Old 10-25-2018, 12:48 PM   #76
knomadd
knomadd's Avatar
Re: 72 Swb starting from the bottom
I just found your thread. You've done some nice work so far. I'll be following along on this one. Keep it up!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 10-26-2018, 11:20 PM   #77
J3rm0ff
Thanks!!
Got one side of th exhaust about ready to weld up. Taking a week off and heading out to Vegas for sema.
J3rm0ff is offline   Reply With Quote
Old 11-12-2018, 10:32 PM   #78
J3rm0ff
After getting back from SEMA the first thing I did was set the cab back on the frame. And of course it hit the exhaust. Thought I had that planned out. Anyways I redid that added another clamp right before it goes over the axle.
Also started working on the trailing arm crossmember to add clearance for a 3.5 driveshaft
Old 11-14-2018, 10:43 PM   #79
J3rm0ff
While out at SEMA I purchased a QuickJack directly thru them for a heck of a price. It finally came in and got it out together. Definitely looking forward to using this.
Old 11-18-2018, 09:53 PM   #80
J3rm0ff
Got the driver side exhaust tacked and ready to weld over the weekend.
Old 11-28-2018, 09:39 PM   #81
J3rm0ff
Haven’t made much progress. Welded up the rear shock mounts and cross bars. And started working on exhaust hangers. Also found a much tighter bend aluminum pipe so going to be redoing my intercooler piping again
Old 12-05-2018, 11:14 PM   #82
J3rm0ff
Driveshaft hoop for the trailing arm crossmember is tacked in. All kinds of room now.
Old 01-04-2019, 12:49 PM   #83
J3rm0ff
Haven’t got much done in the past couple weeks. Caught up on some house projects and put in some new lights in the garage. Now I need to clean up again.
Old 01-08-2019, 11:00 PM   #84
J3rm0ff
I guess I did get more done than I thought. I got the hoop almost completely welded in. The exhaust rings are welded in. Rear exhaust hangers are welded in. Made some brackets to hold bump stops so the axle isn’t resting against the frame when aired out. Made some progress on the exhaust crossover to go under the driveshaft. Had to rig up some pipe to allow me to make the tubing into an oval. Also decided to make the gas tank flush with the top of the frame after putting the rear bumper on it won’t be hanging down below it.
Old 01-09-2019, 11:12 PM   #85
J3rm0ff
Finished racking the exhaust crossover tonight and threw the other side on. Starting to actually look like something.
Old 01-15-2019, 10:23 PM   #86
J3rm0ff
Got the derale trans cooler mounted between the front frame rails. Hopefully this will do a good job at keeping the 4l80 cool. Also got the vintage air mini unit mounted. Had to run the mini to fit under the impala dash. But this will also allow me to hide the heater hoses and ac lines better.
Old 01-17-2019, 07:32 PM   #87
Sparky dave
Well done on this one I’m inspired
Sparky dave is offline   Reply With Quote
Old 01-17-2019, 10:22 PM   #88
J3rm0ff
Thank you!
Old 01-17-2019, 10:27 PM   #89
J3rm0ff
After going to sema and coming back my silicone elbows have bothered me. I don’t know why but they have. So I got reducers and found a company that sells much tighter radiused aluminum elbows than what I was using. Much happier with it now that it’s all tucked in better. Also got the upper radiator hose together.
Old 01-20-2019, 06:58 PM   #90
J3rm0ff
Got a couple things done this weekend. Got the bov flange tacked on to make sure I like the location. Also got the inside of the fire wall in epoxy so I can work on getting the dash welded in.
Old 01-23-2019, 08:38 PM   #91
Sparky dave
I just got giddy looking at that engine bay. I want, I want lol
Old 01-25-2019, 12:31 PM   #92
J3rm0ff
I feel the same way every time I go out to the garage!
Old 02-02-2019, 12:32 AM   #93
J3rm0ff
Got a 14x22 vintage air condenser and got it mounted up. But In order to do that I had to make the mounts for the radiator to find it’s final resting place. I lowered it down and moved the bottom closer towards the engine and the top closer towards the core support. The upper radiator supports still need trimmed up. Also tested out a bead roller I bought a while back on some aluminum tubing.
Old 02-07-2019, 11:19 PM   #94
J3rm0ff
Started back on the dash. Took another 1” or so out of the depth. Decided to focus on the dash and get it fully welded in this month. That will be a big mental step for me.
Old 02-22-2019, 04:14 PM   #95
J3rm0ff
Still working on this dash..
Old 02-28-2019, 10:14 PM   #96
J3rm0ff
Working on the end caps for the dash and it will finally be ready to weld in. Threw the gauges in for inspiration.
Old 02-28-2019, 10:24 PM   #97
cornerstone
cornerstone's Avatar
Lookin' real good! Inspiration always helps...
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-01-2019, 12:37 PM   #98
knomadd
knomadd's Avatar
Looking good! Here's some inspiration for you:
Name:  2019-02-23 15.12.33.jpg
-Duane
Old 03-02-2019, 10:11 PM   #99
J3rm0ff
Attachment 1880823
That’s definitely some inspiration! I’d like to do an aluminum trim piece like that.
Pretty much finished up one end cap. Hopefully the other side goes faster.
Old 03-08-2019, 06:08 PM   #100
J3rm0ff
Found a home for the vintage airi controls. It’s just roughed in right now. But I think this will work out well. I think I will also add a USB port and auxiliary port below the controls.
