08-20-2023, 01:15 PM | #76 | |
Re: S10 Frame Swap on 47-53 - Would you do it again?
08-20-2023, 03:25 PM | #77 |
I guess i gotta ask what intricate work I talked about?
shortening the frame is pretty standard if someone start withs the wrong wheelbase; use a longbed and its even easier than the 2wd swap. moving the motor back wont be an issue for most people, using a v8 does it automatically, just need a trans mount. the front bumper mount I make now will work just fine on a 4x4 chassis with a little grinding where the swaybar goes. I think someone could do a 4x4 s10 faster now than it even took you to do the 84 shortbed swap. I have made mounts for those C10 swaps (and jeep J10 swaps, and dodge 2500 swaps, etc) and they are taller because of the kickup under the back of the cab. doesnt hurt on a 4x4 swap, free lift kit haha.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
08-20-2023, 06:54 PM | #78 |
Altering chassis is a precise art well out side my abilities. Everything you described is intricate compared with straight body swap in a wet cow pie laden pasture with only a couple boards and a cutting torch.
08-23-2023, 09:13 AM | #79 |
And i think i did a pretty good job hahahah
If i did do it again, i would buy a "s10 kit" - more for the time i could have saved I guess they are all a puzzle, . . . . and dont get me wrong, im pretty stoked now that i have it done Heres a pic : |
08-23-2023, 10:12 AM | #80 | |
09-07-2023, 06:39 PM | #81 | |
09-07-2023, 07:07 PM | #82 |
Looks great!!!
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 |
09-07-2023, 08:03 PM | #83 |
About ten years ago I came across a good deal on a 55.1 five window pickup. I decided to upgrade the suspension and steering and after weighing the pros and cons of upgrading the stick frame vs an S10 chassis swap, I decided in the s10 swap. I knew where I could pick up a 1985 s10 lwb rolling chassis for $300. I sold all the body parts for $400, so I made money. I decided to use the EZ Chassis swaps kit to save time. I picked up a wider 4x4 rear axle with 4.10 gears and posi for $100 and sold the old rear for $50. The swap kit worked extremely well. If you have the time and skill it may not be worth it to you. It is a little more comprehensive than mentioned above. Not only does it have brackets and instructions for the cab bed and bumpers, but it comes with pieces to mount the s10 steering column and brake booster. Unfortunately “life has gotten in the way” as they say and the truck project is currently dormant. It currently has a rebuilt vortec 350 with a carbed intake, ZZ4 crate motor take out cam, s10 b8 swap headers and an S10 T5 trans. It still needs floors, bodywork and wiring.
09-26-2023, 08:57 PM | #84 |
