03-18-2017, 05:33 AM | #1076 |
Re: My 50 roadster pickup build
Looks good Jim!
Going steady, before you know it, you'll be on the raod again!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
03-18-2017, 07:45 AM | #1077 |
Reaper, want to share some info on the Tig unit you are using? Nice job.
Rich
03-18-2017, 09:05 AM | #1078 |
Thanks Kees, hope to get something done each day. Now that spring is here,means cutting grass and yard work, so we will see...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-18-2017, 11:14 AM | #1079 |
Jim, I really like the New turn signals your using. Did you use the Hagen frenched head lights ?
03-18-2017, 02:34 PM | #1080 |
Thanks Ray, yes they are Hagen units, so were the old ones. The new system for installing the light is much better than the older units. Will have to modify the old bucket (pass side), but no big deal...Jim
03-18-2017, 02:43 PM | #1081 |
Well, managed to get a few hours in the shop today.
Pic 1 Is the location of the existing turn signal, that needed to be cut out. My old system was welded to the fender, new ones are different. Pic 2 Back side of fender. Pic 3 After cutting out the old system.
03-18-2017, 02:57 PM | #1082 |
Pic 1 & 2 Old and new system side by side.
Pic 3 This is the rubber sleve that is held tight to back side and then tighten the clamp to hold everything in place. Pic 4 From view of new unit in place. Pic 5 Rear view of new unit in place.
03-18-2017, 03:03 PM | #1083 |
Well I couldn't help myself, had to throw a couple bolts in the fender and set it in place to check the fit. Don't see any major problems. Will have to wait till next week and Mark can help me install inner and outer fender together to see if any cutting and welding are needed.
Fender is back on the horse already, till next time...Jim
03-18-2017, 03:14 PM | #1084 |
I like those new turn signal units.
I'm impressed that you can get back into fixing it so quick. I'd be so depressed I'd probably just stare at it and hope it would fix itself! Hope there isn't to much cutting and welding.
53 Chevy Pickup |
03-18-2017, 05:16 PM | #1085 |
That new turn signal assembly looks like a simple install. It looks good too. Repairs are coming along very well.
03-18-2017, 10:58 PM | #1086 | |
Believe me when I say I hoped it would fix itself, hoped it was a bad nightmare, but it wasn't...Jim
03-18-2017, 11:00 PM | #1087 |
Thanks Doug, yes it is simple. Little by little it's getting there, and a lot faster with your fender. Hope you and Cindy are doing good...Jim
03-18-2017, 11:10 PM | #1088 |
I like the chrome trim ring of the new light. It adds just the right amount of bling. The repair is looking really good.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
03-19-2017, 12:04 AM | #1089 |
Faribran, The TIG unit I have is from Eastwood (TIG200) AC/DC is is an awesome TIG machine! and you can find them on sale for around $700.00 and they offer a digital 200 AC/DC unit now for $1000.00
Both units have a trigger on the torch so you don't have to use the foot pedal all the time (like under a car) hope this helps. Mark
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
03-19-2017, 06:23 AM | #1090 |
Coming along nicely!!
To be honest, I like the new turn signal more than the old one, it looks great!!
03-19-2017, 09:46 AM | #1091 | |
03-19-2017, 01:58 PM | #1092 |
Looking good Jim!
I like the new turn signal approach too. Not that i didn't like the prior look but this just looks a bit more finished. Matching the headlight chrome and grill is just a bonus. You ARE aware that chrome adds 10 horsepower, aren't you? It's kinda like the huge diagonal letter "R" graphic on Japanese import cars! Lol.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-19-2017, 02:43 PM | #1093 | |
03-20-2017, 11:40 PM | #1094 |
Coming along real good! Almost time for the rattle can and call it a day
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
03-21-2017, 10:07 AM | #1095 |
Thanks lower. I wish it were, but lots more time fitting, etc, before that...Jim
03-21-2017, 06:12 PM | #1096 |
wow good updates! you will be ready for the summer shows for sure
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
03-21-2017, 08:46 PM | #1097 |
Did you say you are going with a chrome grill this time?
If so, are you buying a reproduction or getting an original one re-chromed?
53 Chevy Pickup |
03-21-2017, 11:17 PM | #1098 |
Thanks joedoh, I really want it ready my May 1st, will see...Jim
03-21-2017, 11:19 PM | #1099 |
Yes, a chrome grill. I bought a repo, looks really good, will see how it fits, here soon...Jim
03-22-2017, 04:26 AM | #1100 | |
and nuts) between all of the sections were all very cheap poorly plated steel. I ended up jigging the whole thing up on the bench and replacing with stainless steel 10-32 hardware. Also, the unit was fastened with a slight skew and twist when I got it, so I straightened that out too. A lot of the hardware was loose too. The chrome looks really nice though, so I'm pretty happy! Hope your's has better hardware.
53 Chevy Pickup |
