#1001 |
Daring to be Different
Re: 198Plus build
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#1002 |
Re: 198Plus build
Sure hope you decide to build this truck. Even if its not the correct cab, maybe build it in your dads memory (forgive me if I am wrong, but wasn't this his truck?) I know it's not the same but think what he'd do in your situation.
Posted via Mobile Device |
#1003 |
1961 crewcab
Re: 198Plus build
ronnie-
something you might look into. if your vin plate was swapped to another cab, there should be paint under the vin plate. gm riveted them on after paint. if there is primer, or any other color paint under there besides the original color of your dads truck you might be able to prove that it was not your cab, and at most, if anything put a negative spotlight on the body shop you suspect did the swap, if they did it on yours, they probably do it often, and it would be nice to see them go down, even if you can't get your dads truck back. I would let the authorities know and have one present when you remove the tag, to cover you self.. might be more trouble than it is worth, I guess it dependes on how pissed you are ![]()
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#1004 |
Re: 198Plus build
Go get them Ronnie.
#1005 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 198Plus build
I've been thinking the same thing. I would go after the suspects.......
![]() Quote:
#1006 |
Re: 198Plus build
All right guys I going to attempt to finish my truck with out any help from the guys at the shop........Should be very entertaining.....lol..... I think Alan is going to try to help walk me though this process and I hope I can get everyone's help in trying to finish my truck.
Alan I clamped the a post back to where you cut it, looks like to me the Cross brace of the floor got bent upwards while transporting.....correct me if I'm wrong. ![]() ![]() ![]()
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#1007 |
Re: 198Plus build
Here's my new project, like I need another one.......
![]() 1972 Chevelle 454...4 speed. ![]() ![]()
#1008 |
1 thing at a time is progress.
Re: 198Plus build
Ronnie, you know a consulting fee is very expensive.
![]() Take the inner rocker piece out and see if the piece I cut off the A post will line up where it is suppose to on the cab support. The gap on the A post cut should be the width of a cut off wheel, about a 1/16". Once that is determined to be correct then put the inner back in and start fitting.
Alan
Philippians 2:14-16 |
#1009 | |
Re: 198Plus build
Just send me the bill
![]() Alan it is kicked out I was just trying to give you an idea, I will take some pics tomorrow of it with the inner rocker out of the way. Quote:
#1010 |
Re: 198Plus build
My first attempt at repairing panels on my truck..........Tonight I cut out the inner rockers and part of the floor pan....... New parts seem to fit good, I hope
#1011 |
VA72C10
![]() Join Date: Mar 2008
Re: 198Plus build
looks like a good fit. Keep at it!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1012 |
60-66 Nut
Re: 198Plus build
Looks good
![]() I'm glad to see you haven't given up and are working on it. ![]()
#1013 |
Re: 198Plus build
I worked on the A posts today, trying to fit them before installing kick panels.
#1014 |
Re: 198Plus build
Looks kind of funny here. I'm not sure what is going on. Maybe it looks funny because the kick panel is missing.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 10-15-2010 at 10:45 PM. |
#1015 |
Re: 198Plus build
Some progress this evening finally, inner rocker's zipped up.
#1016 |
60-66 Nut
Re: 198Plus build
Looks good!
Keep goin' ![]()
#1017 |
Re: 198Plus build
Alan here's the pics..........
#1018 |
SSN 706
Re: 198Plus build
Well?
#1019 |
Member of the longbed union.
Re: 198Plus build
I think you should cut the floorboard out and flint stone it.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#1020 |
Re: 198Plus build
Ronnie, looking at the pics it's hard to tell from here what is actually going on. Either the door is bowed out in the middle or the rocker is sucked in in the middle. The gap looks about right, but to me there is still some checking to be done. To give a better answer it would be better to see it in person. Basically from the pics your close, but not close enough. If you are unhappy with anything about the fit, now is the time to fix it.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 11-05-2010 at 08:48 PM. |
#1021 |
SSN 706
Re: 198Plus build
Maybe you can lend him your electron microscope.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 11-05-2010 at 09:12 PM. |
#1022 |
Re: 198Plus build
DAve, those doors came off of my truck. They are in pretty good shape, although they do need some rust repair and some dents fixed. It doesn't take much of a bow to create a bad body line. While repairing the rust in the bottom of the door it can be straightened out.
Alan
#1023 | |
Re: 198Plus build
What time tomorrow will you be down at my shop..........
![]() Quote:
#1024 |
Re: 198Plus build
Getting ready to take it to the crusher, sounds like a better option
#1025 |
Re: 198Plus build
I don't think it's the door or the rocker, it's the dumbass that's working on it........Lmao
