Old 11-14-2015, 10:58 AM   #1151
Smooth68
Smooth68's Avatar
Re: Slosh Tubz SEMA 2015 Build "BOOSTED BERTHA"
Excellent build!! I'm just recently catching up on this. Hoping to pickup a 64-66 project in my near future
Smooth68's Web Site
WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got??
'68 Short Step - Shaved Body, Soon Bagged - SOLD
Driver-2004 GMC Z-71 Ext-cab
Smooth68 is offline   Reply With Quote
Old 11-14-2015, 10:22 PM   #1152
rmvlt1100
rmvlt1100's Avatar
That is one Beautiful truck!! Not sure a guy should say "Beautiful" or not but I will. I think your next trip should be to the AutoRama in February for the Ridler Award Entry!!!
Outstanding Build
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 11-14-2015, 10:33 PM   #1153
77BBGMC
77BBGMC's Avatar
Impressive, looked even better in person!
77BBGMC is offline   Reply With Quote
Old 11-19-2015, 10:24 AM   #1154
67cheby
67cheby
67cheby's Avatar
Thank you ! awesome !
Outstanding Build
Thank you so much !
I appreciate that , now to get it all finished up ! I cant wait to hear this monster fire up !
67cheby is offline   Reply With Quote
Old 11-19-2015, 10:29 AM   #1155
67cheby
67cheby
67cheby's Avatar
I am about done goofing off, I have to get back to work on it !
We are starting on a fiberglass headliner , I put my son on tape duty. This is my first time to try this so lets see what happens ! I have already screwed up they say I should have put a release agent to keep the glass from sticking to the tape. Worst case scenario I will cut the roof apart and surgically remove the steel headliner from the glass mold ! LOL....live and learn !
Old 11-19-2015, 10:40 AM   #1156
JPutnam
yeah the resin will stick to the tape. you can sometimes pick the tape off, but it will rip a ton and be a pain. if there were any imperfections in the tape, I.E. cuts or gaps, then the resin will be on the actual metal. that wont be pretty. if they are small enough the mold might just pop off with a good amount of tugging. lift a corner of the fiberglass when its ready to come off. spray a bit of air between the two and it will pop off most of the way, if not all the way. I usually just use automotive car wax. if you had put a good amount of wax on top of the tap the glass would come off real easy. Also hairspray works real well for a release agent. coat the whole mold with a thick layer of hairspray. then layup. once the resin cures it will pop off with no issue.
edit: Also if you are planning on making multiple parts off the fiberglass mold you should make it alot thicker. use thicker mat and/or do 5 or 6 layers. did you stiple the resin into the mat with a brush? any light colored area is going to have air bubbles or bridging. take a short hair paint brush(I buy the 30cent 2" and 1" brushes from homedepot and cut the bristles down to be about 1.5in long) and start stipling(poking the fiber with the end of the brush) the whole thing. it will remove the air bubbles and the bridging.
JPutnam is offline   Reply With Quote
Old 11-19-2015, 10:44 AM   #1157
67cheby
67cheby
67cheby's Avatar
I am going to knock down all the high spots and then lay down two more layers of glass and resin and then I will start the fight to release it .......not looking forward to that !
Old 11-19-2015, 10:47 AM   #1158
slammed427
slammed427's Avatar
Bertha is beautiful Mike! Keep it up!
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 11-19-2015, 10:50 AM   #1159
JPutnam
lol yeah its a ton of work. Sometimes I use the clear packing tape over stuff that doesnt need a perfect finish. or for wierd shaped air ducts. resin doesnt stick to the packing tape. Just make a crude foam mold that resembles the correct shape. cover it in packing tape then layup. after it dries poke some holes in the tape and dump in some acetone. it eats the foam. then pull out the tape and you have a relatively smooth inside of an air duct.
Old 11-19-2015, 10:52 AM   #1160
JPutnam
also I never really worry about the high spots. they just add strength to the mold. Unless this fiberglass is going to be the actual "finished part" but I would still probably just leave the high spots until all the fiberglassing is done. then knock it all down in the end.
looks like a fun project. Makes me want to make something.
Old 11-19-2015, 10:53 AM   #1161
Bomp
Bomp's Avatar
I use bee's wax as a release agent.
Bomp is offline   Reply With Quote
Old 11-19-2015, 04:39 PM   #1162
watahyahknow
watahyahknow's Avatar
wat i seen used mostly is aluminium tape over normal package tape , the package tape releases from he metal pretty eazy the aluminium stuff stays on the poliester
you could just take the piece out
sand the rough side up a little , cover it with a layer of thin foam spray gleu on again and then put the cover material on
the shell is made to fit the roof anyway so it should go back in pretty accurately
to hold it up you could screw the handholds through it intoo the sheetmetal of the roof structure over the doors and behind the roof light in the middle
if you make the mould long enough and thin enough you might even flip the rubber window seal from the front / rear window and the doorseals over it once its in
if youre not sure of the roof will bow out over time you could glass is a few strips of metal across the whole width
with the foam covering you prolly whont see it in the cloth or leather covering
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-19-2015, 08:32 PM   #1163
clemdaddy
clemdaddy's Avatar
need doors? got doors. I want a day or two smooth out the inside and they'll be ready.
clemdaddy is offline   Reply With Quote
Old 11-30-2015, 10:24 PM   #1164
sduckworth13
sduckworth13's Avatar
Wow! Wow! Wow! Your truck turned out awesome Mike. I like everything about it.
Scott
sduckworth13 is offline   Reply With Quote
Old 11-30-2015, 10:32 PM   #1165
UKNOWME
UKNOWME's Avatar
Sooooooooo...... How's it going?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 12-02-2015, 10:47 AM   #1166
67cheby
67cheby
67cheby's Avatar
Ok so I am finally getting motivated to get back on her !
We popped the fiberglass headliner out of our mold.....that makes it sound easy, it wasn't ! LOL , since I didn't use any release agent it was bonded to it pretty good. I cut the roof all apart and then just started working around the edge of the headliner loosening the tape from the roof finally got it all released. Next I took the headliner to work and pressure washed all of the blue tape off that was stuck to the top
Old 12-02-2015, 10:50 AM   #1167
67cheby
67cheby
67cheby's Avatar
Now on to the dash, trying to make something out of the stock dash with a custom look.....I still have a long way to go . It will have a removable dash cap that wraps down the front of the dash and gives it some more 3d shape it wont just be a flat panel. Anyway here is the beginnings
Next up a trip to Clems to rob a junk dash and get a set of doors to mock up some fiberglass door panels off of !
Old 12-02-2015, 11:47 AM   #1168
Bomp
Bomp's Avatar
Will you be keeping the dome light in the new roof inner panel?
Have my total attention on this. Looks good.
Old 12-02-2015, 12:15 PM   #1169
67cheby
67cheby
67cheby's Avatar
Yes but I will be using a nicer aftermarket light from Trique Manufacturing
Old 12-02-2015, 05:34 PM   #1170
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
curious on how the roof panel is going together/will work, this might be an option for the headliner in my crewcab....
Old 12-09-2015, 10:23 AM   #1171
67cheby
67cheby
67cheby's Avatar
well here is a little more progress trying to build a dash for Boosted Bertha . I want to make a home that is deserving for all the cool parts from Dakota Digital, Resto Mod Air, Clayton Machine Works and Trique Manufacturing
I am trying to make every part bolt together to make it easier to upholster once we get back to that stage
disclaimer #1. The metal work is quick metal work that will be skim coated with bondo and the foamed over the top of that before the leather, so I am not spending a lot of extra time trying to metal finish it
Old 12-09-2015, 10:28 AM   #1172
clemdaddy
clemdaddy's Avatar
Man... thats a bunch of work. Looks good Mike, keep after it buddy.
We want to visit your place to check it out and get some of the best Mex food on the planet.
Old 12-09-2015, 11:36 AM   #1173
67cheby
67cheby
67cheby's Avatar
Thanks Clem, I was about to call you I might come over Sunday if you are going to be around so I can bring back your sander and come steal a dash
Old 12-09-2015, 11:43 AM   #1174
67cheby
67cheby
67cheby's Avatar
it fit In super nice !
Old 12-09-2015, 12:16 PM   #1175
mjh1965
mjh1965's Avatar
Mike that's a lot of work , but it's all in the game of modding, but it looks awesome . Making something that also comes apart makes the job and design a lot harder to do . I know this because of my job , a lot of the stuff we build has to be removable so an able bodied person can still drive the vehicle .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
