Old 07-17-2019, 01:18 AM   #76
Getter-Done
Getter-Done's Avatar
Re: 67 (Crew Cab) C30
A little more progress.
The Person that normally does my sand blasting is Booked Up.
So that leaves it to ( You know who)
It was close to sunset on the next 2 Pictures.
Better than No Pics???
84 Chevy K-20
Old 07-17-2019, 01:38 AM   #77
Getter-Done
My Hired help seems to be on Vaca-tion
Here is a picture of under the dash after sandblasting and primer.
84 Chevy K-20
Old 09-12-2019, 11:34 PM   #78
Getter-Done
Quick update.
I got the cab divided.
I will post more pictures.
84 Chevy K-20
Old 09-13-2019, 10:52 PM   #79
Getter-Done
Couple more pics.
84 Chevy K-20
Old 09-15-2019, 04:00 PM   #80
Getter-Done
Got the front part of the (top)roof skin removed.
I was a little rusty at the seam.
84 Chevy K-20
Old 09-15-2019, 04:14 PM   #81
Getter-Done
There was (mouse nest) insulation all across the front on the roof seam.
At first I though mice?
It was neatly placed all the way across the front channel.
So this is what the factory done to hold the cab light wire in place and protect it.
Because some of it was still bonded to the wiring harness.
Driver's side sunvisor reinforcement plate
and hole for routing cab light harness.
Pass. side sunvisor reinforcement is there
so A visor could be added.
Because this truck didn't come out with one.
This is the last terminal on the cab light harness.
Here's a picture of the Insulation
from pass side view.
84 Chevy K-20
Old 09-23-2019, 09:47 PM   #82
Getter-Done
I have got a little more done.
I will catch up with my pictures & progress.
I am cleaning up from when I cut the roof off.
Drivers side B-Pillar
Top view inside dome light.
I am removing the excess piece by piece to
keep my back panel in the best condition.
84 Chevy K-20
Old 09-23-2019, 10:06 PM   #83
Getter-Done
I used a grinder and a
home made chisel
and took my time to remove
the spot welds of the excess
of where I cut the roof panel out.
84 Chevy K-20
Old 09-24-2019, 11:13 PM   #84
Getter-Done
Pass. side clean up of roof removal
Center
Driver's Side
84 Chevy K-20
Old 10-17-2019, 11:03 PM   #85
Getter-Done
Here is a small update.
After splitting (di-sec-ting) the cab
Got the cab sand blasted.
Then primed.
More pictures soon.
84 Chevy K-20
Old 10-19-2019, 09:49 PM   #86
Getter-Done
A few more pictures.
Fresh out of the sand blast place.
Back of the cab
Right side (under the dash)
Left side (under the dash)
84 Chevy K-20
Old 10-19-2019, 09:58 PM   #87
Getter-Done
Got it Primed
Left side (back of cab)
Ride side (back of cab)
Top view from Drivers side
84 Chevy K-20
Old 10-19-2019, 10:00 PM   #88
72 tigger
72 tigger's Avatar
Good progress, building it right
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 10-19-2019, 10:07 PM   #89
Getter-Done
My next step is a (Frame) jig for the floor-pans.
I need to drill holes in that frame then level it.
84 Chevy K-20
Old 10-19-2019, 10:11 PM   #90
Madkidd007
Madkidd007's Avatar
Are you meaning make a jig to put your body mounts on the frame?
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 10-19-2019, 11:25 PM   #91
Getter-Done
Madkidd007
I am in the process of making a Platform for the cab.
When I complete it I will take Pictures.
This platform is to build the cab.
I am making this platform using 8" I beam for my base.
I will have stands for the different measurements with
the floor-pan braces that it will take to make the
differences in the mounting points in my Floor-pan.
This is how I will transfer the floor-pan to my frame
and cab mount locations.
84 Chevy K-20
Old 11-03-2019, 11:07 PM   #92
Getter-Done
Small update.
My helping hand is getting a little sassy.
Got some work done on the platform.
This is the frame I will build my cab on.
I leveled and welded the 2 I-Beams.
Check Both I-Beams for square in X & Y & Z.
84 Chevy K-20
Old 11-16-2019, 11:04 AM   #93
clay68c10
clay68c10's Avatar
That’s one hell of a platform! I like it. You could also use it to do any frame work needed.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-16-2019, 11:16 AM   #94
Getter-Done
I hope to get some more work done to the frame today.
84 Chevy K-20
Old 11-17-2019, 11:19 PM   #95
Getter-Done
Added Trailer hitch to my Platform.
This will be used to build the cab.
My helper is asleep at the wheel
Welding the hitch on the trailer
1Name:  f2.JPG
2Name:  f3.JPG
3Name:  f4.JPG
Finished and Now My
Helper is Awake
I will get picture's of this frame in the day-light
later on.
She must be a Night - Shift dog
84 Chevy K-20
Old 11-24-2019, 11:01 PM   #96
Getter-Done
Update.
84 Chevy K-20
Old 11-24-2019, 11:16 PM   #97
Getter-Done
I got the 2 floor pans mated together for
some measurements.
84 Chevy K-20
Old 01-03-2020, 11:54 PM   #98
Getter-Done
Progress report.
After All the Holiday party's
I am Glad to spend time with the family
I just wish they liked Trucks like I do.
I cut Circle's out of a sheet of steel
I welded those to the top and bottom of a piece of pipe
to make some stands for leveling the floor pan.
I didn't take a Picture of the pipe before I started cutting
This pipe that I used was the pipe that was my basketball pole
when I was young.
Yea I saved it that long.
I turned these on the lathe.
Then put them on the mill to get them close to size.
I then had them Precision ground
to the (height) +/- frame mounts / jig frame.
These are the test fixtures.
These will be used on my platform.
84 Chevy K-20
Old 01-04-2020, 12:32 AM   #99
Getter-Done
Then the Next step is the
Solid stands I have machined in the 3rd and 4th picture.
I will get the floor-pans leveled with the pipe stands
in the 1st and 2nd picture below.
Then I will know the Difference between the
front and Rear stand measurements.
These (solid) stands in the pictures below
are on stand -By for now
Once I get the floor-pans level.
I will know the measurement to grind these stands
in the pictures below.
84 Chevy K-20
Old 01-04-2020, 09:14 PM   #100
1968k20
1968k20's Avatar
Wow, impressive! How much does your helper get paid per hour?
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
