Old 09-05-2006, 04:16 PM   #101
PBFAB.COM
PBFAB.COM's Avatar
Re: Dropmember in a 69 C10
I will have to get back to you with pics of the Dropmember, with the rack and pinion installed, later in the week... or the beginning of next.
I have attached a couple pics of the Dropmember C4 (uses C4 Corvette Suspension). It is near completion... I am impatiently awaiting a rack and pinion I ordered a few weeks back . Once I get the rack I can finish up the piece, and build my fixtures for production. It is set-up to have a 5" ride height with a 27" tall tire. The tire in the pic is a 255 35R20. It will need to be ran with a Shockwave or coil-over.
PBFAB.COM is offline   Reply With Quote
Old 09-05-2006, 05:37 PM   #102
valleycustom
Please become a site supporting vendor to advertise a business in your signature. you can do so here
valleycustom is offline   Reply With Quote
Old 09-05-2006, 06:29 PM   #103
SCOTI
SCOTI's Avatar
Is the 2nd pic the estimated ride height?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-05-2006, 07:17 PM   #104
PBFAB.COM
PBFAB.COM's Avatar
2nd pic is at 6", that's one inch above the ride height. The first pic is at full compression.
Old 09-05-2006, 09:10 PM   #105
tom71
what happened to flint mi
tom71's Avatar
whats the c 4 drop member gonna cost?
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 09-05-2006, 09:56 PM   #106
PBFAB.COM
PBFAB.COM's Avatar
It'll run $1500 WITH a custom width power rack. Comes with all the same stuff as the regular Dropmember kit. C4 suspension components can be had... brakes, spindles, hubs, and arms for less than a set of Strong Arms! You do have to use Shockwaves, if you're going air, so that makes the overall cost of the kit a little more spendy, but not too bad!
Old 09-05-2006, 11:02 PM   #107
valleycustom
I have the shockwaves and everything else.... Now all I need is the dropmember.
Nathan's shop is one of the best shops I've ever worked with. He sends updates all the time on how things are going. I'll defently be buying more of these.
Old 09-05-2006, 11:57 PM   #108
tom71
tom71's Avatar
any plans for irs vette crossmember kit?
97 fiance mobile
Old 09-06-2006, 01:15 AM   #109
PBFAB.COM
PBFAB.COM's Avatar
It's going to be a complete back-half... it's in the works.
Old 09-06-2006, 01:29 AM   #110
dstrbd71
dstrbd71's Avatar
Thats what I cal a front end SWAPPAGE!!!!!!!!
Very nice work I must say!
1967 Chevy Stepside Shortbox
1995 Chevy Silverado 4X4
1956 Chevy 210 post Delray
dstrbd71 is offline   Reply With Quote
Old 09-06-2006, 12:46 PM   #111
XXL
Seņor Member
XXL's Avatar
There will be lots of straight-line driving on that thing
XXL is offline   Reply With Quote
Old 09-06-2006, 01:34 PM   #112
PBFAB.COM
PBFAB.COM's Avatar
Not quite sure what the "EEK" is meant for... it will handle corners just as nicley as it will go straight.
Old 09-06-2006, 02:07 PM   #113
XXL
Seņor Member
XXL's Avatar
You indicated that pic #2 was 1" _ABOVE_ ride height. As shown, you're well into the tire... so how do you turn?
Old 09-06-2006, 03:05 PM   #114
PBFAB.COM
PBFAB.COM's Avatar
With the steering wheel! All joking aside... I know you're not the biggest fan of the front track width being "too narrow"... and I too think there is a point of it being "too narrow". The track width is "narrow enough" to allow the wheels to be turned without contacting the fender and allows for 3" of compression at ride height before the tire would contact. The camber curve built into the design is much more aggressive than the stock geometry on these trucks, this too pulls the top of the tire inward as the suspension compresses, creating even more clearance. I have attached some pics of clearances. (My BIGGEST pet peave is tires rubbing... and I design and build things with this in mind )
One point of clarity... this particular Dropmember C4 is going to a customer, and it is set up for a 5" ride height with a 27" tall tire per his specs. The Dropmember C4 will also have a one inch higher ride height available. The one inch taller ride height (6")will not allow the frame to set on the ground... it'll have a 1/2 inch to spare.
Old 09-06-2006, 03:12 PM   #115
jimmydean
jimmydean's Avatar
Damn PB, you do some wicked work. I wish you were closer, but I guess it's good that you're not because I'd be BROKE!
jimmydean is offline   Reply With Quote
Old 09-06-2006, 03:27 PM   #116
PBFAB.COM
PBFAB.COM's Avatar
Thanks for the compliments Jimmy Dean!
One more quick note... The wheel is a 20X8.5 with an 18mm offset; that equates to a 5" backspacing.
Old 09-07-2006, 12:09 AM   #117
SCOTI
SCOTI's Avatar
Thanks about the pics. I can wait if you can get some. I really like the C4 Dropmember (that will most likely be the way I go w/mine).
If the rack is custom, any chance on choosing power or manual (JIC)?
Do you have a supplier on used C4 stuff?
Once again . . .... awesome design & I look forward to seeing more of your ideas come to life.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-07-2006, 12:46 AM   #118
PBFAB.COM
PBFAB.COM's Avatar
The rack can be either power or manual... it has a custom width center to center on the inner tie rod length. It's still a MII design, just lengthened in the middle a couple inches. If you go manual you can also choose either a short or long pinion... that's the steering shaft that comes out of the rack.
For the C4 components, I do have a good source. Just PM me when you want to do some window shopping or actual shopping and I will get you the info... really reasonable prices.
Old 09-07-2006, 09:39 AM   #119
layedoutnoma
layedoutnoma's Avatar
what brand is the rack? i need a custom width one for my c10..
Meticulous Fabrications
Milford Michigan
layedoutnoma is offline   Reply With Quote
Old 09-07-2006, 11:33 AM   #120
XXL
Seņor Member
XXL's Avatar
Makes sense. One problem with a tighter arc in the control arms, however, is that you get up on the edge of the tire very quickly. That's not such a big deal when you're just dumping the bags in the parking lot, but you get hit with this same issue when you're driving... so you get lots of wear on the corner of the tire, and the bump steer can get pretty aggressive. I think the real "solution" is a complex cantilevered upper A-arm setup, that gives you the "tuck" you have with your tighter geometry, but that keeps the wheel vertical center more nearly vertical. Let me know when you get that engineered out
Old 09-07-2006, 12:05 PM   #121
PBFAB.COM
PBFAB.COM's Avatar
I have a couple of "complex cantilevered" designs along with both push and pull-rod style mechanisms... only problem with those are the cost... if you want to pay $10K for a tricked out suspension or $20K for a tube chassis jump in line... I am booked out for a year. Only thing is the idea behind a production piece is affordability and quality at the perfect blend.
As for the geometry on the Dropmember C4... no worries about bumpsteer, there is less than .1 degree toe through the entire suspension cycle!!! That's a tighter tolerance than production vehicles. As for camber, It does follow a tighter arc... that's the idea... performance suspension, such as this, requires more camber to allow improved handeling and cornering. Let's say under "normal" driving conditions the wheel will compress 2-2.5" (that's pretty realistic) well camber gain at 2.25" is 1.225 degrees camber... not a ton, enough for a drast improvement from stock, and it won't be any harder on the tires than let's say a C4 Corvette . Will they wear faster than stock geometry would allow... probably a little... if you're taking adavntage of the increased performance!
Old 09-07-2006, 01:32 PM   #122
XXL
Seņor Member
XXL's Avatar
I understand the expense, and that being the limiting factor in (anything) a production piece. And I appreciate the quality of your work, and you being in demand. What I'm not sure of is whether the market for dropmembers and related is actually "performance" oriented. Maybe it's just this board... but most seem to just want low... not better cornering, etc. If they can get that for free, they won't turn it down, BTW .
Having said all that, I may have to start saving my pennies for a dropmember of my own. Limiter on my hooptey right now is the trailing arm xmember, but once I resolve that, I'll be back to the same LCA problem as everyone else.
Old 09-07-2006, 01:52 PM   #123
PBFAB.COM
PBFAB.COM's Avatar
The nice thing about the Dropmember(s) is that it caters to both these markets. Those who want LOW can purchase either one and get it, while those who want PERFORMANCE can buy the Dropmember C4 and get theirs... slap some coil-overs on this thing and look out! And of course, those who want PERFORMANCE and LOW can buy the Dropmember C4, throw some shockwaves on it and have the best of both worlds.
Old 09-07-2006, 08:36 PM   #124
Rokcrln
Rokcrln's Avatar
So we can go low, drive faster into the turns and keep it under control doing it and if the down side is a new set of tires every now and then oh well! I find that more than worth it. Right now I have three sets of tires that were changed out for different sizes not because they were worn. I would rather wear them out passing the Tuners any day.
This has me thinking a 2wd 70 with C4 stuff might be fun
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 09-07-2006, 09:10 PM   #125
tom71
tom71's Avatar
how bout a blazer with c4 stuff ??? thats gonna be my next project !
97 fiance mobile
