09-23-2016, 06:01 PM | #1001 |
Re: Dutch '59 Fleetside Longbed
See the nut and bolt but not the others.
Kim |
09-23-2016, 06:09 PM | #1002 |
Thanks Kim.
I'll try again in the morning
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
09-23-2016, 07:18 PM | #1003 |
I still can't see them.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
09-23-2016, 10:00 PM | #1004 |
A320 Pilot/USAF Retired
Nope!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
09-24-2016, 05:24 PM | #1005 |
Okay, lets try again....
The driveshaft in pics:
09-24-2016, 05:31 PM | #1006 |
I've checked it on my iPad, there it's visible.
I think that problem is solved Then I had the cable for the carb. GM bracket modified to take the throttle cable and the TV cable: Turned the pin for the TV cable: And bolted that pin at the right place at the carb. You can't connect the TV cable just somewhere on the carb lever, this has to be at the right place to work properly.
09-24-2016, 05:42 PM | #1007 |
As you go from a TH400 to a TH700R4 you have a longer "reach" in the shifter rod.
I have a mid '70s Chevy Van column, with column shift for a 3 gear automatic. So the gear indicator is no good anymore... I bought a second hand indicator from a newer Chevy Van, I thought it would fit. But unfortunatly it doesn't. I looked at the internet for an old style indicator, but I couldn't find one. As I am a bit handy, especially when it's for my own , I changed the one I had. Polished the old letters off, made a cardboard template and took the new shift pattern over on the cardboard. Then took it over on paper and painted it on the original indicator This is the difference: Polished off the letters: It's painted on the backside. Paint is still wet, so I will mount it tomorrow and let you see the finished product then
09-24-2016, 11:02 PM | #1008 |
Hey Kees, on my home PC I still DON'T see any pics...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-25-2016, 09:56 AM | #1009 |
They were there yesterday, but not today!!
09-25-2016, 10:10 AM | #1010 |
Still see nothing.
Sounds like you're making good progress though. Kim |
09-26-2016, 08:38 AM | #1011 |
Well it all sounds good.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
09-29-2016, 02:18 PM | #1012 |
Yes it sounds good
But you want to see some things, I know.... I still see the pics on my computer, on my iPad I saw it for two days and then they were gone. I'm working on it. Now I will try to post some as an attachment, see if that works. The driveshaft: (I see they're on their side..)
09-29-2016, 02:20 PM | #1013 |
The end result of the driveshaft:
09-29-2016, 02:21 PM | #1014 |
Then I had the cables on the carb:
09-29-2016, 02:31 PM | #1015 |
At last the pics for the gear indicator, then you have all the pics I wanted to show.
Insert pics via url works way better for me, so I will try to get that going again. In the meantime I upload them as attachment. Hope you can see them now? Let me know
09-29-2016, 02:52 PM | #1016 |
looks good great work
09-29-2016, 02:56 PM | #1017 |
In see pics.
Looks good. Some of mine were on there side when i used my phone to take them. Kim |
09-29-2016, 08:24 PM | #1018 |
Hey Kees, I'm seeing the pics, nice job on drive shaft and indicator...Jim
09-29-2016, 09:52 PM | #1019 |
I agree with Jim..good work Kees!
09-29-2016, 11:20 PM | #1020 |
Nice work!
09-30-2016, 08:10 AM | #1021 |
It all Looks good now. Nice job on the gear selector.
09-30-2016, 09:36 AM | #1022 |
Good to see the old girl with some more progress.
Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
10-06-2016, 10:10 AM | #1023 |
Kees! --- wow I thought you were done.... lol These things are never ending my friend... good to see you working on it all the time.
My Build: 57 Chevy Pro-Street |
11-07-2016, 04:32 PM | #1024 |
I'm Back!
Did suffer some body problems, but in the meantime I did some small stuff. Insulated the roof and put a thin wood panel as headliner. I want to put some licenseplates there. Also went to Rockin' Jalopy here in the Netherlands. This is an indoor Hot Rod Show. Went with the truck, it's a 150 mile roundtrip., the first longer drive Picked up a friend on the way and had a great time!! The truck did great! Lots of thumps up, photos taken along the way, even somebody was filming while driving I'm really happy with the TH700R4 trans. Hooked up the lock-up, it now runs 1600 rpm @ 60mph, not bad! (I use a temporary GPS hub for speed now.) I can use the lock-up in 2, 3 and OD. It's manually switched and when I brake, the lock-up switch off. The trans was equipped with an electronic drive for the speedometer, I want to use the original speedo, so have to change to a mechanical one. A friend gave me the parts to build this, but he didn't have the drive gears I needed. I found the drive gear for in the trans, but the driven gear was a problem. So I ordered a 40T driven gear for the trans after a few emails back and forth. Got the package last Saturday, but the good man put in a 41T gear... So I emailed the good man (it's in the USA...) Today I got an email back with apologies and he said he already sent a new one out!! A 40 tooth, free of charge! That's what I call Service!! Don't know if I may say his name here, but I think he's well known. Hope to have the new 40 tooth driven gear next week, so I can finally use the original speedometer I will post some pics of the show next time.
11-07-2016, 08:19 PM | #1025 |
thats awesome Kees glad the truck did really well on the trip.
Mark...
