#1151 |
1 thing at a time is progress.
Re: 198Plus build
Me likey
Alan
Philippians 2:14-16 |
#1152 |
SSN 706
Re: 198Plus build
Better hurry up and get it done before gas hit $6 a gal and you won't be able to drive it. Looks nice.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-09-2011 at 12:22 AM. |
#1153 | ||
Re: 198Plus build
Thanks, I hope so.
Thanks.... Thanks.... Quote:
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl |
#1154 |
Re: 198Plus build
Thanks.........I'll just take off 7 plug wires
#1155 |
Re: 198Plus build
What brake line kit do I need to order for my 65 truck, it has disc brakes and a 1971 12 bolt rear end........Also I'm getting ready to install my trans cross member, I was going to set my engine angle at 4 degrees...Does that sound right....
#1156 |
![]() Join Date: Aug 2009
Re: 198Plus build
It should match the angle of your diff flange at ride height, if your diff is at 4 degrees then set the engine at 4 degrees
#1157 |
Re: 198Plus build
Not much going on with my truck, getting ready to start a big back window swap on it....Here's a project going on at my shop, 1968 Charger 383 car. It's a pretty straight car to start out with, getting new lower quarters and a complete paint job. Car was on Pass Time a couple years ago here in Atlanta.
#1158 |
Rollin' Old Skool
Re: 198Plus build
cool car....so what's happening with the old cab? i assumed you were keeping it since you did all that work...or are you just doing the window swap?
#1159 |
Re: 198Plus build
Just doing the window swap.
#1160 |
SSN 706
Re: 198Plus build
That cab is looking lonely.
#1161 |
Re: 198Plus build
If I ever get caught up, it will get some love
#1162 | |
Re: 198Plus build
Alan
#1163 |
Re: 198Plus build
What's the bed I spent so much time blocking on doing sitting on it's nose.
Alan
#1164 |
Re: 198Plus build
Sneak peek.......Charger coming out of the paint booth tomorrow........Spent a lot of time on this one, it's razor straight. After all priming and blocking was done car went in booth for sealer then 2 coats of base and clear, then brought out and wet sanded. Then received 3 more coats of base and 3 more coats clear.....Wet Sanding and buffing starts soon.
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=346597 https://www.facebook.com/pages/198-C...1434001?ref=hl Last edited by 198plus; 04-07-2011 at 12:01 AM. |
#1165 |
Desert Dweller
Re: 198Plus build
Nice job on the Charger
![]() ![]() I wish I still had my Charger... It was an actual stunt car from The Duke of Hazzard show that I traded my 70 SS Chevelle for back in 84. Boy was I stupid when I was young... You do great work. Wish I was closer to have you paint my truck ![]() Tony Posted via Mobile Device Last edited by AZ66GMC; 04-07-2011 at 12:11 AM. |
#1166 |
Re: 198Plus build
Little progress on my engine, run some factory Big block 375/425 HP fuel lines today.
#1167 |
Re: 198Plus build
Couple more pics of the Charger. Wet sanding and buffing tomorrow.
#1168 |
Re: 198Plus build
that is looking good!!!
![]() bagged 66 longbed build http://67-72chevytrucks.com/vboard/s...d.php?t=449548 my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918 |
#1169 |
Re: 198Plus build
Little update on my trucks progress, not much at all. Was able to finish my power steering brackets and pulleys. Got my new fuel lines run to carb, about time to fire her up !!!! My new Motion valve covers showed up today, I really like the look...
#1170 |
VA72C10
![]() Join Date: Mar 2008
Re: 198Plus build
Those look great on there!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#1171 |
Rollin' Old Skool
Re: 198Plus build
very nice/clean setup! and any progress is good, IMO
#1172 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: 198Plus build
Those valve covers are killer..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#1173 |
Re: 198Plus build
Very nice Ronnie!!!
Alan
#1174 |
Re: 198Plus build
#1175 |
Re: 198Plus build
that looks great, i love detail and it looks as though your a perfectionist to the extreme. exleent work. and by the way the charger is sweet too.
