08-30-2014, 09:48 AM | #1076 |
Re: 72 k20 project
not a bad idea. i am leaning towards a hinged plate. the magnets are a neat idea, but i would be afraid of loosing them or some passer-by snatching them for the heck of it.
i may also be able to use a thumb screw and tap a hole in the fairlead face. i am leaning towards the hinged apparatus though. |
08-30-2014, 10:28 PM | #1077 |
Re: 72 k20 project
08-30-2014, 10:46 PM | #1078 |
Carpe manana
Re: 72 k20 project
Wow!!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-31-2014, 08:43 PM | #1079 |
Re: 72 k20 project
Thanks Pete!
you guys are probably tired of the same pics, but i like em! sitting at RH. front and rear. a poor representation. the floor slopes to the rear, and the front tires are smaller. should have a little bit of a nose heavy stance. i prefer that look in a "working" truck. always looks ready for a load and seems more aggressive. i will have to tune the ride height once it is all together and i can have it on some level ground. looks close to me though. slammed all the way out front and rear. curbside load position should be pretty close to a stock 4wd. i dont have one on hand to measure, but comparing numbers to my yellow truck shows it to be in the area. jammed in tight. truck puller mode. no air front, at the top in the rear. this would be dumped rear and RH front. trailer hook up position the goals here where to measure for shock length front and rear. this is at the top front and rear. bag spec on the rear says it could go at least 2 more inches up, but i didn't like it. got nervous about the bag over extending. the fronts by spec have more than 3 inches left. they scared me too, so i stopped. i will probably set up the limit straps and shocks to take adavantage of the added length, to a degree, but i will err on the conservative side since the down travel will be less of a concern on this truck. gratuitous shot roughly comparing my yellow truck with a 2.5-3" lift, it will be in the area of a 5.5-6"ish lift over stock. again, i'd need axle to frame measurements to compare or a factory height truck around to compare more accurately. the rake is a little more than stock for sure. |
08-31-2014, 08:49 PM | #1080 |
Re: 72 k20 project
I also did a little "test" not the most reasonable since the rest of the truck is not here, but i filled one front bag while all the rest were empty. i didn't take any real measurements, but the chassis is pretty darn rigid, but does flex just a touch. perfect.
08-31-2014, 09:59 PM | #1081 |
Re: 72 k20 project
Awesome work on the chassis
Is there a bit of a body lift on the cab I see? And I see the factory front shock mounts are still on the frame, are you planning on using those?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
08-31-2014, 10:35 PM | #1082 |
Re: 72 k20 project
Looking good there Ryan.
Very cool to see the suspension in all "modes". And it all fits. All those details are paying off.
Tom 71 K2500 71 K5 Jimmy |
08-31-2014, 11:47 PM | #1083 | |
Re: 72 k20 project
there are definitely some things i need to address, but so far i cant gripe. i am excited to post pics of the different modes being controlled by my control ciruits and all the bodywork on, but i cant resist some motivational pics. |
08-31-2014, 11:59 PM | #1084 | |
Re: 72 k20 project
09-01-2014, 09:34 PM | #1085 |
Re: 72 k20 project
I agree, anything over 1" is totally out of the question for me. i am less impressed with myself than could be due to the lack of forethought that could have prevented this, but the added space i got in other areas really does make it a positive. feels like heresy to say that.
here are the old next to the new. installed. new bolts will have to happen. punched the wiring pass through holes in the bumper and trimmed excess off the receiver tube as well also melted this in. |
09-01-2014, 09:38 PM | #1086 |
Re: 72 k20 project
open to suggestions on ideas for bumper color
i am thinking silver or white with a mild chance for black. i am almost positive the front bumper will be OEM and white. |
09-01-2014, 09:42 PM | #1087 |
Junk Yartist
Re: 72 k20 project
Crazy thought, thinking about going this route on my Cummins swap, what about raising the cab mounts the necessary height, and dropping the bottom of the core support. Since you are pretty much building a bed, why not drop the bed floor. I say all this knowing that you are already way past that point, just agitating that twitch.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
09-01-2014, 10:20 PM | #1088 |
Carpe manana
Re: 72 k20 project
I'd vote for something like an argent silver - keeps with OEM-color theme for a factory step bumper. White my second vote.
09-01-2014, 10:52 PM | #1089 | |
Re: 72 k20 project
i knew there was a reason we were friends, Pete! that is basically what i am thinking |
09-01-2014, 11:09 PM | #1090 |
Re: 72 k20 project
I really think that will look cool with the bumpers painted that way. I have always loved the look of a highly modified truck that makes the average joe think it's mostly stock . The period correct colours are where it's at. I even vote for 10 wide steelies and stock hubcaps .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
09-02-2014, 12:11 AM | #1091 |
Re: 72 k20 project
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-02-2014, 01:22 PM | #1092 |
Re: 72 k20 project
AWESOME WORK!!!! I am impressed with the core support rehab. I may have captured some screen shots to use for ideas. I am mostly interested in the mounting of the a/c condenser, and clearance from the grille and hood latch. I will be following this thread until completion, once again, great work.
09-02-2014, 02:21 PM | #1093 |
6>8 Plugless........
Re: 72 k20 project
Nice work Ryan! The suspension looks great! I vote white on the bumper since the front will be white. For some reason, I just think white will look better than black on that green.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-02-2014, 05:01 PM | #1094 |
Re: 72 k20 project
Those cab pics make me want to call Rambo for a recon mission.
That bumper is stout. Now,i almost feel bad for what you back into with that ! And i think like Dieselwrencher on the bumper.White. But,you and Pete are right.Silver would look good too. Decisions.
09-02-2014, 09:31 PM | #1095 | |||||
Re: 72 k20 project
due to my choice in brake upgrades, i have to run a 17" minimum. i am going for 18". with all the super duties out there with OEM 18"s i think they will get cheaper and be easy to find. so aftermarket wheels are the plan. Quote:
i cant say for sure right now, but i think the condenser will fint with only a little additional trimming of the grill support. i have not even figured out the condenser i will use so that is a bit in the future. Quote:
itll be bolted to the frame, so best get arnie to help. sly is to itty bitty for that! i pity the fool that takes a crack at the back bumper. i feel like i will win. |
09-02-2014, 09:44 PM | #1096 |
Re: 72 k20 project
I did a little water jetting today.
those go together like such. fuel sender and the new draw tube. turned a lip on the weld-in piece . i also got this all mounted. in a bit of hidden fastener trickery, the bolt threads through the clamp and sets the filter in place. does not take much, just a little pressure. that also mounts the clamp. jam nut on the bolt makes sure the clamp is tightly mounted to the pump bracket. i had a friend already on the way to four states gasket, so i had him pick up an appropriate sheet of fuel safe gasket material to make a seal. |
09-02-2014, 11:11 PM | #1097 |
Vintage 4x4s
Re: 72 k20 project
Good progress Ryan!
I vote white like this from 66knsmodels: Second pic is CG's awesome truck shown for a look at black.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
09-03-2014, 08:43 PM | #1098 |
Re: 72 k20 project
Awesome Work!
Totally impressed ! I have read and looked through the pictures SEVERAL times and I find something new every time! Oh, that Cab shot doesn't get old, just looking better every time I look at it ! |
09-03-2014, 09:05 PM | #1099 |
Re: 72 k20 project
That's great work on the sender rehab!
09-03-2014, 10:23 PM | #1100 | ||
Re: 72 k20 project
Thanks! here are some more. burned a hole in the tank. welded in the flange. added a pick up tube of appropriate size. also made a gasket. the material was Buna. an as spec'd -10 fitting for fuel pump draw. the sender is in as well. and jabbed in the tank. it looks a little like it is on steroids. i suppose that is ok though... |
