#1126 |
![]() Join Date: Dec 2010
Re: 1977 Chevy K30 Crew Cab Build
Well, although it did cause headaches & an extra delay, it seems as if the clutch "emergency" has blown over....
Seems as if the initial measurements for the throwout bearing were taken off of the wrong point so it was incorrect... A new one is on the way as well as a new pushrod, so once that arrives all should be right with the world again! Sure wish Keven would'a been in charge of my truck all along so all this stuff could've probably been avoided!!! On a positive note, the Gaurd Dawg unit arrived today - seems as if they sent an updated model to replace the one they were supposed to repair. Once Keven verifies that the wiring set-up is the same as the other he can get it wired in. Start-up will have to wait until the trans is bolted back in place though.... |
#1127 |
![]() IT'S ALIVE, IT'S ALIVE, IT'S ALIVE!!!! ![]() This is the quick email message I got from Trevor only a few minutes ago: "All I can say is NASCAR! That thing sounds nasty! Keven only fired it for a second. Video tomorrow or Monday!" Still awaiting my full weekly update from Keven with pics, but man does this end my week on a GREAT note!!!!! |
#1128 |
Junk Yartist
Woooo Whooo!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#1129 |
![]() Join Date: Oct 2011
nice!!!!!
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
#1130 |
high-Tech Red Neck
And I said let there be fire!
Awesome man, that has to feel damn good knowing it is running.
"He used to be a pretty nice feller, now he's a welder!" |
#1131 |
Trust me, when I am there at the shop there will be some requisite tire destruction!!! Luckily the old tires & wheels are on there so no loss...
#1132 |
This is a really nice truck that you are building. I always tell my wife that I want to build an older truck like yours that is more reliable than any new truck rolling off the dealership. Can't wait to see you get it driving.
67 Chev "BIG-Bertha" ![]() |
#1133 |
Appreciate that man! Yeah, I managed to convince my Wife I should build one - think she might not allow it knowing what she knows now, but to late now!!! Hehe
#1134 | |
#1135 |
Front push bar is fully welded up - would take something pretty substantial to damage this thing!!! Still needs powder coat & will look like AWESOME!
#1136 |
This is the toolbox from Weather Guard we ended up going with. I like the one button opening & it's pretty well built & even matches the back pretty darn well out of the box!!! Keven's still got to bolt in down & all that this week.
#1137 |
This is how the engine bay looks at the moment. Kinda dirty & still needs some wiring clean-up & shortening/covering & organizing. We ended up ditching the Wilwood master cylinder since it wouldn't build pressure.... This one doesn't look as good, but is MUCH better than the stocker & works PERFECTLY!!!
On the plus side it's cheap & available almost anywhere if I ever need to replace it. Keven's got to adjust the brake lines & proportioning valve postition to finalize it. |
#1138 |
This is the slick little oil cooler line adapter Keven ended up using - it's from Lingenfelter Performance & it's a VERY nice piece!!!!!!
#1139 |
Something tells me that I won't have ANY issues with visibility at night in this thing!!!
#1140 |
My gauge cluster set in place. Everything works so far, just have to dial in the parameters for the oil pressure & water temp gauges in the Mast software to get them reading to match the readout when the computer is connected.
The speedo will require a new gear to be made once we can get it on a dyno. |
#1141 |
Keven added 12V outlets on the back of the center console as well as some heated seat switches to match the ones for the front. The seat heaters will be added when the upholstery is getting done.
#1142 |
This is the transfer case shifter arm mount that Keven ended up fabricating. The one they bought simply was too weak & bent after a few shifts, so he made one that isn't EVER gonna bend on me - plus it's got spherical rod ends!!!
#1143 |
sweet man! keeps gettin better all the time.
over here in Europe those push bars are prohibited, because they can seriously damage/injure pedestrians when hit by a car. Otherwise we would have mounted one of those too...
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#1144 |
http://www.youtube.com/watch?v=PcIQv...ature=youtu.be
![]() And here's the real payoff!!! This freakin' motor pulls like a horse in every gear!!! I broke the wheels loose all the way through 3rd gear on the freeway..... The motor was broken in on Mast's engine dyno, so there wasn't any need for me to baby it thankfully! This was a pure clutch dump - no brakes!!! Sounds cuts out a bit since the iPhone mic doesn't work well with that much noise... There is an exhaust system on there, but it's just a temporary one so it isn't completely obnoxious... |
#1145 |
These would'a been MUCH longer had I not been quickly running out of real estate directly in front of me.....
The torque arms they built for it make it go straight as an arrow in whatever direction I pointed it!!!!! I haven't had a smile this big on my face in quite a while!!!! ![]() |
#1146 |
http://youtu.be/TP5bpi7eBlw
Here's a video of Beau working on getting my gauges calibrated. The Mast ECM is GREAT - it allows you to customize the output for your specific gauges so it's totally universal & can even do CAN set-ups! |
#1147 |
Junk Yartist
I watched your burn-out vid 3 times. How does your neck feel after that?
#1148 |
Yeah, it pinned me back in the seat pretty darn well!!!! Was so fun & worth it though!!!!
#1149 |
wow the burnout looked like a speed up video from a 60s comedy movie amazing.
#1150 |
6>8 Plugless........
![]() Join Date: Sep 2007
Congrats on getting to drive it. It sounds wicked for sure! It'll be fun to drive around, and it sounds like it has no problem at all pulling up the rpm range!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
