Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 02-16-2013, 10:07 PM   #101
turp mcspray
turp mcspray's Avatar
Re: New member from the Black Hills
I made up a new one and welded it in. Now I can get back to mounting the body.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 02-16-2013, 10:10 PM   #102
turp mcspray
Body mounted.
Turp Mcspray
Old 02-16-2013, 10:14 PM   #103
turp mcspray
A few pics of pieces before they get removed, and some more rust that needs fixing.
Turp Mcspray
Old 02-16-2013, 10:18 PM   #104
turp mcspray
A little more rust that was under a tub, and some shots of the original Ochre, on the bedsides. Did I mention how much I HATE ochre? LOL!!
Turp Mcspray
Old 02-16-2013, 10:24 PM   #105
turp mcspray
Got the rear floor pieces welded in. Also found some rust in the bottom of a floor rib, and the hat channel that is welded underneath of it. I figured I had better remove it, to get rid of all the crust.
Turp Mcspray
Old 02-16-2013, 10:28 PM   #106
turp mcspray
Epoxy on the bottom of the floor, and rocker boxes.
Turp Mcspray
Old 02-16-2013, 10:31 PM   #107
turp mcspray
I also sealed all of the seams and undercoated.
Turp Mcspray
Old 02-16-2013, 10:39 PM   #108
turp mcspray
I found a little pinhole in the cowl. After cutting out a small spot, I decided to remove the whole area. I'm glad I did, because it wasn't pretty. Water had gotten down in between these two pieces of metal, and caused a good deal of rust to form. I ended up also removing the inner support brace, so I could blast it completely clean, as well. One wheel tub needed a corner replaced, due to a little rust.
Turp Mcspray
Old 02-16-2013, 10:42 PM   #109
turp mcspray
Finally made it to the booth, for some epoxy! Another milestone for my build!
Turp Mcspray
Old 02-16-2013, 10:46 PM   #110
turp mcspray
Few more booth pics.
Turp Mcspray
Old 02-16-2013, 10:49 PM   #111
turp mcspray
I'm going to let it set overnight, and then spray a little primer surfacer on tomorrow.
Turp Mcspray
Old 02-17-2013, 08:38 AM   #112
swyfor5
swyfor5's Avatar
Wow, looking good! Nice pic's of your progress!
swyfor5 is offline   Reply With Quote
Old 02-17-2013, 11:04 PM   #113
BLUE THUNDER
BLUE THUNDER's Avatar
Wow!!!! You are goin all out on this build.
BLUE THUNDER is offline   Reply With Quote
Old 02-18-2013, 08:03 PM   #114
thor
thor's Avatar
She's gonna be too nice to wheel!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 02-18-2013, 10:39 PM   #115
turp mcspray
I made it to the shop Sunday, and got the rest of the primer sprayed. My goal is to spray the bottom side next weekend, and hopefully the firewall and inside, the next weekend. We'll see what happens. I'm REALLY excited to see some color!
I'll still take it out in the woods, but no more rocks. At least not any big ones! LOL!
Turp Mcspray
Old 02-18-2013, 11:20 PM   #116
Jdubs71
Jdubs71's Avatar
Just went through your build thread nice work. I noticed you used a later model rear axle. I did the same thing and have been waiting to re weld the spring perches. Any advice on the perch widths and pinion angle when rewelding the perches.
71 K5, AC/Tilt, 4" lift 33" tires
5.3L/4L60E/NP 205 (Under Construction)
05 Dodge 2500 4x4 5.9 Cummins (Daily driver)
"Common sense is not so common"
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=555879
Jdubs71 is offline   Reply With Quote
Old 02-19-2013, 10:28 PM   #117
turp mcspray
With my lift, I had to use some shims to set the pinion angle. So when I set up the new rear, I set the perches at the needed angle to not need any shims. If your blazer is not lifted, set the angle same as your original ones were. I also boxed in the ends of my perches, to add some strength, since I have bent them in the past. Ideally your pinion angle should match the angle of your transfer case. Unless you run a cv joint, then the pinion should be the same angle as the driveshaft, minus a couple to allow for axle rotation.
Turp Mcspray
Old 02-19-2013, 10:52 PM   #118
Jdubs71
Jdubs71's Avatar
Yeah I guess I need to wait until I mount my transfer case to make sure I have the propper angle. Do you know if not having the body on the frame will affect pinion angle once it is set down on the frame? My body is off getting painted and I'm trying to get this chassis rolling before its done.
My build thread
Old 02-19-2013, 11:38 PM   #119
SeventyOne
Does the weight of the body need to be on before measure driveline angles and welding in the perches?
SeventyOne is offline   Reply With Quote
Old 02-20-2013, 11:10 AM   #120
turp mcspray
Yes, you need to have the weight on the chassis, or it will change. Before I took my blazer apart, I took a measurement from a hole in the side of the frame, to my rear end. After the body was removed, it changed by several inches. When I set up my new rear end, I compressed the chassis and rear with some ratchet straps, to the old measurement, set my pinion angle, and tacked welded the perches.
Turp Mcspray
Old 02-20-2013, 12:52 PM   #121
SeventyOne
Genius!
Old 02-24-2013, 07:44 PM   #122
turp mcspray
It started out as a simple engine swap, and drive it for awhile. But I couldn't stand the thought of having to look at that Ochre dash. (no offense!). I figured I could spray the dash and inside with some black epoxy. One thing led to another, and here we are!
Turp Mcspray
Old 02-24-2013, 07:53 PM   #123
turp mcspray
Yesterdays progress.
Turp Mcspray
Old 02-24-2013, 07:56 PM   #124
turp mcspray
As long as the dash and firewall sand out ok, I'm hoping to get the firewall and inside of the tub, painted next weekend!
Turp Mcspray
Old 02-25-2013, 11:18 AM   #125
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks like a brand new part from GM.
hgs_notes is offline   Reply With Quote
