04-15-2016, 02:30 PM | #976 | |
Re: Rat repair.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
04-18-2016, 10:19 AM | #977 |
Re: Rat repair.
Good choice I'm pretty sure you got the brightest ones from your list. We use the T8 4100K (cooler the temp longer they last?) cause they were the best deal and I needed about a bazillion of them!
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
04-19-2016, 05:13 PM | #978 |
Re: Rat repair.
So i don't mind saying that i feel like the blind leading the blind here, I keep hearing don't sand blast because it can warp the panels, i know this is true on big surfaces like hoods and bed sides, roofs ect.
I'm looking at my front fender, the inside of it, it looks impossible to hand sand little lone even paint inside the horn and behind supports ect, i did take a brush with my rust treatment ( link below) and brushed it on all the looks and cranny's, down in the horn ect, there was some surface rust but no cancer needing to be cut out. http://www.gemrustkiller.com/ I have Black Diamond Med coal slag blast media. http://www.tractorsupply.com/tsc/pro...s?cm_vc=-10005 I still have yet to do anything to the inside of the fender, don't know if i should blast the whole fender? Or just blast the inside where i can't sand? Or should i just clean it up with my bantam motor and coat it with POR15? I know i cannot get into the horn with my paint gun.. Wondering how to approach the inside of the fender without opening up too much of a can of worms? We have had 3 day record breaking temperature, you would think i would have gotten a lot done but too much on the plate...... At least i have lights in the booth now.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
04-20-2016, 10:43 AM | #979 |
Re: Rat repair.
IMO it really depends on the project as to whether you blast or not. New thin metal with no issues that only has factory paint of course you would scuff and shoot. 45+ year old truck where you can't get everywhere you do your best and hope it's good enough. Someone who knows what they are doing can blast panels with the appropriate media keep the heat down and do a really nice job. We'd blast the smaller stuff at home and send the big stuff out. I'd also ask around to find out who the body shops are using for that kind of work.
We have a guy here who runs a body/restoration shop they had a need and bought the equipment. In the beginning it was mainly just for his body shop but grew to a point that they will do just the blast work. Pretty sure that's where we will take the K30 cab whether they paint it or not. As to the inside of your fender I'd clean it as best you can and seal with your product of choice. When we did the rear quarters on our 66 SS Impala I had my buddy POR15 everything he could get to before installing the panels. Car is now gone but for over 10 years we never saw any issues with the body work.
Brett 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 Last edited by 7dee2; 04-20-2016 at 10:49 AM. |
04-23-2016, 03:59 PM | #980 |
Re: Rat repair.
Question for those who have used H/F spray guns, after reading the instructions i made a wrench and removed the tip of the gun and found what i thought was white paint, the rest of the gun has no trace of paint just a few very light scratches in the anodize so i continued to remove the needle and it has a light clear grease looking substance on it, looking closer i think the white stuff may be a latex or silicone caulk.
If you used a H/F gun did you also have this white stuff? should i completely remove it or leave it, i would hate to think i have to leave it to keep the thing from leaking..
04-23-2016, 04:38 PM | #981 |
Re: Rat repair.
Yes and yes I would and did remove that stuff.
Check out (suffer through ) this Youtube video http://www.bing.com/videos/search?q=...81A4&FORM=VIRE I did use some Teflon tape that had to be redone every time I took the gun apart for cleaning.
04-23-2016, 05:57 PM | #982 |
Re: Rat repair.
Same here. The white stuff is Teflon paste you can use to seal threads in lieu of the tape. A bit messier, but no strings attached. I cleaned mine and didn't replace the sealant and never had a problem, but using the tape is extra insurance. Always a good idea to thoroughly disassemble and wash a new gun to remove any potential contaminants and check that all the little seals and gaskets are in place. After reassembly, I put some wash thinner in the gun and adjust the pressure and fluid pattern to get it close before mixing paint.
04-23-2016, 07:34 PM | #983 |
Re: Rat repair.
Thanks guys! I assume paint thinner or mineral spirits are good enough to clean the gun, i have never done anything but rattle cans or house paint with brush and roller.
04-25-2016, 10:32 PM | #984 |
Re: Rat repair.
Most autobody supply houses stock a generic "wash thinner" that's a recycled grade of lacquer thinner. You can usually buy it in either one or five gallon cans. Lot less expensive than the thinners / reducers used for mixing paint. I prefer to at least partially disassemble a gun after a spray job. By that I mean pull apart the fluid nozzle and tip, the air cap and break apart the joint where the cup attaches. I have several small brushes I use to scrub the fluid passageways. After cleaning the components with the wash thinner and brushes, blow dry with compressed air and reassemble. The last thing I do is put a small amount of fresh wash thinner in and spray it out to make sure the gun is adjusted and ready for use. Just make sure all the wash thinner is out before loading the next batch of primer or paint. Even a small amount of lacquer thinner can cause some paints to clabber up and become unusable.
04-26-2016, 12:48 AM | #985 | |
Re: Rat repair.
And the latest holdup, been a little depressed, spent weds-fri with my left arm in a sling, something in my shoulder went rip, have an appt at the orthopedic place this Wednesday to evaluate, they will probably send me to get an MRI to see if it needs surgery, if they recommend it I'll do it, if not I won't but I think it's tendon. Still using it carefully and working but it don't feel too good when moved certain ways. I got to say sometimes I wish I didn't spend the 15 some odd years racing dirt bikes and all the other crap I did when I was younger cause I'm surely paying for it now, seems like every time I get on a roll with the truck something happens. Oh, it's been raining a lot outside, I may have to go buy a 10 X 10 to sand my parts under
04-26-2016, 11:48 AM | #986 |
Re: Rat repair.
Yep, just make sure the wash thinner is out before reloading the gun with the good stuff.
05-02-2016, 03:30 PM | #987 |
Re: Rat repair.
Any real need to sand beyond the original paint or the primer that was used before my truck and was repainted?
05-02-2016, 08:30 PM | #988 |
Re: Rat repair.
Ok darned it all, i let my shoulder heal until i could hardly feel it anymore when moving it, so i decided to give it a go today, started sanding but i decided i needed to blast a couple places with my speed blaster so i got it out, then i needed to get my 5 gal bucket of sand off the shelf, so as careful as i could with both arms i picked up the bucket and started to make the turn to put it on my work table, and rippppp! ripped my left shoulder again! I have an MRI scheduled for tomorrow morning.
Anyway i was pissed enough to continue so I blasted a few places i couldn't sand and a couple places with surface rust, Then welded 3 holes that were drilled for the old running boards, called it a day cleaned up and sitting here with an ice pack on the shoulder again. Didn't take another picture but almost all the paint has been sanded off.
05-02-2016, 08:40 PM | #989 |
Re: Rat repair.
Dang just when the weather is good. Heal quick!
Been w/o a workable shoulder a few times, feel your pain. MRI ugh. now don't move!
"I feel the need for speed!"... as soon as I am done with my nap. |
05-03-2016, 10:20 AM | #990 |
Re: Rat repair.
Sorry to hear Mike my oldest boy has had a lot of shoulder trouble over the years hoping you heal quickly.
05-03-2016, 02:29 PM | #991 | ||
Still Learning
Re: Rat repair.
It's up to you on how far to take the old paint off on your project. I prefer to sand it down to bare metal. That way I know exactly what is under my primer and paint. It's more time consuming and uses more sandpaper but it's worth in my opinion. I used that same cheapy HF paint gun to do a bunch of primer on mine. Watch the videos on yourtube. Those were a good help |
05-06-2016, 12:21 AM | #992 |
Re: Rat repair.
I left the fender in the booth for about 2 days, checked it with the inferred thermometer today about 10:30, it was 65 on one end and 63 on the other, i rigged up a sheet of plastic and draped it over a couple stand alone heaters about 2-3 ft from the intake filters and fired them up, the temp on the fender went up to 75 on one end and 73 on the other in about 30 minutes, long as it doesn't go over 75 i have the heat situated.
Moisture on the other hand, had to back up and do a bit of re rigging today and cleaned out one of my water traps that is collecting a good amount of rust from my pipe manifold, I can see now how some good copper piping would be a benefit but hoping to get by for now, still have about 100' of air hose after the dual water traps, then added an in line air dryer, then another 50' of hose to the gun, tomorrow i need to drain the tank. Still taking it easy as much as i can but every time i turn around i end up yanking my shoulder, Dr appt with a surgeon this coming Wednesday to discuss the MRI.
05-06-2016, 12:27 AM | #993 |
Re: Rat repair.
Jerry rigging at its finest, the pic is sideways, sorry. Oh yea it's cramped in there! Wonder about hanging the fender grill side up? May try it but not sure how well the 2x2's will support the weight of the fender.
05-14-2016, 05:12 PM | #994 |
Re: Rat repair.
So a little update, I have come to Hate Franciscan healthcare!
Origional injury was 4-20, i get a referal to see the orthopedic place on 4-25, i call and make an appt, they always first have you see a nurse practitioner, able to get in 4-27, she sends an order for an MRI, MRI appt on 5-3, on 5-4 the MRI has been reviewed by the actual Ortho Dr. the next day, they call and schedule an appt on 5-11, I get there and review the MRI with the DR. her says he wants to refer me to a better Ortho surgeon.... That appt is 5-23...... So this Dr that i did see is a good Dr but not a shoulder specialist, why did they refer me to him in the first place? Then why after he reviewed the MRI did he have me schedule an appt with him? why not just refer me on to the next DR?? Guess he needed to make his BMW payment or something.. ??? So this is how things go with Franciscan, i could have called and made my own appt with a specialist at a different place that i usually go for anything else, i regret i didn't do so, but i do hear the DR i am going to see is suppose to be really good with shoulders so hopefully things will work out. Diagnosis: Severed Bicep tendon, torn but not severed rotator cup tendons, arthritis in the shoulder joint, bone spurs. I hate getting old LOL! Anyway i have been healing slowly, i did re injure the thing 4 times total since the original tear but i think i am over that hurdle now. I can move it every way except when my arm is straight out i cant raise it above my shoulder without pain, able to pick up some weight but i'm not going to try and find out how much.... If there is any paint guys out there i'm trying to figure something out. The paint supply place says i have 2 choices for a Single Stage paint in the 518 Med Green color code, altho they say its now called Meadow Green. One is a DCC that is a Urethane base, the other is Delstar that is an acrilic Enamel base, my main goal is to paint the inner kick panels, floor after repair, the door jambs and the inner part of the front fender at the top where you see the color. They said whatever i choose the rest of the truck will have to be painted with the same paint... Which paint should i choose? does it matter? I am assuming the stock color is Single Stage. Planning on doing some primer tomorrow, finally.
05-15-2016, 12:43 PM | #995 | |
Re: Rat repair.
As for the paint, there are several options. Most modern cars are shot with a basecoat/clearcoat system. The base is typically a urethane that uses either water or a conventional reducer to thin it to the consistency needed for spraying. It is unable to resist weathering, so it must be topcoated with a catalyzed urethane clear. Thus the designation BC/CC. This is the most expensive approach as it requires the most materials. For what is called a single stage paint, you can choose between acrylic urethane or acrylic enamel. Both can be sprayed without a catalyst, but the cure time is much longer and the finish much softer than with a catalyst. The urethane is typically a little tougher and longer lasting, but also more expensive. These finishes can be repaired and even buffed if they are catalyzed, but I don't recommend it. A properly applied single stage paint can have a very nice gloss without a lot of orange peel. An improperly applied single stage can wrinkle, run, attract dust nibs from 50 feet away and in general, look like crap... and then be nearly impossible to fix. That said, there is no reason you couldn't shoot a single stage paint on the kick panels, floors and etc. It would save some money and labor. Depending on how you mask the door jambs, a catalyzed acrylic urethane won't react negatively where it butts up or slightly overlaps a BC/CC. But if you want to be 100% safe, do like the paint store says and stick with one system. And we'll need pictures, of course!
05-15-2016, 02:35 PM | #996 |
Re: Rat repair.
I used to use arylic enamal, ditzler, acme, dupont, nathan single stage years ago. I like single stage paint.
Do they even still make acrylic enamal anymore? Im in Calif right now and you cant get it here. All ive seen is the single stage urathane.
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting |
05-16-2016, 12:10 AM | #997 |
Re: Rat repair.
MY garage smells like paint thinner....
Tried to think the whole process thru before i started, it is cramped in there and no matter how i set it up getting both ends is near impossible. Also I couldn't find my old safety glasses so had to use non prescription, not being able to see clearly didn't help me that much. First pic, after painting i noted the gun tip seems to be spraying uneven? all the passageways were clear when i pre cleaned and inspected a few weeks back.. Pattern was a fat football shap. I seemed to have a problem getting the paint to flow as much as i wanted, i was able to increase the flow a little but felt it needed more than i could adjust, I contemplated stopping and re reading the gun manual but opted to continue, hopefully that was not a mistake. I tried hanging the part and put a swivel on it, it helped to be able to access the whole fender but it was a pain to have to keep a finger on it to keep it from spinning. Will need to coat it again, think i'll probably have it horazontal and do one side at a time next.
05-16-2016, 09:44 PM | #998 |
Re: Rat repair.
Regrouped for round 2, paint flowed much better, abandoned the hanging approach for one side at a time, looks like I have a little dust issue or cold this possibly be paint splatter? Doing one side I miss judged on the amount of paint to mix so had to make another smaller batch to finish.
05-16-2016, 09:45 PM | #999 |
Re: Rat repair.
Another
05-16-2016, 09:48 PM | #1000 |
Re: Rat repair.
One more, got to figure out how to keep this from happening. Will do a final coat on the inside tomorrow.
