-2017, 04:27 PM   #89
Orange67
Orange67's Avatar
Re: Dumptruck Dolly
Really dig this and your rollback. Very nice trucks man.
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 10-19-2017, 01:31 AM   #90
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thank you Orange67
Old 10-19-2017, 09:53 PM   #91
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Could not find a clean gas tank locally, ordered a new one from LMC. Should be here early next week.
Old 10-19-2017, 10:15 PM   #92
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
On a sidenote, since the rollback has been on this thread before, I’ll be using it tomorrow to pick up lumber and doors for a studio project in my basement. Justification at its finest!
On Saturday morning, there is a car show and burnout contest in Ely as a fundraiser for the Jake Forsman scholarship. This will go towards education within the trades… HVAC, metals, electrical, etc.… Should be a good time. This is the first annual event, and will always take place on the third Saturday of October.
Old 10-25-2017, 02:14 PM   #93
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Getting the frame ready for the dump box.
Old 10-25-2017, 02:16 PM   #94
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Got the gas tank. Went with a new one.
Old 10-25-2017, 02:22 PM   #95
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
New items include water pump, radiator and hoses. I need to find a new upper radiator hose as the local distributor did not have one, nor did they locate one.
So to recap thus far: new plugs, wires, fuel pump, fuel filter, hoses, water pump, anti-freeze , thermostat, radiator, accelerator pump, points and fuel tank.
Old 10-27-2017, 02:58 PM   #96
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Box getting sized up for Dolly.
Old 10-27-2017, 03:02 PM   #97
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
More pics of Dolly's box
Old 10-27-2017, 04:20 PM   #98
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Dumptruck Dolly
Coming along nicely!.
How was the repro gas tank for fit and such? Any issues?
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 10-27-2017, 05:58 PM   #99
fishnixon
fishnixon's Avatar
Re: Dumptruck Dolly
Thanks Eric...
It went in as it should. No complaints. The tank came with a gasket for the sending unit so when I ordered and received the sending unit, it came with one as well. Now I have one for the shelf. I also put in a new neck grommet for the cab.
Old 10-27-2017, 08:05 PM   #100
rustytruck50
Re: Dumptruck Dolly
Looks great!
-Doug
'05 RCSB Sierra 2WD
