05-04-2021, 10:10 PM | #76 |
Re: My 58 Brookwood
All mocked up after pulling the column and brakes 5 times to ensure everything fit
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
05-05-2021, 10:15 PM | #77 |
Re: My 58 Brookwood
Here’s the lower column bracket we made
Here’s an "in progress pic of the firewall
05-11-2021, 11:36 PM | #78 |
Re: My 58 Brookwood
Firewall is all finished and we begin final install on the brakes and column tomorrow
05-20-2021, 09:44 PM | #79 |
Re: My 58 Brookwood
These are the handmade motor Mount Adapters
The motor Mounts and Adapters required Modification
05-21-2021, 08:49 PM | #80 |
Re: My 58 Brookwood
We Built the motor mounts and test fit the engine today
06-01-2021, 12:36 AM | #81 |
Re: My 58 Brookwood
Today we put on the collector’s and welded the O2 bungs
We also created a firewall pass through for the Wiring harness.
06-08-2021, 09:37 PM | #82 |
Re: My 58 Brookwood
The new alternator came in
The new O2's came in And we finally pulled that lifting plate off and put the Valley cover back on
06-17-2021, 10:23 PM | #83 |
Re: My 58 Brookwood
Here is that 600hp LS3 nestled in the engine bay!
Here’s a view From the bottom of That 4L80E and how well it Fits.
06-18-2021, 08:09 AM | #84 |
Re: My 58 Brookwood
Looking awesome. I like those valve covers on the LS3. A bit of old school flare with the fins. Where did you find them? Is the harness a holley terminator?
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
06-18-2021, 08:14 AM | #85 |
Re: My 58 Brookwood
Nope, bought it one eBay. $450
06-22-2021, 08:23 PM | #86 |
Re: My 58 Brookwood
we put 2 3/8 nipples in the bottom for the brake booster and the PCV
06-22-2021, 08:27 PM | #87 |
Re: My 58 Brookwood
Here’s the overview of how the engine looks in the bay
so we cut the tunnel 7” wide to facilitate the installation of our 12” Lokar tail shaft mounted shifter
06-23-2021, 10:09 PM | #88 |
Re: My 58 Brookwood
We got the right MAP sensor in today and mounted it
I think it looks clean on the back of the intake Here’s that LS3 in the engine bay. Just can’t get enough of that sick looking MF'er!
06-24-2021, 07:44 PM | #89 |
Re: My 58 Brookwood
We put the 3/8 hoses on the intake
Routed the steam tubes This is the engine with all the Wiring ran and plugged in
06-24-2021, 09:08 PM | #90 |
Proprietor of Dale's Corner
Re: My 58 Brookwood
Looking good!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-25-2021, 09:11 PM | #91 |
Re: My 58 Brookwood
Thank you
Today we modified the Transmission crossmember to slide 8” back for our 4L80E
06-25-2021, 09:22 PM | #92 |
Re: My 58 Brookwood
It's coming along nicely. Keep plugging away!
06-25-2021, 11:36 PM | #93 |
Re: My 58 Brookwood
We are only able to work on it about an hour a day.
