Old 03-09-2015, 08:04 PM   #1126
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by enaberif View Post
Don't do roll pan. Get a nice sport chrome bumper will look so much better.
Sorry The Greg respects chrome for it's durability but don't like it, too much bling, now black chrome ... pronounced "EXPENSIVE" and that I can dance to!
Gregski is offline   Reply With Quote
Old 03-09-2015, 08:13 PM   #1127
enaberif
Re: Restoring Rusty
Originally Posted by Gregski View Post
Good point, we're running this split down the middle Holley approved spacer gasket, it is as you describe a 1/4" thick.
I am pretty sure you've discussed your carb/intake setup but could you refresh my memory of why you are using that spacer? Are you using a spreadbore intake?
enaberif is offline   Reply With Quote
Old 03-09-2015, 08:15 PM   #1128
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Fuel Problem - Idea
On February 9th I installed that inline fuel filter right in front of the carb and we all saw that the rubber hose 90* elbow was getting a bit squished, I am wondering if that has something to do with it, I am considering reversing this "upgrade" ie deleting the glass inline fuel filter in front of the carb, especially since I installed a plastic one now before the fuel pump
so going from this back to this... (it's just a thought, since I don't recall a problem back then)
Old 03-09-2015, 08:22 PM   #1129
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Dope, I meant to say square bore, looks like I found a pic of the spacer / gasket on it as well
Old 03-09-2015, 09:13 PM   #1130
enaberif
Re: Restoring Rusty
Yeah you have the spacer so I'd definitely be looking towards fuel delivery next.
Old 03-10-2015, 05:55 PM   #1131
rusty76
rusty76's Avatar
Re: Restoring Rusty
Take the filter out and try it out. Can't hurt. But if you have fuel in float bowls and in the filter and doesn't start there must be something to it. If you are having to hold your foot to the floor to start it then is it flooding out? Do you smell gas when you try to start it? I have no idea really but if we have fuel, air and spark then it should run right? But here again I guarantee it will be something simple. Let's get this problem solved fellas.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-10-2015, 07:57 PM   #1132
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Foot to the floor start is typically a sign of flooding. I think you are on track tho to try running without the filter for a day and see if that resolves the issue
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-10-2015, 10:49 PM   #1133
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Hmm...the filter theory is very interesting.
Chaplain is offline   Reply With Quote
Old 03-11-2015, 11:01 AM   #1134
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Where is The Greg?
Old 03-11-2015, 11:11 AM   #1135
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Chaplain View Post
Where is The Greg?
The Greg is suffering from a bad case of Hang-Over-Fenderitus (i.e. back strain) so he is trying really hard to stay away from Rusty for a day or two.
Old 03-11-2015, 11:49 AM   #1136
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
I get it. I mean I got it back in January when I had a fight with a frame and a pair of leaf springs.
Old 03-11-2015, 08:03 PM   #1137
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
This is a live update from the field... here is our field correspondent The Greg
Thank you Ron... yes here I am with Rusty at the scene of the crime. We have replaced the glass inline fuel filter right in front of the carb and made it here without the truck wanting to stall at the stop signs or quit running while parked
we've been idling here as I type this for about 5 minutes (yes I am a slow one finger Blackberrian, non of that dual teenage thumb action for me)
I am being told we are about to shut her off... Him I'm sorry... apparently Rusty is a he
more as the news develops
now back to you in the studios
Old 03-11-2015, 08:10 PM   #1138
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I am being told we have a visual of that replacement fuel line...
Old 03-11-2015, 08:44 PM   #1139
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
FUEL PROBLEM - GOOD NEWS!
It appears as though eliminating the glass fuel filter has fixed the problem, but it still may be too early to call it a permanent fix.
The truck started, on the second try but it started.
Drove it around some more and shut it off, waited about 10 minutes and it also started, again on the second try.
The plan is to drive it in to work tomorrow (10 miles), shut it off wait 10 minutes and see if it will start.
Maybe test it at lunch time, and then again when I come home from work.
If we really want to be geeky we can put the old line with the inline fuel filter back on and in theory the problem should come back, don't know if it's worth the tax payers money, hee hee to do so, but we may do it for science.
If this works, then I am guessing a clogged / dirty inline fuel filter? Maybe the particles are so small the filter does not have to look like the bottom of my aquarium back in college to be considered dirty, who knows!?
Old 03-11-2015, 08:50 PM   #1140
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I get the vibe that you may be a bit too short in the tooth for such automotive injuries? JK
Old 03-11-2015, 09:23 PM   #1141
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
Some of those fuel filters have a one-way check valve. Now, I am not saying you put it on backwards, but, um, did you put it on backwards?
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 03-11-2015, 10:13 PM   #1142
77K10Silverado
77K10Silverado's Avatar
Re: Restoring Rusty
Wouldn't that keep it from starting the first time? Not real sure how those work though..
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 03-11-2015, 11:57 PM   #1143
Titomars
Titomars's Avatar
Re: Restoring Rusty
I would think so myself, but since I have never seen one with a check valve in it. I am not sure how they work. I do know those little see through filters are nothing but trouble. I have seen many issues around them over the years.
Best fuel filter I have seen is a K&N fuel filter. Aluminum housing that the housing unscrews to access a cleanable stainless steel screen.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-12-2015, 01:04 AM   #1144
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
This one does not have such a check valve it is just a fine screen inside a glass tube. Also it says IN on one end and OUT on the other so I am 107% sure I installed it the correct way.
Now that I look at it while it is empty there is a bit of residue on the glass looks like someone sprinkled some pepper in there, maybe it just did it's job and cleaned fuel for as long as it could.
Old 03-12-2015, 02:18 AM   #1145
rich weyand
Re: Restoring Rusty
In which case you may have another problem. Have you changed out all the soft rubber fuel lines yet?
Rich Weyand
1978 K10 RCSB DD.
Old 03-12-2015, 03:20 AM   #1146
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
I'm finding that I don't bounce back like I used to.
Old 03-12-2015, 09:30 AM   #1147
Titomars
Titomars's Avatar
Re: Restoring Rusty
Boy, Do I know that song!
Old 03-12-2015, 01:05 PM   #1148
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
yes sir, did that when I dropped the tank a few weeks ago
Old 03-12-2015, 01:08 PM   #1149
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Fuel Problem Update - Looking Good
Made it to work ok, truck ran great, drove in the 10 miles and shut it off, about 30 minutes later he fired right up on the first try.
At lunch time we will make a few test runs and test starts to confirm, but so far Looking Good!
as always a huge thanks to all of those who contributed your input and ideas, very much appreciate it
Old 03-12-2015, 02:11 PM   #1150
77K10Silverado
Re: Restoring Rusty
Good deal!.
Mike B.
