Old 10-01-2012, 12:45 PM   #101
jephs422
Re: Here's those pics of the under dash pedal assembly
Here's a few images:
Triple remote reservoir for dual master cylinder and single clutch. Please note that these are NOT open vented systems. FULLY sealed, we add the bellow/diaphragm to the reservoir and you get rid of the one in your master cylinder. Systems that are vented to the atmosphere will collect moisture. Cheap units can be had for less, but they are NOT worth it.
Our reservoirs are ported on the bottom as well as the back. You will plug the set you decide to not use. This allows you to run your lines through the firewall, or down it.
Our billet master cylinder lid is ready to use for a remote system, or you can drill/tap your existing lid. Just remember, when switching to a remote reservoir style system, you are overfilling your master cylinder. We highly recommend using our lid because of the tighter fit and use of the OEM gasket for a superior seal.
I don't remember if I ever posted dimensions, but here ya go
dimensionally, the dual with clutch is the same as the single.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 10-01-2012, 07:17 PM   #102
jmedero
jmedero's Avatar
Can you use the Cpp all in one master? The chrome one with the built in prop valve?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 10-01-2012, 08:37 PM   #103
Scottshotrods
Yes you can but there is no need to go with the chrome one you will not be able to see it under the dash
Justin
Scottshotrods is offline   Reply With Quote
Old 10-02-2012, 06:06 PM   #104
crossfire84
crossfire84's Avatar
do you have a thru the firewall brake and clutch pedal assembly ?
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 10-07-2012, 10:20 AM   #105
Last_Paladin
How about a remote billet cover for the Wildwood billet Master Cylinders?
I don't feel like using an Allen wrench to check my brake fluid every time.
Last_Paladin is offline   Reply With Quote
Old 10-08-2012, 11:58 AM   #106
Scottshotrods
You can send us your Wilwood master lid and we will drill in two holes and tap it for you.You can run some 1/8 pipe an fittings out of your lid.You have now a remotoe lid after this is done.
Price you will be looking at will be $30.00 to do this for you.Plus shipping
Justin
Old 10-08-2012, 12:02 PM   #107
Last_Paladin
Justin
I can do that myself. That's not what I want, since it doesn't look professional. It has Wildwood all over it.
Old 10-08-2012, 01:06 PM   #108
Scottshotrods
If you do not want that and want us to machine one for you.We can do this for you no problem at all.
You can call me at the shop at (805)485-0382
Justin
Old 10-08-2012, 01:06 PM   #109
Scottshotrods
Yes we do you can call us at the shop at (805)485-0382
Justin
Old 10-09-2012, 09:52 AM   #110
jephs422
I don't have a dimensioned image, but I'm sure I can go get a tape and get you one this week. I don't have any pics of the brake/clutch unit, but I'll see if I can't go shoot one.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 10-11-2012, 06:03 PM   #111
C0UCH
Tagging for later. Will buy when I redo my brakes.
C0UCH is offline   Reply With Quote
Old 09-15-2015, 11:41 AM   #112
83c10wit454
83c10wit454's Avatar
Anyone have any good solutions to using this setup and still having windshield wipers?
83c10wit454 is offline   Reply With Quote
