07-01-2022, 08:51 AM | #76 |
Re: '95 Heater Control Panel. What's The Diff?
Well, one thing fixed and another needs attention.
Glad you're making progress!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
07-01-2022, 10:19 AM | #77 | |
I wonder about the blower motor being bad now. I had started replacing the resistor (I kept calling module) last winter but abandoned it until I got a long handle 1/2" ratchet. what is the component you remove to get to the resistor on a bracket, as I recall? I'm not sure if I even reconnected that. I'll have to look. I'm not sure the old resistor is plugged in. There would have been no power to the blower, right? So, wouldn't have given that last breath. I also need to look into a new ground for switch. I have a nicer cluster surround I didn't have with me as well as the high end stereo I want to install. So, I'll be back in there soon
07-01-2022, 11:33 AM | #78 | |
Actually, I suggested it first. But it's cool you got it swapped out.
07-01-2022, 07:59 PM | #79 |
Sorry to overlook this. This is quite a long thread over a long time. I am no less appreciative to you. In fact, since you were the first I'll go back and delete my thanks to Hatzie
07-01-2022, 08:13 PM | #80 | |
Lol
07-02-2022, 09:28 AM | #81 |
laying low
If the blower wasn't noisey before, I'd put my bet on the resistor gone south or weak grounds.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-02-2022, 12:33 PM | #82 | |
He's such a good mechanic, and I mean analyzing, I'm not sure why he went straight to replace motor. I want to talk to him before I get into it. He's definitely not a parts swapper. He even said go get yourself a junk yard one when a new one is not expensive. I asked about the resistor and he did say he'd go ahead and replace that since the truck is so old and I'm already right there. And I have a new GM part.
07-02-2022, 04:37 PM | #83 |
laying low
You're set then.
07-02-2022, 09:09 PM | #84 |
We'll see. I'm doing the resistor while I'm at it. I have the GM one waiting. While I'm into it I'll do a better ground if it doesn't act right after the parts. I get the heat going, next I should look into why I lost a/c. It worked, then must have leaked down over winter and lost it's cool
07-02-2022, 10:47 PM | #85 | |
Just see if the motor is getting power. I think I've changed the motor on all mine, twice on the 93. They don't seem to be too great. I usually test them right to the battery after I've pulled it.
07-03-2022, 07:42 AM | #86 |
Makes sense. At least the motors aren't so expensive and not so hard to replace
