Old 11-21-2009, 07:26 PM   #1151
daverod
SSN 706
daverod's Avatar
Re: Daverods project 66
Originally Posted by ruffrida2005 View Post
Take a lot of pics how your fixing this. I have the same problem.
Thats my fix.
daverod is offline   Reply With Quote
Old 11-21-2009, 07:28 PM   #1152
daverod
SSN 706
daverod's Avatar
Hay Allan I found the button for my electron microscope. About a year latter. Ya I know my welding still sucks.
Old 11-21-2009, 08:22 PM   #1153
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
hey dave i think a bird was in your shop and crapped on your truck
j/k
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-21-2009, 08:41 PM   #1154
Bazooka
Keepin it old school
Bazooka's Avatar
j/k
that was wrong
Bazooka is offline   Reply With Quote
Old 11-21-2009, 08:47 PM   #1155
watahyahknow
watahyahknow's Avatar
it prolly would look better if you welded on a clean surface to begin with and added a little more power/heat less wire feed , it looks like the weld is laying on top of the metal that needs to be welded .... not enough penetration ...... you did use the mig with gas didnt you , that allso helps it should look like it just about flowed intoo the surrounding metal
everyone should be able to weld eventually if they try and know wat to do when surtan things happen mig welding should sound like sissling bacon in a frying pan when its cracling and its too high power or too little wirefeed hissing is to low power to big wirefeed when you set the balance on a couple of scraps youre usually set for the rest of the truck , just keep the small spot blasts around the piece all about the same time each time to get a nice even bead around the piece the welder i used actually had a timer to give spotwelds and it worked verry nice
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-21-2009, 09:16 PM   #1156
daverod
SSN 706
daverod's Avatar
Originally Posted by Bazooka View Post
that was wrong
Ya Wrong, but in a funny way.
Old 11-21-2009, 09:55 PM   #1157
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
I'm with Watahyaknow. You need to reweld it, turn your wire down. I know your not welding with gas because of the way it looks.
But other then that. glad to see some more progress going on the truck. I need to post some stuff on mine!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 11-21-2009, 11:48 PM   #1158
daverod
SSN 706
daverod's Avatar
That was just the first pass. I don't turn the heat up the first run because it's so easy to burn through. Usally after about 3 runs its looks normal.It all gets ground down anyway. Then sprayed with undercoat. On the inside I'll Skim coat the wall with some mud. The floor well get sound matt.
Old 11-22-2009, 12:11 AM   #1159
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
everyone should be able to weld eventually if they try and know wat to do when surtan things happen tig welding should sound like sissling bacon in a frying pan when its cracling and its too high power or too little wirefeed hissing is to low power to big wirefeed when you set the balance on a couple of scraps youre usually set for the rest of the truck , just keep the small spot blasts around the piece all about the same time each time to get a nice even bead around the piece the welder i used actually had a timer to give spotwelds and it worked verry nice
hehe........penetration....hehe
hey dave do i need to come help you weld that
Gage
Old 11-22-2009, 12:26 AM   #1160
ruffrida2005
wow Gage is talking smack.
Paul
Old 11-22-2009, 12:52 AM   #1161
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
im just joking i hope no one will have hard feelings over this im just havin fun
hehe......hard feelings....hehe
Gage
Old 11-22-2009, 01:19 AM   #1162
shrunken66stroker
shrunken66stroker's Avatar
D rod, you're supposed to grind it smooth before taking pics. When you smooth it out it shines so bright and you can't tell what it really looks like. That's my trick anyway. Shine it up and re-post it and I bet you get compliments. Give it a shot.
shrunken66stroker is offline   Reply With Quote
Old 11-22-2009, 02:07 AM   #1163
ruffrida2005
lol shrunken. But it's too late.
Dave I just saved it. Remember the c notch pic you keep posting on mine. I got you back
Paul
Old 11-22-2009, 11:17 AM   #1164
daverod
SSN 706
daverod's Avatar
Thats the truth huh. The only reason I took the picture was because I was so happy I found out how to switch my camera to macro. I was the only thing to take a picture of. I'm not to worried it all grinds down and you never see it anyway. I knew I was going to hear about it. I love the close up though. It makes it look twice as ugly as it really is.Heres what it looked like after I cleaned it up. I wished.
Old 11-22-2009, 11:19 AM   #1165
daverod
SSN 706
daverod's Avatar
Ya He's only 15 so I'm letting it slide. Other wise I would go getto on his a$$$
Old 11-22-2009, 12:54 PM   #1166
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
haha well its good im 15 huh
and that i can weld
Gage
Old 11-22-2009, 01:31 PM   #1167
daverod
SSN 706
daverod's Avatar
Not so bad.
Old 11-22-2009, 01:31 PM   #1168
watahyahknow
Originally Posted by daverod View Post
looks like one of nathans welds all porterbuild stuff looks like that
Old 11-22-2009, 01:46 PM   #1169
Strodder
Daring to be Different
Strodder's Avatar
Use Spearmint Bubble Gum. It gives a smoother look when welding. Seriously you are doing a great job. Dave don't listen to anyone.
And Gage keep the digs coming. It keeps us all on the ball.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 11-22-2009, 03:10 PM   #1170
daverod
SSN 706
daverod's Avatar
Thanks Dennis I'm sure it nothing you hav'nt seen before. Hope to get the rest done today. Spent the morning out at the goat ranch. It's hard work being a goat rancher. Ok Gage lets hear it, and they are goats not sheep. In fact I'm naming the brown one Gage. He's a stud, untill I cut his you know what's off.
Old 11-22-2009, 03:23 PM   #1171
daverod
SSN 706
daverod's Avatar
I hope in like five years from now I can weld like that.
Old 11-22-2009, 04:03 PM   #1172
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
hahahahahahaha
i can.............................NOT
Gage
Old 11-22-2009, 09:32 PM   #1173
Strodder
Strodder's Avatar
Poor Gage
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 11-24-2009, 01:03 AM   #1174
daverod
SSN 706
daverod's Avatar
Finished the floor and sides. Started beating on my cab supports with a hammer and screw driver. More rust. Ordered some cab supports. Looks like I'll have plenty to do this winter. Did I say this truck had no rust? Anybody use the slip over cab supports?
Old 11-24-2009, 01:12 AM   #1175
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Hurry turn it off. J/K .............Practice makes perfect.
Alan's Classic is offline   Reply With Quote
