Old 01-08-2015, 09:49 AM   #1026
ratty 46
Re: Shrunken66Stroker's build thread.
I couldn't find my Machinist Handbook ... but found this right from Lincoln Welding for you:
http://www.lincolnelectric.com/en-us...al-detail.aspx
R46
ratty 46 is offline   Reply With Quote
Old 01-09-2015, 09:49 PM   #1027
shrunken66stroker
shrunken66stroker's Avatar
R46
Thanks 46. The 309 worked in my tests. I welded the part of the steering shaft that I cut off (mild steel) to the extra double d shaft (stainless) and it worked great. I held off welding the U-joint to the steering shaft because I ordered new upper and lower steering column bearings and it will be easier to have the steering shaft loose while I'm working on the column. I also blasted the rust off of the steering shaft in my cabinet. The bearings were toast.
shrunken66stroker is offline   Reply With Quote
Old 01-09-2015, 09:57 PM   #1028
shrunken66stroker
Since I held off on welding the u-joint to the shaft I decided to fill the holes from the steering shaft mock up and the extra engine mount holes from the factory. Cleaned it up quite a bit.
Old 01-09-2015, 11:12 PM   #1029
jlsanborn
jlsanborn's Avatar
Slick!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-12-2015, 06:24 PM   #1030
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Dude you have some mad skills......Your crazy...But you have mad skills...lol
I dig the outa the box approach you take for stuff. I never even considered running my steering linkage like that for my LSA build.....wicked idea good on ya
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 01-12-2015, 07:59 PM   #1031
ratty 46
I forgot to mention that I was impressed with the way you handled the steering shaft through the top frame section. Most would have been stymied with the possible resolution ... Nicely done.
R46
Old 01-12-2015, 09:11 PM   #1032
shrunken66stroker
Originally Posted by jlsanborn View Post
Slick!
Thanks Wutnxt. You have some sick projects too. Great stuff. Where can I find the LSA build?
Thanks Ratty!
R46
Old 01-12-2015, 11:17 PM   #1033
wutnxt
Thats my low and go tp://67-72chevytrucks.com/vboard/s....php?p=5799909
I have been too busy to do much lately but i have moved it back into the shop and am getting ready to make up a parts list . It's time i get back on this project...infact I was just about to order a new steering coloum
You have such creative fixes for common problems it's impressive...It's nice to see you back on this project.
Old 01-13-2015, 02:16 PM   #1034
shrunken66stroker
Thanks. I also shortened my steering column a while back. I took 3" out to give me a little more space, so I won't have to spend money on an aftermarket column. Next up is the pedal assembly. I bought it a few days ago and it should be here soon. I'm going to knock out the floor to give me a little more leg room. Should be fun.
Old 01-16-2015, 12:18 AM   #1035
semihippie
Hey man, I know you're busy and everything but if you have anytime I'd love to come hang out in your garage. I still don't have a truck of my own to build but it's always a learning experience just watching someone work. I know very little about fabrication or welding but if I can help in anyway at all even if it's just holding something in place or moving something, I'd be happy to.
semihippie is offline   Reply With Quote
Old 01-16-2015, 03:31 PM   #1036
7wolf
just finished reading, such a good job fabbing everything. any more updates? looks sweet so far.
7wolf is offline   Reply With Quote
Old 01-17-2015, 09:35 PM   #1037
shrunken66stroker
Thanks! I may just take you up on that. I work sporadically, as you can tell from my thread, but I'll keep your offer in mind.
Soon, soon, soon, I hope.
Old 01-17-2015, 09:54 PM   #1038
shrunken66stroker
So, just tying up loose ends from a while back. I welded a few threaded couplers together to get the sway bar to clear the steering linkage. I had to make them a little higher to make sure they cleared lock to lock, bags all the way up and all the way down.
Old 01-18-2015, 10:58 AM   #1039
chevyrestoguy
chevyrestoguy's Avatar
I love your work, man. Excellent fab skills, and you aren't afraid to tackle anything. I look forward to your updates!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-21-2015, 02:05 PM   #1040
shrunken66stroker
I got some parts in the mail yesterday. The steering column bearings came in, but you guys probably don't need a pic of those! Here's the the exciting stuff. It's a Holley mid-rise efi intake. I'm going to go through all of my parts and see what I have and what's missing to build this engine asap. It will be a few months till the time and money come together but I've got plenty to do till then.
Old 01-21-2015, 03:42 PM   #1041
SCOTI
SCOTI's Avatar
That intake will definitely fill the void left from the 'better looking' LS1/2/3 intakes while much more pleasing to the eye vs the truck units.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-21-2015, 07:36 PM   #1042
shrunken66stroker
Yeah, it's a lot about looks and making the engine compartment not look empty. It's also ideal for power between 2000-6600, which exactly matches my cam. Should be a great combo for the street.
Old 01-22-2015, 10:58 AM   #1043
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-22-2015, 11:51 AM   #1044
Shifty One
Shifty One's Avatar
Your build is like "fabrication Viagra" Sir!
Old 01-23-2015, 09:01 PM   #1045
wutnxt
LS's are pounders and a cam upgrade makes them go crazy...your going to have tons of power.....it's looking good man. Your making me wanna work on some of mine own stuff...You do great work
Old 01-28-2015, 02:09 AM   #1046
shrunken66stroker
Looking forward to that power. Thanks, wut. Get back on that low and go.
Got a wheel for the right price that I think might work. I also started the mock up on the headers.
Old 02-01-2015, 10:40 PM   #1047
Strodder
Daring to be Different
Strodder's Avatar
Looking good
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 02-04-2015, 11:41 AM   #1048
Hammered 77
Hammered 77's Avatar
What brand is the steering wheel?
Hammered 77 is offline   Reply With Quote
Old 02-06-2015, 01:25 PM   #1049
shrunken66stroker
Forever Sharp- https://fssteeringwheels.com
Seems to be pretty good quality and great prices compared to some other half wrap wheels I've seen.
Old 02-18-2015, 04:10 PM   #1050
Strodder
Strodder's Avatar
I have this wood one for mine. Just have to buy the adapter & horn kit.
Side note: Don't buy a wood one with the rivets. They are just stickers and can peel off. Unless they are covered with thicker clear coat.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
1966, bagged, disc, long to short, stroker
