05-11-2008, 05:32 PM | #101 |
PROJECT 7DEUCE
Re: Tri-Pro's "Project GPW"
Trucks looking good keep up the good work...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-11-2008, 06:00 PM | #102 |
You have to remove them to get the cab floor up into location, since the cowl was getting replaced, it was just easier. Will mount them up later, the builder is alittle slow
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-11-2008 at 06:01 PM. |
05-12-2008, 06:57 PM | #103 |
could you take some better pics of your repo door fitment i have been concidering buyuing them but im weary on fitment
05-23-2008, 12:17 AM | #104 |
Here's a pic of Jon's headers,sweet. I think he said they were off a passenger car, they seem to have the rite fit, higher up in the frame, now he can run his exhaust along the frame rails. For all you guys dragging metal
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-23-2008 at 12:19 AM. |
05-23-2008, 12:23 AM | #105 | |
Damn Yankee
The headers are another set of Thorleys for GM passenger cars. They're mid-length and fit perfect. There's good clearance on the mounts, frame, etc. and I can't see a reason NOT to use these on lowered trucks. Last edited by jb4short; 05-23-2008 at 12:25 AM. |
05-23-2008, 12:34 AM | #106 | |
Maybe I should stay away more often, you'll get something done and we won't BS as much LOL
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 05-23-2008 at 12:35 AM. |
05-24-2008, 06:15 PM | #107 |
Damn Yankee
This morning I installed the Early Classic super track bar, the lower shock relocation mounts, 6" lowering springs and reinstalled the shocks.
If you're an idiot like me read (or should I say "Heed") the part of the directions that says to jack the frame to take the weight off. While bracing myself by holding the top of the axle tube I reached under and dropped the nuts off the "U" bolt......apparently that's not too bright. "Frame, axle tube....axle tube, frame". It smarts. Fortunately the powder coating kept it from dropping slowly as the nuts came off and broke free all at once dropping the frame in one fell swoop. Last edited by jb4short; 05-24-2008 at 06:15 PM. |
05-24-2008, 06:19 PM | #108 |
so Jon is the reason we cannot have nice things!
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
05-24-2008, 06:20 PM | #109 |
Can we get a pic with the new 6-inch drop, lets see the rake.
05-24-2008, 06:41 PM | #110 |
Damn Yankee
new rake:
clearance panard bar and shock relocator pass side driver's side complete with dust |
05-24-2008, 07:48 PM | #111 |
It looks like it's going to be a nice truck, and a nice way to remember a friend. I'm sorry if I missed it, but what are you planning on doing with the truck once it's finished?
Anyhow, I hope that everyone remembers that there is going to be an additional 800 - 900 lbs put back on there once the cab, seat, gas tank, steering column, tailgate, and bed floor are installed, pushing the back end down even further. That may be too much of a drop. Just a thought to consider, if it hasn't been yet.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 05-24-2008 at 07:49 PM. |
05-24-2008, 07:59 PM | #112 | |
Damn Yankee
It's only a 6" drop in the rear and 4 1/2" in the front. I will have to c-notch the frame but the kit is not here yet. |
05-24-2008, 08:07 PM | #113 |
Cool, yeah, with weight it will sit freakin perfect! That looks much better Jon.
05-24-2008, 08:13 PM | #114 |
got any pics of the hand?
05-24-2008, 09:37 PM | #115 |
Uh oh.....
05-24-2008, 09:37 PM | #116 | |
That will look good once everything is put together.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
05-24-2008, 09:52 PM | #117 |
Damn Yankee
05-24-2008, 10:02 PM | #118 |
Did it hurt right away or after a few moments?
05-24-2008, 10:07 PM | #119 |
Damn Yankee
05-24-2008, 10:08 PM | #120 |
Damn Yankee
05-29-2008, 04:23 PM | #121 |
Any pics???
05-29-2008, 05:09 PM | #122 |
Damn Yankee
05-29-2008, 05:18 PM | #123 |
sucked huh? Is that the one with the enlarged driveshaft loop and exhaust cutouts?
05-29-2008, 07:09 PM | #124 |
Damn Yankee
05-29-2008, 08:57 PM | #125 |
Damn Yankee
I should explain that the part is fantastic- the difficulty in the installation came from what looks like prior frame damage (minor). I was able to get things "Tweaked" back where they should be but it was kicking my !#@$! for a bit. The upside is that I lost about 18lbs. of water weight struggling with it |
