Old 08-23-2018, 09:24 PM   #1101
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Thanks, the color the GM color is Jet stream Blue GM code WA512Q it was used on corvettes from 08-011. As far as I know it’s discontinued.
Alex - Dirty AL "One Piece at a Time"
Follow me on Instagram alex.barr.ios
smokedat is offline   Reply With Quote
Old 08-23-2018, 10:21 PM   #1102
smokedat
smokedat's Avatar
Trying to figure out some of the interior details like ignition switch since my steering column is keyless, I wanted it like that any how narrows it down to these 2 from so cal speed shop. I was thinking of concealing- so I don’t drill any holes in the cigarette lighter small compartment door
Old 08-23-2018, 10:50 PM   #1103
smokedat
smokedat's Avatar
I also want to add a gauge cluster 2 for sure maybe 3. For sure I will add a transmission temp gauge and a fuel pressure gauge, and maybe a dial clock. Mounted on a either a finned or regular aluminum bracket. As for mount location still not sure maybe under dash in view like below radio.
Old 08-23-2018, 11:11 PM   #1104
smokedat
smokedat's Avatar
Items needed for a fuel pressure gauge. Adapter and the sender and it goes something like this
Old 08-23-2018, 11:25 PM   #1105
smokedat
smokedat's Avatar
As for the transmission cooling I will cancel the radiator cooling and use an external cooler from Derale with temp sender coming out of cooler. I will hard line the system
Old 08-24-2018, 12:28 PM   #1106
LT7A
Copy that. I was going to be surprised if the electron blue was still in use in the same formula. I asked because I had a Trans Am then with bad paint. I wanted to change from the burgundy and couldn't decide until I saw the 2000 Vette.
Anyway that Jet Stream is a beautiful color. Looks amazing in the sun.
Old 08-24-2018, 11:05 PM   #1107
smokedat
smokedat's Avatar
So the Z10 has reached a milestone the engine is finally in. I couldn’t think of this day ever happening. And the bed got done
Old 08-24-2018, 11:14 PM   #1108
z71se
Looks nice man. Did they paint under the bed the same color?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 08-24-2018, 11:33 PM   #1109
smokedat
smokedat's Avatar
Thanks. No under the bed and cab I did a silver POR 15 I like the contrast it gives I didn’t want to deal with clear gettI got chips. POR 15 gives good protection and it’s way more cost effective.
See the pics below I dig that contrast
Old 08-24-2018, 11:36 PM   #1110
smokedat
smokedat's Avatar
It took me like 3 years to find a decent tailgate. The one I had originally was beat up beyond repairs. Mind u this tail gate had allot of work done. I love the stamped letters
Old 08-25-2018, 12:17 AM   #1111
smokedat
smokedat's Avatar
Here are some pics of the tailgate in sequence, I found it up in Ojai Ca. Some dude that had like 4 c10 in different stages some just parts junkers
Old 08-25-2018, 12:21 AM   #1112
smokedat
smokedat's Avatar
On parts that need allot of work I do them in sections or zones and close in on it. Once I lose my patience I walk away and try another day, sometimes ur just not inthe mood, if that’s the case I don’t eaven attempt to do any work.
Old 08-25-2018, 02:22 AM   #1113
z71se
Lol he have any other parts? I’m looking for some 73-80 inner fenders.
Old 08-25-2018, 07:59 PM   #1114
smokedat
smokedat's Avatar
If I come across a set Il let u know
Old 08-25-2018, 08:02 PM   #1115
smokedat
smokedat's Avatar
So the fire wall section got color sanded and buffed prior front clip being install. Looks really flat straight. Btw color over a phone pic is way off
Old 08-25-2018, 08:44 PM   #1116
smokedat
smokedat's Avatar
Here’s an almost complete pic. Needs tailgate.
Old 08-26-2018, 01:19 AM   #1117
mud.man.rj
mud.man.rj's Avatar
Just love that firewall, nice work on all of it, a pleasure to see the build come along.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 08-26-2018, 02:06 AM   #1118
z71se
That firewall doe!
Will you be drilling into it for vintage air?
Old 08-26-2018, 10:29 AM   #1119
smokedat
smokedat's Avatar
Mudman.
thanks mudman
Old 08-26-2018, 10:30 AM   #1120
smokedat
smokedat's Avatar
That firewall doe!
thanks, i decided not to run ac or heater, im out in cali where is mostly sunny
Old 08-26-2018, 10:33 AM   #1121
smokedat
smokedat's Avatar
here a few fast track pics of the evolution of the firewall
Old 08-26-2018, 10:35 AM   #1122
smokedat
smokedat's Avatar
few more
Old 08-26-2018, 03:03 PM   #1123
mud.man.rj
mud.man.rj's Avatar
Well we can tell it wasn't fast, but all the effort sure paid off.
Mudman.
5.0 4spd std.
7" lift w 35's.
Old 08-28-2018, 12:33 AM   #1124
smokedat
smokedat's Avatar
Towed the square back home. I didn’t install tail gate cus I didn’t have stainless bolts for hinges. Will do this on week end. will also install the steering column and steering wheel, maybe if I get to it install the calipers and wheels and adjust the stance on the coil overs now that it has the weight of engine.
Will wait 3 weeks before I color sand.
Old 08-31-2018, 11:34 PM   #1125
mud.man.rj
mud.man.rj's Avatar
Truck and colour looks great, love the wide rear tubs.
Mudman.
5.0 4spd std.
7" lift w 35's.
73c10, c10, cheyenne, ls1, swap
