02-01-2012, 03:26 PM | #1076 |
Re: Make it handle
So no anti squat with a parallel 4 link? How would you account for that in a drag race application? The low CG? I am learning so much cool stuff from this thread.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
02-01-2012, 08:21 PM | #1077 |
Re: Make it handle
Yes they run parallel bars, when viewed from the top, but from the side view, they are not. Slicks, and the low CG help. The key is to run the lowest Anti-squat you can, and still hook up hard. Front/rear weight, CG, Tire, it all comes into play.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
02-01-2012, 10:54 PM | #1078 |
Re: Make it handle
So I have a question about the best way to go about gaining more anti squat with the 4 bars. Would it be better to lower the rear mount of the upper bar or raise the front mount of the lower bar? Is it just more of a matter of experimenting with a particular set up?
Matt
My build thread http://www.67-72chevytrucks.com/vboa...d.php?t=494247 |
02-01-2012, 10:58 PM | #1079 | |
Re: Make it handle
02-03-2012, 04:59 PM | #1080 |
Re: Make it handle
Wow, not too many comments on the 4-bar/3-link info. Are we still thinking?
02-03-2012, 05:10 PM | #1081 |
Re: Make it handle
I have something that could be discussed.... how does the positioning of the link bars at the axle tube come into play? For example, how does the width between the two pivots (side view) effect the function; how does the distance from the axle tube center-line to pivot points (side view) effect its function... etc.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
02-03-2012, 06:55 PM | #1082 | |
Registered Cruiser
Re: Make it handle
Is there a way to properly increase anti squat when running a bagged app, laying frame, with a 4 bar/link? Just wondering how possible that would be with the amount of travel there is in that type of suspension?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
02-04-2012, 01:40 PM | #1083 | |
Fun Stuff
Re: Make it handle
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
02-04-2012, 05:58 PM | #1084 |
Re: Make it handle
These sites helped me a TON when building my setup. I have a triangulated 4 bar.
Here is the calculator for anti-squat and roll center http://mysite.verizon.net/triaged/4l...tml/index.html Here is a great site that helps describe how to get a car to hook up http://www.baselinesuspensions.com/i...A_Drag_Car.htm
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
02-07-2012, 12:27 PM | #1085 |
Re: Make it handle
Yes, it's to offset weight. Usually there is only the driver. Remeber that the pedals, booster/master, column and wheel are on the right side. Even with the battery, fuel pump, and othe components moved back and left, it's hard to get a balance. Moving the eng/trans helps. - an old MOPAR trick.
02-07-2012, 12:27 PM | #1086 | |
Re: Make it handle
02-07-2012, 12:30 PM | #1087 |
Re: Make it handle
Approach this as a static drop. The only time you really need to focus on the geometry us at Ride Hieght. - you just can't corner that fast with the frame dragging the ground. - lol. Start with the lower bar level at RH, and the upper bar running down hill (in front) appx 5*.
02-07-2012, 01:26 PM | #1088 | |
Re: Make it handle
02-07-2012, 01:28 PM | #1089 | |
Registered Cruiser
Re: Make it handle
02-07-2012, 05:35 PM | #1090 | |
Re: Make it handle
First, bar mount width. Side - side. As the rear moves up and down, becuase of the arc of the bar, the axle moves a little bit forward or backward, depending on the bar geometry. Longer bars move less, and shorter bars more. If both tires move up the same amount (suspension compression) the axle moves a bit forward, and stays square to the truck. But, if only one side is compressed, like in a corner or a bump, the rear end can 'steer' itself. As the bar spacing gets closer together, from the top view, the more this 'steering' is noticed. As far as the pivit point locations go, I think it would be best to have the upper bar pivit point, and the lower bar pivit point be the same distance from the axle center. That being said, most vehicles would have big packaging problems with an upper bar 6" above the axle CL. - This is MHO - no testing. But I can prove this thought. A 4 bar that places the upper bar even with the CL has a lot of issues. Tremendous force is lost as the axle wants to rotate under the bar, instead of a push-pull of the two bars. This tends to let the rear squat, and unload the tires.
02-17-2012, 12:28 PM | #1091 |
Re: Make it handle
one of those nights. We went over to A.M.P. (Adams Motorsports Park) last night, even though it was drift night, they let us run the time-attack loop if we show up. We wanted to run the JT with it's wider track set-up. A local guy Kenny B. was there with his S-10. ?? Kenny has been coming in and buying some Afco, Howe, and Speedway parts from us in the last few months. I thought he was building an IMCA Mod, but I guessed wrong. His short bed, std cab is a budget build screamer. Worked over front suspension, read this, build a metric mod front on an S-10, add a big sway bar, and the rear is really simple too. He kept the leafs, added a spring slider to mount the housing (speedway dirt track parts), and added a torque arm. The 4.3 is mildly worked, still EFI, and a 5-speed. Kenny tells us he's at the $3k mark now, and it's a dayly driver. He ran many laps in the 49 sec mark, right along side the JT. Note the S-10 has sticky Falken rubber, 255/45/17 all around. Next he says is a cage, rear sway bar, and adjustable shocks. I'm really sorry I didn't get any picts or video, but we will in the future. He says he'll be at our track day on march 29th. Anyway, a fun and surprising night. It was col to see this home built, well thought out, p/u running good, maybe we can help him get into the Truckin' Throwdown III
02-17-2012, 12:31 PM | #1092 |
Re: Make it handle
Oh yeah. The JT ave lap was 49.58, almost .3 sec faster than it's best lap ave. (pev best 49.85). The only change lately has been to widen the track 2" ft/rr. We did this with some billit wheel spacers that we had. Not my favorate way, but we wanted to check it out before we considers a new set of wheels.
02-17-2012, 12:40 PM | #1093 | |
Re: Make it handle
02-17-2012, 12:43 PM | #1094 |
Re: Make it handle
The current wheels are 9", we may go to 10" all around, with a little less back space, so both gains if we change.
02-17-2012, 01:07 PM | #1095 |
Re: Make it handle
I gotta start going to the track on "amateur day", Thunder Hill in Willows, and see what people are running. Hopefully something a little different like the S10 guy, or somebody cool like Rob.
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
02-18-2012, 12:01 AM | #1096 |
Re: Make it handle
Hey Rob
have you heard anything about a Throwdown in Ca this year? |
02-18-2012, 04:13 AM | #1097 | |
optomistic ah-so
Re: Make it handle
I figured if I ever had the chance to really go that route I'd find some of those flared fiberglass fenders for off-road S-10s...the IMCA Metric Mod is based on G-body geometry which is almost identical to the S-10 (parts will bolt on) but a little wider and this idea stayed in the dreaming stage so I don't know by how much.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
02-20-2012, 04:23 PM | #1098 | |
Re: Make it handle
How's you'r new project comin?
02-20-2012, 04:24 PM | #1099 |
Re: Make it handle
Kenny's S-10 has stock fenders, he used wheel offset to cope with the additional width.
02-20-2012, 04:31 PM | #1100 |
Re: Make it handle
Looks like GoodGuys is changing the rules for their autocross events. This could be 'Rob Rule #2. From now on, if you win your respective class, like 'truck' you will be moved into the Pro class. The vendor class will be replaced by the Pro class, and all displaying vendors will run in that class. This is to stop guys like me from dominating the class, and giving others a shot at the winners circle. ( I may not like it, but those are the rules now) So, get your trucks ready and get out and have some fun.
