Old 03-22-2017, 08:31 AM   #1101
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Originally Posted by donandal View Post
The reason I ask, I used a repo also but the fasteners (10-24 screws
and nuts) between all of the sections were all very cheap poorly plated steel. I ended up jigging the whole thing up on the bench and replacing with stainless
steel 10-32 hardware.
Also, the unit was fastened with a slight skew and twist when I got it, so
I straightened that out too. A lot of the hardware was loose too.
The chrome looks really nice though, so I'm pretty happy!
Hope your's has better hardware.
Thanks for the heads up. I had planned to look it over good, I rebuilt my original grill, so if need be I'll rework what is necessary...Jim
oldman3 is offline   Reply With Quote
Old 03-28-2017, 07:47 PM   #1102
oldman3
oldman3's Avatar
Well back for a little update. Last week was one of those where life gets in the way, so nothing was done.
Today I was able to work on the Hood latch panel for a couple hours. The panel was bent in a couple places in the accident, which cause several large cracks in the paint.
Pic 1 overall shot of panel with cracked paint removed.
Pic 2 and 3 are close ups...Jim
Old 03-28-2017, 07:56 PM   #1103
oldman3
oldman3's Avatar
Pic 1 Areas were DA'd to feather in the edges, and then the rest of panel was sanded.
Pic 2 &3 again are close ups.
Will see how things go tomorrow for anymore updates...Jim
Old 03-28-2017, 08:51 PM   #1104
Advanced Design
Advanced Design's Avatar
Good to see the updates Jim. Looks like you are able to straighten the panel?
Advanced Design is offline   Reply With Quote
Old 03-28-2017, 10:23 PM   #1105
youngrodder
youngrodder's Avatar
Looking good Jim...Things always look worse before they can look better. The repair is looking top notch.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 03-28-2017, 11:14 PM   #1106
oldman3
oldman3's Avatar
Thanks Doug, Yes I had about 30 to 40 mins of hammer and dolly work. Had to reshape the panel to match the long curve of the fender. Plus had to remove a big goosebump from where the cruise unit hit the panel...Jim
Old 03-28-2017, 11:16 PM   #1107
oldman3
oldman3's Avatar
Marc
Thanks Marc, if I can get some small things done, it will seem like I'm doing something...Jim
Old 03-29-2017, 08:41 PM   #1108
lower50's
lower50's's Avatar
Good job with the hammer and dolly.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-29-2017, 11:01 PM   #1109
oldman3
oldman3's Avatar
Thanks lower...Jim
Old 03-31-2017, 07:41 PM   #1110
oldman3
oldman3's Avatar
Got a couple small things done the last few days. On Wednesday I used some fiberglass filler to fill behind the new headlight bucket and fender. It filled most of the opening. Thursday nothing. Today I put some regular filler by the bucket again. I don't want any area were dirt and water can cause it to start rusting.
Pic 1 Filler installed
Pic 2 Here I've been sanding it down.
Pic 3 Covered with encapsulator paint.
Old 03-31-2017, 07:47 PM   #1111
oldman3
oldman3's Avatar
Pic 1 Also today I install filler around the headlight area and the fender.
Pic 2 and 3 showing sanding the filler.
Pic 4 and 5 showing the good right fender and the look. Need to match the left to the right fender. On page 43 post #1071 you can see how it needs to be built up at the bottom to have a smooth look...Jim
Old 03-31-2017, 09:02 PM   #1112
donandal
I think this type of repair is the toughest.
Matching custom work and remembering how you did it the first
time so it comes out the same.
Very Nice!
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-31-2017, 09:46 PM   #1113
lower50's
lower50's's Avatar
Ya trying to match is hard. Where do the wires go into the bucket? or are the lights wireless
1951 MG TD
Old 03-31-2017, 10:30 PM   #1114
Indian113
Indian113's Avatar
Slow and Steady Jim- You'll make it Soon!
Indian113 is offline   Reply With Quote
Old 03-31-2017, 11:19 PM   #1115
oldman3
oldman3's Avatar
Very Nice!
Thanks guys, appreciate the comments.
Yes it is tough. After I did the bondo on rear of bucket, I remember that I used a body hammer to knock down the metal toward the bucket and it didn't take that much. This was about 13 yrs ago and I slept a few times since then..
Lower, wires go in from the back of bucket, haven's drilled the hole yet, wire-less lights, that's a good ideal.
Ray, slow and steady, well slow at least, that's me...Jim
Old 04-01-2017, 03:10 PM   #1116
oldman3
oldman3's Avatar
Well, I got out into the shop this morning for a few hours. Installed the inner and outer fender. Aligned most of the areas I needed. Looks to be ok for now. Still need to make some adjustments. I did take my 6" aluminum rule to check how the front lined up.
Pic 1 Looking across both fenders, everything to this point is good.
Pic 2 and 3 are close ups of each fender and rule. Inner and outer edge of both headlight buckets are touching so it is good.
I also brought up my grill to check on the fit, let's say for an hour and a half, I messed with it, and it's going to have to been fine tuned. Didn't take any pics of this, but tomorrow I hope to get back in shop, show what's not right and make some changes...Jim
Old 04-01-2017, 06:41 PM   #1117
Advanced Design
Checking fender alignment / fit with a long straightedge is something I've never thought of before. One more idea I've learned from you Jim that is in my ideas bag now....if I can remember it. Thanks Jim!
Old 04-01-2017, 08:30 PM   #1118
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-01-2017, 09:20 PM   #1119
47 Fasttoys
47 Fasttoys's Avatar
Dang, you mean the headlight buckets are suppose to be aligned? Heck, I thought both in the same general direction was great. You obviously work at a higher detail level then I.
Looks great Jim, keep up the good work.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 04-01-2017, 10:21 PM   #1120
Indian113
Indian113's Avatar
Rob
Rob, You have to see this Truck in Person to really appreciate how much detail and fore thought Jim put into it. He even offered to let me drive it once when I was visiting him, just couldn't bring myself to take a chance on wrecking it but the ride I had was AWESOME!
Ray
Old 04-01-2017, 11:09 PM   #1121
oldman3
oldman3's Avatar
Thanks Doug, I saw this somewhere a long time ago, and have used it several times...Jim
Old 04-01-2017, 11:11 PM   #1122
oldman3
oldman3's Avatar
Rob
Thanks Rob, appreciate you checking it out. You camper is coming along nice...Jim
Old 04-01-2017, 11:12 PM   #1123
oldman3
oldman3's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
Thanks Kim, how's the back, hope you've been doing a little on yours...Jim
Old 04-01-2017, 11:14 PM   #1124
oldman3
oldman3's Avatar
Ray
Ray, your going to give me a BIG head, with all this. Appreciate it greatly, next time your back, you have to drive it...Jim
Old 04-02-2017, 09:13 AM   #1125
Kim57
Kim57's Avatar
Backs been doing fine.
Weather has been good so I'm able to spray again. Been doing a ton of sanding.
No fun but necessary.
Kim
My build thread
