Old 06-29-2014, 01:02 AM   #976
6lcummins
Re: 72 k20 project
Originally Posted by ryanroo View Post
which it are you referring to? without knowing i can answer, Yes. the table top is .75" and plenty heavy for my needs. the pan flange is .375" 6061t6 AL and more than adequate. the pan is .090" 5052 AL. at nearly 3/32" it is thicker than it needs to be for a zero(or very low) pressure environment and less than 3 gallons of oil volume. it could have esily been .050" or even less, but it gets more tedious to weld once you get below .080 or so. if i had done my research i would have laid out the bend details for .100" or .080" since we had more smaller drops of those to choose from, but i got lucky and found the one piece of .090" we had in the drop rack and it was a perfect fit for these parts. otherwise i would have had to go out to the metal storage and pull a full sheet. that would have been lame.
I was being sarcastic... Want me to send my polisher out for when its done?
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 06-29-2014, 09:29 AM   #977
ryanroo
ryanroo's Avatar
Re: 72 k20 project
I figured. thats why i gave the full scale run down for you... haha
i did find a place in MO that does fantastic polishing. chrome like finish. but that is to shiny. i did give a token amount of thought to sending it to an electro-polishing outfit too, but i like the raw finish better.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 06-29-2014, 11:03 PM   #978
ryanroo
ryanroo's Avatar
Re: 72 k20 project
so, i did a little fiddling around and found that the original hood to the truck was not worth any more time. the front edge was rusted out, in an unfortunate turn of events. i had it sitting on a pallet in my Grandma's shed for years. at some point it was bumped off the pallet and sat on the dirt floor. in humid IA.
No biggy, the hood from the yellow truck is in good shape and absolutely rust free. BUT, it has fortyseven coats of stuff on it. i used stripper and a scraper to get most of the top layers. there was a very resilient layer of primer at the bottom. it is sanded almost through as well. but i figured it added a helpful layer of filler. i also started to flatten the front edge a little. it had few dings and i figured i would smooth it out. still needs some tuning, but that gives me something to do after school. my air compressor deserved a break anyhow. i had been beating on it all afternoon
this innocuous yellow paint is deceptive. under it is another shade of yellow, a nice brown, a gray primer, what must have been a white repaint early on to match the OEM, and the super primer. dang.
72 K20 12v build
Old 06-30-2014, 06:46 PM   #979
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Looking good Ryan! That paint removal is always a PITA!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-30-2014, 09:15 PM   #980
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
i had read somewhere that sandblasting the hood is a no no. i guess it is too flat. i didn't even talk to the blaster, figured it was good for me to put on the ear muffs and ear phones, slap on the respirator and sweat to the oldies for a few hours. not sure if it was my favorite thing, but i can drop this off at the painter this week, and hopefully temp him with cash so he shoots the rest of the front clip and doors too. long weekend coming up, and i am thinking about pulling the bed apart. that will give me access to the rear frame and make some of the plumbing and whatnot easier as well as making me less nervous when the cab sits back down. it will also force me to get serious about ordering the bed parts. not that i am real excited about that. i have an order on Summit for way to much money and it doesnt even begin to cover all the fittings and hoses i need for plumbing. this thing is a money grubbing whore. haha
since no one wants to hear me whine, ill post some pics.
tacked this up a little.
72 K20 12v build
Old 07-01-2014, 08:29 AM   #981
tsnow678
Re: 72 k20 project
Amen brother! Can you imagine what this truck would cost you if you weren't able to fabricate. It's either a disease as to why we spent every moment in the garage or just a passion. I want to believe its an undying love for metal, wheels, and noise but sometimes I wonder.
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 07-01-2014, 02:54 PM   #982
Dieselwrencher
Re: 72 k20 project
Great work on the oil pan. Now get to work making more to pay for your ho!
Ryan
Old 07-01-2014, 09:22 PM   #983
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i figured up what i would make an hour if i was able to bill 900 bucks for one, like 6 bucks an hour. id do better shaking hands at walmart.
72 K20 12v build
Old 07-01-2014, 09:54 PM   #984
6lcummins
Re: 72 k20 project
$900 is a little low for a custom aluminum oil pan....
"STOCK"
ASSEMBLY THREAD
Old 07-01-2014, 10:19 PM   #985
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i dont even know. no one i found even makes them. the only one i could find was ZZ fab and he never returned my phone call.
Old 07-01-2014, 10:39 PM   #986
Mustard72
Mustard72's Avatar
Re: 72 k20 project
So at a rate of $6/hour, what is the whole truck worth?
Never mind. It'd probably be depressing to think about it. Mine would be worth a mint, and I don't have near as much time (or talent) into mine. Run of the mill C20's with amateur body work just don't bring in that kind of dinero. So I'll probably just keep it for another 28 years.
Keep it up. This thread is awesome.
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 07-01-2014, 10:43 PM   #987
6lcummins
Re: 72 k20 project
In all honesty, $1500-2500
"STOCK"
ASSEMBLY THREAD
Old 07-01-2014, 10:57 PM   #988
ryanroo
ryanroo's Avatar
Re: 72 k20 project
at that rate, just considering labor, probably like half a million. haha. maybe not quite. sometimes it seems like 1000s and 1000s of hours. probably not as much as it seems since i do a lot of contemplating and not a lot of work some days in the garage.
i wouldnt feel bad charging that, depending on the requirements of the pan. to do a complete custom takes time. even mine isn't that intricate and the layout was painful to the head. just to break up the material i have now required 12 or so different lines of program in the break, and each one is a set up procedure. i think it took me over an hour just to break that up. after the mind bending computer sesh. oh well, its worth it to have what has to be one of few sheet metal pans on a cummins.
72 K20 12v build
Old 07-04-2014, 07:57 PM   #989
ryanroo
ryanroo's Avatar
Re: 72 k20 project
some 4th of july fiddling around!
you see the notch, looks silly, but its there for a reason.
this is the tie rod. it clears at ride height, but needs to have some room at dump. its almost even with the second main cap centerline. so i made the notch as big as i could. fingers crossed. haha. i'll add a drain to the front area so i dont have to worry about the old oil tainting my fresh oil changes.
some other pictures
72 K20 12v build
Old 07-05-2014, 04:44 AM   #990
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 72 k20 project
that sure is perty ... lol
Rich
1972 K5 Blazer CST Click HERE
Old 07-05-2014, 11:29 AM   #991
6lcummins
Re: 72 k20 project
Looks good Ryan
"STOCK"
ASSEMBLY THREAD
Old 07-05-2014, 01:16 PM   #992
Mustard72
Mustard72's Avatar
Re: 72 k20 project
Have you considered custom making the tie-rod with a bend to clear the pan?
Nick
Old 07-05-2014, 05:46 PM   #993
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks! i have been eyeballing fabbed aluminum pans for years. never really built anything that remotely deserved one(but i think the jeep is due in for some hotrod stuff, so maybe ill use one on it!) so i was excited that i had a reasonable excuse to build this. way to racy for this truck, but why not!?
Looks good Ryan
Thanks Nick! should i put on on order for you? i need some turbos....
the tie rod was ordered from ORD custom already. meaning that the "normal" one already has a bend. in my little bubble of pseudo-reality, bends dont belong in steering. this is a rule i am willing to bend in the right circumstance. this just didnt qualify. due to the location constraints, bending the tie rod would put it in the panhard pretty hard. any mods to the panhard(this is another no bend piece in my opinion) would put it in the diff cover pretty fierce. this stuff is all very space sensitive. so, a bend would not solve much for me. and trust me, it was on the plate for a brief moment.
72 K20 12v build
Old 07-06-2014, 12:37 AM   #994
mx289
mx289's Avatar
Re: 72 k20 project
Ryan,that oil pan looks Baja 1000 ready !
Very nice.I like alot.
You could charge alot of Pesos for one of them.
(Or a Cummins swap kit...Just sayin.)
How's your bodywork/paint going ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 07-06-2014, 12:54 AM   #995
6lcummins
Re: 72 k20 project
Maybe on the next build.... What turbos are you needing? Similar to my setup I have in the works??? 84mm Primary...
"STOCK"
ASSEMBLY THREAD
Old 07-06-2014, 10:04 AM   #996
84chevyguyid
Re: 72 k20 project
Browsing craigslist and came across this.
http://boise.craigslist.org/cto/4554318580.html
84chevyguyid is offline   Reply With Quote
Old 07-06-2014, 11:00 AM   #997
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks! i'd like to sell a few of them to generate some fun money, but dang, they are some work. in the next few weeks, i hope to start producing billet tappet covers too. that should sell pretty good. if i can sell just the pan flanges, id be extra happy.
paint and body? who knows. i've been busy enough lately that i havent stopped to see. i have noticed a lot of work has happened on his dirt track car in the recent weeks, so i hope he is short on cash and long on time now that it is running. that should motiviate him to call me and say he needs money. downside is, i have to pay him.... haha
i took some time to get this ready for him. needed a bunch of paint stripped and then i did some filler work and painted the underside.
i dont even know what i'm doing after this truck. i keep thinking about an overhaul on the Jeep. it would run hard with a nice little rec port headed twin turbo 454 in it... haha. or a rowdy set of twins for the 12 valve i build next. since i found this that i kind of want to buy.
that is a clean truck! but there are several design issues i would dock him points on. and if its worth 40k with a 383 and all those stock parts, i can only think that mine would be worth 75k what with all the custom stuff. i kind of want to email him a link to this thread and burst his bubble. you arent the only one! and my front geometry isnt nearly as sketch. and whats with the fuel cell in the back?
72 K20 12v build
Old 07-06-2014, 11:05 AM   #998
Dieselwrencher
Re: 72 k20 project
You didn't go buy it? Send him your link. It'd be interesting if you even got a response.
Ryan
Old 07-06-2014, 11:29 AM   #999
ryanroo
ryanroo's Avatar
Re: 72 k20 project
not yet! its eating me alive though. i need to buy some parts or something. usually when i get that buy a new rig itch, all i need to do is blow some money on some parts or something and it goes away... i would send him the link, but that is trolling at its finest. i try not to be a troll...
72 K20 12v build
Old 07-06-2014, 08:01 PM   #1000
ryanroo
ryanroo's Avatar
Re: 72 k20 project
todays fun.
72 K20 12v build
