Old 05-06-2009, 08:27 PM   #101
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Project "Vertically Challenged"
The pics of the bracket above. That's not the way to do it. This is.
Full crank left, aired down.
Full crank right.
Looks like it should work well. A much better appearance. It's bolted to the balljoint not the bag plate. The brake line travels with the control arms. Thanks for the tip Keith. You must have played with these trucks a little.
70k52wd is offline   Reply With Quote
Old 05-06-2009, 08:38 PM   #102
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks good. That's just what my little brain came up with. I'm sure there are better ways,... but it was good enough for my rusty blazer.
Keith
Convert to disc brakes.
Old 05-07-2009, 06:38 AM   #103
VA72C10
VA72C10
VA72C10's Avatar
Looks like that will work well...now when am I gonna get to see this thing on the road???
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-07-2009, 10:14 AM   #104
70k52wd
Blaze-Air
70k52wd's Avatar
I keep telling my wife I'm almost done. She said she is sick of me saying that. I'm getting tired of believing it also.
I've been changing out some grade 5 hardware for grade 8 stuff. So yea, I guess I'm just messing around right now.
Great news, I found my exhaust guy. I lost contact with him for awhile. He is awesome. No side dumps for me. At least I hope no side dumps.
Now, if I had a spread bore carb to borrow, I could figure out if my carb is trashed or not...Once I fix that, well, I won't say it, But, I'm almost something. I have 8 rims to sand prime and paint also. Just kinda tinkering around stuff is left. I'll get it there one day.
Old 05-07-2009, 11:46 PM   #105
VA72C10
VA72C10
VA72C10's Avatar
Well, you better get yourself in gear or you're gonna finish it up just in time to put it back in the garage for the winter
Old 05-07-2009, 11:48 PM   #106
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i really like that brake line idea. I was trying to come up with a solution for that issue on my '50 today. Guess i just found the answer
IvelDesigns is offline   Reply With Quote
Old 05-14-2009, 09:22 AM   #107
70k52wd
Blaze-Air
70k52wd's Avatar
HaHa, Funny guy you are...
Give the credit to lolife99, he practically built the truck over the internet. I only swung the hammer.
I can't believe I didn't see these post until today. I must be busy.
I have a carb adapter I will try, maybe it'll run by the end of week. If so, then I just need the exhaust dealt with. Although, we all know your never really ever done. It just moves to the drive it, fix it phase.
Old 05-14-2009, 11:06 AM   #108
lolife99
lolife99's Avatar
Sent you a PM.
Keith
Old 05-24-2009, 09:21 PM   #109
70k52wd
Blaze-Air
70k52wd's Avatar
I finally finished the rim painting. Well 6 of them anyhow. The last two are on the rear. I'll paint them later on.
I had to redo both sets. First set, I didn't get the gloss I wanted. Second set, the Argent silver just didn't look right. I like them a shade or two darker to contrast with the trim rings and center caps.
Here is a pic of the wrong color. plasti-kote p/n 621, Argent silver.
Here are the pics of them painted plasti-kote p/n 618, Steel.
Those are the 6.5in van rallys. They really tuck in well. Gives the truck a refreshing new attitude. I love it. I can now touch the entire top of the tire. I couldn't before with the 8in rallys, they rubbed the outer wheel well edge, not even close now, same 235/60 tire.
Here's a pic with the former front 8in rallys.
I think it went lower with the new rims. My front tag frame is now about an inch off the floor.
I also put a re man Summit Rochester Q-jet on. Fired right up, choke set, warmed up, choke pulled off. It just needs a tweaking to the carb and tune up.
So I need some valve cover gaskets.
And now I need to figure out a minor electrical issue I have with the AirPod display. I noticed that when the motor is running above 500-600 rpm. The display screen disappears. It comes back on as soon as low idle is reached. All the functions still work. I have it wired to direct battery for the main hot. The memory is at a keyed source. It functions 100% normal with motor off, with either acc keyed, or ignition keyed.
Seems like when the alt get's enough juice flowing to the batt, that where my problem may be.
I have an iffy battery. It works, but I need to do a load test. I've seen low charged batts do weird things to electrical systems before.
Now on to exhaust. I need one. That's later on.
I think I'm ready for a first drive around the block.
I have a ton of clean up to do. I'll post some pics later this week(pending rain)when I pull it out of the garage.
Old 05-24-2009, 09:34 PM   #110
lolife99
lolife99's Avatar
Hey Charlie,... LOOKS GOOD!
I like the look of silver ralleys. How about some outside pics?
JUst a thought,... shouldn't your wiring be the opposite of what you have?
Main hot on the ignition switch and the memory off of the battery? Maybe I just read it wrong.
Anyway,... nice to make some progress. I bet you can't wait to drive it.
Keith
Old 05-24-2009, 09:48 PM   #111
70k52wd
Blaze-Air
70k52wd's Avatar
It wouldn't surprise me at all. I'm looking now.
Old 05-24-2009, 11:12 PM   #112
VA72C10
VA72C10
VA72C10's Avatar
Looking good...I am looking forward to the pictures in the daylight
Old 05-25-2009, 11:44 AM   #113
70k52wd
Blaze-Air
70k52wd's Avatar
Well I just came in to tell y'all. I just drove Blazer around the block.
My next door neighbor thought I was doing brakes this whole time. Then I dropped it for him. His look was worth it all.
I need to do a MAJOR tune up. It runs a 100% better than it did. It can run better though.
Although my drive was brief. It feels totally different than before.
I'll get some pics later this week. I need to shine it up first.
Old 05-25-2009, 12:22 PM   #114
70k52wd
Blaze-Air
70k52wd's Avatar
O.K. So I lied, I decided to put a teaser pic up.
Neighbors 56 or 7 in the background. I can't remember how to tell those years apart.
Old 05-25-2009, 04:07 PM   #115
Rokcrln
Rokcrln's Avatar
Looks good!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 05-25-2009, 05:29 PM   #116
VA72C10
VA72C10
VA72C10's Avatar
sweetness!
Old 05-25-2009, 06:31 PM   #117
lolife99
lolife99's Avatar
Nice teaser pic. Looks good.
Keith
Old 05-25-2009, 06:48 PM   #118
70k52wd
Blaze-Air
70k52wd's Avatar
Thanks guys. I just finished cleaning the first layer of interior crud. Came out nice.
Is it just me, but when I took it for a spin today it felt real tight. I remember a spongy feeling with the spring suspension. I was going maybe 20mph, and went maybe 1.5mi. But very tight feeling. I guess that's good.
Old 05-25-2009, 07:02 PM   #119
lolife99
lolife99's Avatar
No matter how great your truck looks,... you should be most proud of the fact,... that you did it yourself. Hmmm,... now when are your getting a suburban to bag?
Keith
Old 05-25-2009, 10:01 PM   #120
70k52wd
Blaze-Air
70k52wd's Avatar
Yeah I wasn't sure at first of what I was getting into. It seemed easy enough when I'd look at some threads. Some things I found to be down right frustrating. It was a challenge for me. But fun all the way.
I'd like to have a Suburban to play with. Prefer 67-68.
Old 05-26-2009, 07:42 PM   #121
70k52wd
Blaze-Air
70k52wd's Avatar
Washed up the Blazer. Here are a bunch of pics. If you are dial up, go get a snack.
The rear isn't at full dump due to exhaust. Working on that.
I'll have a few more pics up tomorrow with black rims and different sized tires. I am real curios how those will look. I think maybe, real good. We'll see. I'm not going to put trim rings on at first. I will have to contemplate it for a while.
Old 05-26-2009, 08:07 PM   #122
70k52wd
Blaze-Air
70k52wd's Avatar
More pics. Sorry they're so big.
Old 05-26-2009, 08:12 PM   #123
70k52wd
Blaze-Air
70k52wd's Avatar
More.
Old 05-26-2009, 08:44 PM   #124
VA72C10
VA72C10
VA72C10's Avatar
Man, your baby cleaned up good
Old 05-26-2009, 08:45 PM   #125
VA72C10
VA72C10
VA72C10's Avatar
Your hard work was DEFINITELY well worth it. Looks SICK!!!
I think the black rims are going to be the final touch. I'd vote the smaller trim rings like on the front with the black for just a little bling and "pop" against the tires.
