06-17-2022, 09:30 PM | #1076 |
Post Whore
Re: My Dusty 71 GMCe Electruck
and then I powder coated it again, and although this time it took, ie the powder stuck, it dried all dull ie matt instead of glossy
and I powder coated a door hinge at the same time and that dried nice and glossy like all the other parts, so I have no idea what is up with this saucer and honestly as long as it's black and protected from rusting I really don't care |
06-17-2022, 11:14 PM | #1077 |
Post Whore
so big day tomorrow all this stuff gets bolted on
Electruck EV Conversion Update 2 Front End Rebuild / Disc Brake Upgrade Last edited by Gregski; 06-19-2022 at 12:30 AM. |
06-18-2022, 10:41 AM | #1078 | |
Post Whore
06-18-2022, 01:25 PM | #1079 |
Always a good feeling to check a box
71 C10 72 K20 72 K10 Super Kirk |
06-18-2022, 08:16 PM | #1080 |
Post Whore
happy to report the final assembly has commenced and with the help of two great new friends and forum members without whom there is no way I could have done what we did today, we got the trans mounted, the cab mounted, and the crossmember installed (we could not mount the control arms as I am still waiting on the rubber seals
Fun Level: 11.2 Last edited by Gregski; 06-18-2022 at 08:22 PM. |
06-18-2022, 11:15 PM | #1081 |
Coming together really nice, I’m enjoying the journey.
06-19-2022, 09:49 AM | #1082 |
Post Whore
06-20-2022, 03:36 AM | #1083 |
Post Whore
hope you all had a great fathers day, I got to go fishin' and here's what I found:
yup it's a 1" anti swear bar, and judging from the 8 lugs that appears to be a 3/4 ton Squarebody (couldn't tell what year) but the word on the street is that it could might work Fun Fact: some of these are held on to the frame with brackets using 3 factory rivets and 1 bolt, other's using only two factory rivers and 2 bolts (the rivets have to be drilled out [ahem] in the field) Fun Level: 2 Note: these trucks still use the 67-72 style lower control arms, how neat is that, tells you what a great and smart design they were Last edited by Gregski; 06-20-2022 at 03:46 AM. |
06-20-2022, 03:41 AM | #1084 |
Post Whore
now what's more better than one anti swear bar?
that's right two anti swear bars this next one is fatter than 1" and came off of a GMC 2500 rig (I recall 10 years ago you could find half a dozen 1/2 ton short box trucks in the yard, these days you might find one or two 3/4 ton 8 lug long bed work trucks completely wrecked or stripped down) by the way they was $45 bones each, not bad though the rubber is perished Last edited by Gregski; 06-20-2022 at 03:47 AM. |
06-21-2022, 02:02 AM | #1085 |
Post Whore
so then it was time to transfer all the dirt, grime, and rust off of these beauties and onto my face
first the 1 1/16th skinny bar (or at least that's what it calipered too, maybe that included a layer of dirt, grime and rust) |
06-21-2022, 02:03 AM | #1086 |
Post Whore
wire wheelin' like a Boss !
06-21-2022, 02:06 AM | #1087 |
Post Whore
I believe when it comes to de rusting it take two to Tango, abrasives and acid
Prep & Etch Phosphoric acid from Home Depot (like all them fancy de rusting conglamorets at a fraction of the cost and works way better) used to be $5 bucks per gallon now it's like $20 also this is the new(er) California formula so no rubber gloves required (jk) |
06-21-2022, 02:08 AM | #1088 |
Post Whore
then it was time for the big stick, cause I haven't decided which one I'm gonna run yet, any advice?
06-21-2022, 02:09 AM | #1089 |
Post Whore
a little before and after the dance of the wire wheel, then primer then paint, I like my rods silver and my sheets black
06-21-2022, 02:12 AM | #1090 |
Post Whore
and here are them brackets that are usually rivited to the frame rails, these will also get media blasted (I hate putting greasy bits in the media blasting cabinet as it gunks up the media) and then later powder coated
06-21-2022, 02:40 AM | #1091 |
Post Whore
hey I know let's check on those $3 dollar rubber seals that are holding up the project and preventing us from putting the control arms back on
how did that saying go again: "Neither snow nor rain nor heat nor gloom of night stays these couriers from the swift completion of their appointed rounds" |
06-21-2022, 03:07 AM | #1092 |
Looking good
06-21-2022, 09:11 AM | #1093 |
Post Whore
06-21-2022, 10:52 AM | #1094 |
Post Whore
Anti Swaybar (pronounced: "Stabilizer bar") sizes according to Rock Auto
1-1/16 (in) (ah maybe I'm not crazy and my measurements were accurate) 1-3/32 (in) 1-1/8 (in) 1-3/16 (in) 1-1/4 (in) that's it, where is Keith when you need him??? |
06-22-2022, 09:32 AM | #1095 |
Post Whore
yes the mind blowing excitement continues ...
[rant] this stuff makes me think the next time you go to buy a truck or sell a truck and you or some dude want's $15K for it just pay it, or go ahead head over to Pick N Pull when it's 104° F out, in hopes of finding a donor truck, lay upside down on the gravel and drill out them rivets with your cordless and a stash of extra batteries, while the scorching hot metal shaving find their way down yer sleeve, throw in a few cuts and bruises and a solid head bump on the edge of that sharp front bumper.... I'll hold, ha ha [/rant] |
06-22-2022, 09:36 AM | #1096 |
Post Whore
also media blasted the other three hinges
06-22-2022, 11:37 PM | #1097 |
The larger sway bar will have less body roll when cornering. I would use that one.
06-23-2022, 07:45 AM | #1098 |
Nice build and looking forward to seeing how this turns out. I have a question - Is the larger sway bar from the 1985 GMC 2500 a direct bolt up to the 67-72 trucks. I have a 72 C20 and would like to go to a larger bar but not want to pay the high cost for a new one. And I also do not want to drill any holes to make one fit.
06-23-2022, 09:21 AM | #1099 | |
Post Whore
1. my '69 frame only has one hole on each side instead of two, a friend of mine tells me that yeah we will have to drill out the rivet that holds the very front small crossmember in place and use that hole for the second hole. I hope you follow that and it makes sense. 2. the 85 bracket holes don't align perfectly (maybe 1/8th of an inch too narrow and the bracket needs to be spread out just a tad) but is it because I am putting C20 brackets on a C10, or is it because I am putting '85 brackets on a '69 frame or is it because there is still a river in the way, or is it because the bracket may have been warped a bit??? feel me, just trying to help (and get motivated to drill out yet more rivets, lol) |
06-23-2022, 01:30 PM | #1100 | |
Your friend is correct the rivet that helps hold the front crossmember brace on does have to be removed when installing a sway bar on a truck that did not come with one. Thanks for responding back to me. Now I will look for a 85 GMS 2500 front bar. Since I am in Texas, the Land of trucks. Maybe I can locate one cheap. |
