Old 12-08-2020, 12:07 PM   #1026
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Custom Gas Filler Venting
I ended up welding a 1/2" SS NPT fitting on my filler cap. 1/2" hose will connect to tank vent. This way my vent is sealed in case of a rollover. Still have my rollover vent too venting to atmosphere for heat expansion/etc.
Still need to clean up the welds but you get the idea. Gas pump nozzle will go past my vent in cap so it should vent properly eliminating slow fills and burps. I should be able to finish install this weekend, waiting on one last part for tubing/hose.
Far right is 1/2" vent line.
Middle is the Filler hose.
Far left is my rollover vent hose. This probably doesn't need to be ran all the way up to filler, I will most likely shorten this hose and mount to bed rail. Also need to switch this to fuel line instead of vacuum line.
FYI: mock-up stage.
Using 21 Gallon 67-72 Burb Tank.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 12-08-2020, 07:18 PM   #1027
SkidmoreGarage
Re: TA_C10: Stage 1
Looks good, I'll take one too! Did you buy a kit to start with for the sheet metal bracket? If you made it, do you happen to have the template? I really like the whole setup.
I will be starting this soon. I just finished up a big order on my project for the driveline. While I wait, I plan to install my Boyd's tank.
SkidmoreGarage is offline   Reply With Quote
Old 12-08-2020, 08:59 PM   #1028
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks man. I saw the gas filler panel online somewhere, it was being sold for like $150 or $200 maybe. It was too much. So I built mine from scratch. I posted about it a couple pages back in my thread. It was about a days worth of work and some scrap sheet I had lying around. Used washers for the mounting tabs. Originally I wanted to run it up the rear stake pocket and fill from top of bed but then I realized from others guys it wasn't very easy to fill there, and I also wanted a tonneau cover that seals good. This design i liked best.
"It's only money".
Old 12-13-2020, 11:23 AM   #1029
First c10
First c10's Avatar
Re: TA_C10: Stage 1
Looking good. The filler set up looks familiar. Keep it up.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 12-14-2020, 10:23 AM   #1030
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: TA_C10: Stage 1
It's just my opinion but I think some of the guys get too wrapped up in these roll-over vents. Don't get me wrong, they're a good idea, but my truck is not a daily driver. It's a nice weather weekend driver. As such, I decided to go with just a venting system. I'm not looking to start a whole discussion on roll-over vents. This was just my decision not to use one.
If you look at the Rick's Tank in the picture, you'll see two vent locations. I was told to tie both of those together into a section of fuel hose and coil it up near the bottom of the bed, or on top of the tank. Rick's also said if I wanted to use just one of the connections I could try it to see if it works alright. I plugged the one connection and installed a barbed fitting on the other. I ran my vent line up inside the passenger side bed wheel well where it is concealed and protected. It is higher then the fill connection, which is what I wanted.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 12-14-2020, 09:19 PM   #1031
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
I was told same thing, but the more I look at how the factory engineers design these today and have been doing for long time I figured this wasn't something I shouldn't take lightly. If you get into a crash, you wouldn't want fuel spilling out on ground especially if the cab is downhill of tank and fuel is running towards you, then something ignites that fuel while your trapped inside.
That's my reasoning anyway. By putting the vent in the cap, the cap seals off the vent when driving. Then the rollover vent (separate vent from fuel filler) allows heat expansion and etc during sitting and driving, but cuts off fuel during rollover. Plus it's tiny compared to the 1/2" vent inside fuel fill cap. 1/2" vent line would spill quite a bit of fuel out during a wreck pretty quickly.
I like this forum for everyone's opinion, whether I use that advice or not it's good to hear what everyone does so we can all make our own final decisions. No right or wrong, just what we do right?
"It's only money".
Old 12-14-2020, 10:08 PM   #1032
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
Well said (both of you).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-15-2020, 10:44 AM   #1033
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
Lots of good constructive feedback on here. TA-I like how you routed your vent line to the filler - that seems very factory and clean.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 12-15-2020, 06:35 PM   #1034
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Gas Filler Completed.
Well the vent works. Got it all connected, drive down to gas station first time ever, filled it full. Still playing with fasteners but it's pretty much done. I was able to fill tank full speed via gas pump nozzle. But I had to find the sweet spot to do so. Rollover vent is working too as I didn't have vapor lock driving around. Very happy.
I found this small lip seal on Amazon, used it to protect the filler line from sheet metal over time(rubbing).
Used one of the bed floor SS bolts to hold the floor side fastened. Looks good to me I may leave this.
The side fastener however is just a cheap washer and screw. I may install a rivnut in the sheet metal and use a SS bolt for final, we will see.
I had about a 1/4 tank when I got to pump. Filled her up(21 gallon tank), gauge reads full.
"It's only money".
Old 12-15-2020, 06:40 PM   #1035
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Bumpers!!!
Boom. Brothers Trucks Chrome bumpers. They still have the grease on them so they are a little blueish, but they installed well and look good IMO. The bumpers that came on this truck were the farm bumpers, got rid of those. They prob aren't as strong as factory style, but they will do for this ol heap...
Didn't realize I needed the rear bumper center box for license plate area, I am doing the flip down license plate to hide my trailer hitch so I gotta order that still.
"It's only money".
Old 12-15-2020, 06:53 PM   #1036
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Update - Seat belts, seat, speaker brackets
Ripped out the seat, installed my rear speaker brackets from brothers(painted to match), seat belts(re-using what came with truck), and finished up some wiring under seat.
I had pre-drilled the holes already last year when I was doing all the metal work. I drilled them in the factory locations, but the driver side was a little off for some reason. The hole is supposed to go through the floor pan, AND the cab support underneath for added seat belt pull-through protection. Factory welded the nuts underneath. I ended up just using nyloc lock nuts and huge thick washers for another layer of protection/support. All new grade 8 hardware used.
Driver side the hole ended up being just a little too close to the support so I had to bent the washer to fit. No big deal.
I finally pulled off that ugly cheap seat cover that I put on a couple years ago so the seat wouldn't get damaged in the garage over the years working on the truck. Glad I did cuz it still looks pretty decent.
I ended up mounting my seat belts towards the back of cab, this was the best method to keep the belts from touching during use. Plus, it keeps it out of the way, they are kinda ugly anyways.
"It's only money".
Old 12-15-2020, 07:59 PM   #1037
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
You're down to some finishing touches and the hood now! Very functional truck in a unique color. I have a set of the Brothers speaker enclosures on the way - do they feel pretty substantial?
Old 12-22-2020, 10:32 AM   #1038
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks man, I just returned from vacation and I'm ready to get that hood done. I managed to get the truck insured while I was away. Now I'm sitting at Firestone waiting to get it aligned and inspected. Then it's off to local paint supply for some glaze and body filler hardener. Few other supplies as well. Start bodyworking the hood this week and hopefully get her in paint.
"It's only money".
Old 12-22-2020, 10:40 AM   #1039
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
It has begun. And those front fenders will be getting a scuff n shoot along with the hood....
"It's only money".
Old 12-22-2020, 10:41 AM   #1040
SCOTI
SCOTI's Avatar
Re: TA_C10: Stage 1
The light @ the end of the tunnel!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-22-2020, 10:46 AM   #1041
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
We're looking forward to seeing some finished photos!
Old 12-22-2020, 11:03 AM   #1042
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Potter I forgot to mention, those speaker brackets are real solid once installed. I plan to slap some killmat on the backside when I get speakers to install. I have killmat and closed cell foam in the cab corners. Should do pretty good for sound I think.
"It's only money".
Old 12-22-2020, 11:14 AM   #1043
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
The order showed up but they sent brackets that are meant for squarebody's...
They look pretty substantial but like you said I was planning on sticking some sound deadening to them and maybe stuffing some foam in the corners.
Old 12-22-2020, 12:05 PM   #1044
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: TA_C10: Stage 1
Has to be exciting to take it out on the streets. I think your truck looks great and you will be late everywhere you go because people will want to stop and talk to you about it.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-22-2020, 01:13 PM   #1045
SkidmoreGarage
Re: TA_C10: Stage 1
You are really on the home stretch now! I'm sending good weather thoughts your way to make painting happen.
Old 12-22-2020, 01:54 PM   #1046
Kronald_70GMC
Kronald_70GMC's Avatar
Re: TA_C10: Stage 1
Everything is looking great man. Congrats!
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-24-2020, 12:36 PM   #1047
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Thanks, it really is exciting to drive it around. I have insurance but not inspected or registered yet so back of my mind a ticket still in my future. I just hope the cop is a car guy/gal if/when I do get pulled over LOL.
Thanks, I start working on hood today, hopefully it will be done with bodywork this weekend and ready for paint soon.
Thank you sir, and your truck as well!
"It's only money".
Old 12-24-2020, 12:50 PM   #1048
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Few updates and some future stuff going on.
I'm going to be trying something new. BrothersTrucks just came out with their flush mount license plate box. It raises the license plate to be flush with bumper rather than hang down 1 and 3/4" like stock. It's going to be tricky with plans to make it work with hidden hitch. Not designed for that. But I am determined to make it happen. I like the flush look and I had forgot to order my license box for bumper. It's the first commercially available flush mount box I have seen and brothers says it wasn't designed to work with it, so I am on a mission to prove them wrong Stay tuned.
https://www.brotherstrucks.com/1967-...tinfo/FLPB787/
And here is my thread on it as well in general section:
http://67-72chevytrucks.com/vboard/s...d.php?t=815808
Other update. Radio is installed and wired up. Thanks to 71StepSide I was ahead of the curve troubleshooting the source of the yellow wire(AAW harness, radio bat +) to clock fuse. Why they did that I dunno. They also only supplied a 10amp fuse for that circuit but if you use it for radio battery connection, you need to step that up to a 20 amp.
I have the retrosound radio, and decided to mount the microphone for phone calls. Well it clamps onto the little flat spot on tilt rod next to column like it was made for it. So then I just ran the wire underneath the "column to dash" rubber grommet and called it a day. It works great too, called the wife on it from garage
Another cool feature on that radio, if you turn the feature on, it syncs the clock automatically when you sync your phone via bluetooth. So you never have to set your clock manually on the radio.
Clock synced here as soon as I connected my phone to bluetooth.
Here is the microphone that comes with radio. I am in the middle of finishing up "buttoning up" all my dash harness wiring as well. It's a mess right now
Radio comes with male "bullet style" connectors, so I had purchased a kit of those already for other things and used just the female ends on the AAW harness connectors for radio connections. Worked really clean.
"It's only money".
Old 12-24-2020, 01:59 PM   #1049
MDPotter
MDPotter's Avatar
Re: TA_C10: Stage 1
I must have gotten lucky with my radio install - I didn't have any issues hooking it up to the AAW harness and making it work.
My microphone is just hanging under the dash...I don't know if it will be useful with the volume of the exhaust. It seems like the farther I press the pedal down, the louder it gets.
Old 12-28-2020, 11:49 PM   #1050
TA_C10
TA_C10's Avatar
Re: TA_C10: Stage 1
Yeah my flowmasters are a bit louder than I wanted for a DD, but I gotta tell ya the combination of heat and sound deadners I have inn the truck really work well. Even with the doors still wife open unfinished. Happy about that. But I will probably get a little more mellow mufflers down the road.
"It's only money".
