Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-12-2021, 09:12 AM   #76
MONTE
MONTE's Avatar
Re: C20/cummins 12 valve
And it begins.
Need to get replacement panels.
Like the electric 6 inch sander.
Not to crazy about the burnishing polishing machine
MONTE is offline   Reply With Quote
Old 01-13-2021, 09:49 AM   #77
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Getting it blasted might not be a bad idea. Make sure all your mechanical stuff get sealed up really well. Nice on new house and shop. Nothing wrong with that.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-13-2021, 11:36 AM   #78
MONTE
MONTE's Avatar
I was thinking about getting it blasted. Not that many guys that do it in my area.
Old 06-22-2021, 11:09 AM   #79
MONTE
MONTE's Avatar
Need to get a few body panels.
Anyone used Raybuck or c2cfabrication?
Old 06-29-2021, 08:40 PM   #80
MONTE
MONTE's Avatar
Re: C10 suburban /cummins 12 valve
Old 06-29-2021, 08:41 PM   #81
MONTE
MONTE's Avatar
Updates
Old 07-01-2021, 05:51 PM   #82
MONTE
MONTE's Avatar
Score on mirrors?
Old 07-08-2021, 03:59 PM   #83
MONTE
MONTE's Avatar
Better do it right.
Old 08-05-2021, 11:10 PM   #84
MONTE
MONTE's Avatar
Old 08-14-2021, 08:24 AM   #85
MONTE
MONTE's Avatar
I think at this point I should move this to suburban builds. How do I go about that?
Old 08-15-2021, 11:08 PM   #86
MONTE
MONTE's Avatar
UpdateName:  675D5007-8370-4AF4-9985-4BA5C080EC2E.jpg
Old 08-15-2021, 11:10 PM   #87
MONTE
MONTE's Avatar
Re: C10/Suburban Cummins
Had me confused for a while. Don't do the same mistake I did. You need to trim this back end.
Old 08-16-2021, 07:48 PM   #88
Dieselwrencher
Looking good!
Ryan
Old 08-21-2021, 11:15 AM   #89
MONTE
MONTE's Avatar
Re: C10 Suburban Cummins
This is what I was talking about.
Don’t remove!
Old 08-21-2021, 03:56 PM   #90
MONTE
MONTE's Avatar
Went with POR-15 for all the inside.
Old 08-21-2021, 08:06 PM   #91
pwdcougar
pwdcougar's Avatar
Looking good! Also looking familiar, I did similar work on my 70 K10
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 08-22-2021, 01:55 PM   #92
MONTE
MONTE's Avatar
Little spot welds
Old 08-23-2021, 12:56 PM   #93
Dieselwrencher
At least your inner wheel house wasn't all rotted out. As far as moving the thread, I'd almost leave this one here and then start a thread in the suburban area showing the progress on the burb. Thats what I'm doing on my wife's 72 burb.
Ryan
Old 08-28-2021, 09:55 PM   #94
MONTE
MONTE's Avatar
For your 1st timers like me:
1. Try to get all your panels from same supplier. Bottom lip where you tac to the wheel arch had to be modified to look somewhat the same.
2. Make sure you have some support on the inside pushing the panel out. I was so worried about not having big gap that I didn’t notice that the top weld from the door to the wheel arch had pushed in. This is because this section of the panel only has a horizontal support. The back half has a vertical support so didn’t have an issue on the back 1/2.
3. This was not an issue but when you weld jump around on the welds to avoid warping.
Hopefully these pics will help the next guy trying to do this job.
Old 08-28-2021, 10:03 PM   #95
MONTE
MONTE's Avatar
1. This back had no issues.
2. This is the inside support.
3. Inside support.
4. This is where I see an issue. Since no inside support. Make sure you have something pushing the panel out before you weld.
5. Since I used 2 different suppliers for my panels. They required some modification to make them work. Stick to one supplier if possible.
Old 09-06-2021, 12:27 PM   #96
MONTE
MONTE's Avatar
Looks like the rear light panel is a little off.
Old 08-03-2023, 09:08 AM   #97
MONTE
MONTE's Avatar
Getting back into it.
Old 08-03-2023, 09:29 AM   #98
LockDoc
The Older Generation
LockDoc's Avatar
Good deal! Glad to see you back on it. I'm having the same problem with my project, too many interruptions....
LockDoc
Leon
Old 08-03-2023, 10:16 AM   #99
Dieselwrencher
That's looking good. I need more time to dwindle the project list down so I could work on the wife's burb.
Ryan
Old 08-06-2023, 03:15 PM   #100
MONTE
MONTE's Avatar
Not bad.
