Old 10-28-2009, 03:04 PM   #1051
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Kinda slackenWaiting for my trans.
daverod is offline   Reply With Quote
Old 10-28-2009, 03:06 PM   #1052
daverod
SSN 706
daverod's Avatar
I got my spindles toay. Forgot to order the $75 bracket that holds the calipers. Thinking about just using new cailpers.With modular spindles your stock caipers won't mount on unless you buy a bracket. My old dust shields won't work ether. Don't know what to do there? Wonder if I even need them?
Old 10-29-2009, 12:41 PM   #1053
daverod
SSN 706
daverod's Avatar
Ordered my bracket. Took my rotors down to be ground, picked up new calipers, pads, and bearing. All this for $105. Guess they don't make dust shields for the modular spindles.
Old 10-29-2009, 10:15 PM   #1054
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Sorry Dave
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-29-2009, 10:40 PM   #1055
daverod
SSN 706
daverod's Avatar
Originally Posted by ruffrida2005 View Post
Sorry Dave
It's ok
This much I know.Pick up my rotors and calipers tomorrow. Don't get the brackets for a week. Need to save up so I can get new upper and lower control arms. I did get the track on my rmk. Need to get some bags and stuff for the front. Think two ply bags are Ok?
Old 10-29-2009, 10:42 PM   #1056
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
are you going to be low enough? i think you need to z the frame.
are you laying rocker?
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 10-29-2009, 10:43 PM   #1057
spudtruck
spudtruck's Avatar
Lookin' good!!! But how does that Polaris suspension fit into the spindles?
spudtruck is offline   Reply With Quote
Old 10-29-2009, 10:46 PM   #1058
Strodder
Daring to be Different
Strodder's Avatar
What size wheel are you going to use? You must know the height of the tire and wheel before you make your air bag cups. The angle on your ball joint could be too much, and it could fail. Be carefull.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 10-29-2009, 10:52 PM   #1059
daverod
SSN 706
daverod's Avatar
The frame belly is on the concrete.
Old 10-29-2009, 10:53 PM   #1060
daverod
SSN 706
daverod's Avatar
I think I want 20" or 22". How do you change the angle of the ball joint?
Old 10-29-2009, 10:55 PM   #1061
daverod
SSN 706
daverod's Avatar
When I get the suspension back where it belongs then I can spend more time on my spindles.
Old 10-29-2009, 10:58 PM   #1062
Strodder
Strodder's Avatar
New A arms. Or if you could put a wheel on it with the same height dimensions. That would help a lot to see how low you really need it. It might be laying frame with no wheels on it, but it's not an accurate way to check.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-29-2009, 11:02 PM   #1063
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
what do you mean by frame belly
Gage
Old 10-29-2009, 11:06 PM   #1064
daverod
SSN 706
daverod's Avatar
Belly!~belly
Old 10-29-2009, 11:09 PM   #1065
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
the crossmember
Gage
Old 10-29-2009, 11:10 PM   #1066
daverod
SSN 706
daverod's Avatar
So I'm not laying frame. And I need one 20" rim. Damnit.
Old 10-29-2009, 11:12 PM   #1067
daverod
SSN 706
daverod's Avatar
the crossmember
It touching.So's the frame.
Old 10-29-2009, 11:21 PM   #1068
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
dang thats going to be sweet
Gage
Old 10-29-2009, 11:36 PM   #1069
daverod
SSN 706
daverod's Avatar
I get my rotors tomorrow I'll put some wheels on then. Does the out side diameter of the tire change with the different rims?
Old 10-30-2009, 11:38 AM   #1070
Strodder
Strodder's Avatar
Put the tire size you want to use on the front, and take the diameter size and divide in in half, and take that measurement and measure from the spindle shaft to the ground. Do this with the frame on the ground.
Use this chart.
http://www.miata.net/garage/tirecalc.html
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-30-2009, 03:23 PM   #1071
daverod
SSN 706
daverod's Avatar
Right now I have 12" from the ground to the center of the spindle. So how about 155 30 20's that gives me 11.85". or 145 35 19's are 11.54"? Sweet chart. So I want the wheels more or less than 12? "Less right. or doest it matter that much?
Old 10-30-2009, 08:30 PM   #1072
ruffrida2005
Dave if you run those tire sizes you will have really thin tires. And I dont believe anyone makes those tires sizes. You have to think most 16" car tires are about a 205.
Paul
Old 10-30-2009, 11:00 PM   #1073
Strodder
Strodder's Avatar
I wish I could be more help, but I never did 60 to 87 trucks. Lots of 88 and up though. And made them lay frame. It looks like you need to get the front suspension to drop lower.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 10-31-2009, 10:48 AM   #1074
watahyahknow
watahyahknow's Avatar
the porterbuild dropmember would be just the ticket its designed to lay frame with 22 inch wheels .
with the original crossmember adapted you still have the original steering and the alighnment will be out of wack when youre running low along with the clearingproblems with the oilpan and the headers that need to be atended too , the porterbuild dropmember is practicly a bolt in and uses a ford rack and pinion this tightens up the steering a lot and keeps the wheels aligned a lot better troughout the up and down motion its allready has the pads for airbags
he changed the geometry a bit so the wheels are a bit forwarth in the fenders to be able to fit bigger wheels and make the wheel look more centered in the wheelwhell
he recently added a new treat to the forum plugging his newest version and the A arms hes now building
nathan porterbuild is a verry nice person and a good man to do busness with he keeps to his word unlike others i dealt with
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 10-31-2009, 11:06 AM   #1075
Strodder
Strodder's Avatar
Dave you got me thinking last night. You can also raise the front portion of the frame in front of the cab. Like you would do in the rear. It would raise your engine too, so you can't go too high. It would for sure get your 20s on and lay frame. You would also have to drop the front portion of the frame in front of the cross member to mount the sheet metal and bumper. Lots of work, and the cheapest way to go.
Watahyahknow's idea is good too, but looks like it would be expensive. Do you have a link to there web site?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
