03-05-2020, 11:27 AM | #76 |
Re: Swapped PCV & gained big time!
Dave,
Please have the interested parties e-mail their order to me and mention Daves2020 Group Buy to receive the discount. When I receive 6 orders I will send each party their invoices through PayPal which they can pay for with any credit card. Thank for your getting your group buy together. Barbara Wagner Customer Service M/E Wagner Performance Products 570-899-4544 www.mewagner.com |
03-05-2020, 03:45 PM | #77 |
03-06-2020, 12:32 PM | #78 |
We have reached the purchase threshold, I've asked Wagner to hold group buy open for another week.
03-06-2020, 01:45 PM | #79 |
Hi Dave,
I’ve sent your PayPal invoice. The group buy will be available until March 31. This will give others a fair amount of time to respond. Thank you for organizing this group buy. Barbara Wagner Customer Service M/E Wagner Performance Products 570-899-4544 www.mewagner.com |
09-20-2021, 09:05 PM | #80 |
Hey Dave, got any pictures of that install? I'm considering redoing my PCV system, but I like the look of no holes in my valve covers.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-20-2021, 10:14 PM | #81 |
I don't have one but I borrowed one on line. As in the picture, I planted the PCV right into the block with the properly sized grommet. My line to the back of the carb varied a bit from the pic in that I made it a straight shot by putting a short piece of rubber hose at the rear of the carb using a theaded brass hose barb and another short piece at the valve. Then, I used a custom bent metal line in between. I tried it first with rubber all the way but it wanted to kink and push the PCV backward toward the firewall dislodging it from the grommet.
09-20-2021, 10:31 PM | #82 |
I got a half arsed decent pic of mine for you. Showing the S bend in the metal line that I used to make it all copacetic.
09-20-2021, 11:58 PM | #83 |
Thank you! I like that a lot better than the PCV valve I used prior that just screws into the back of the carb. Much harder to replace when needed, and it's been in there since I did the engine swap. Oops
Looks like I'll be doing some research tomorrow to find that grommet for the back
01-09-2022, 05:34 PM | #84 |
Did anyone use an air oil separator when installing this PVC valve?
01-09-2022, 07:24 PM | #85 |
Forest, I didn't use the separator. I really didn't see the point since I wasn't really drawing much oil thru my pcv anymore with the new valvecovers. My old covers though.....wow, the baffle was a piece of garbage made by me and I used to wonder where my oil went. Then I watched those videos on the ME Wagner website and I figured it was my bogus baffle. A pair of new covers with a factory type baffle pretty much cured that whole problem. I got the impression that the separator was for those who wish to confirm that they were indeed drawing oil thru the pcv valve and wanted to see how much they were losing.
01-09-2022, 08:03 PM | #86 |
Just asking because I was just looking at the installation checklist and it said “ An air-oil separator between the PCV valve and manifold vacuum source is optional, but is recommended if the application permits. Ensure the air-oil separator does not restrict airflow, some smaller units can cause a significant vacuum drop which may interfere with PCV valve tuning. M/E Wagner has used Moroso part number 85474 successfully in various applications.”
