Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-30-2016, 11:22 PM   #101
Captainfab
60-66 Nut
Re: '60-'62 Power Brake Booster Adapter Bracket
What are your capabilities? Do you have the means to weld it properly? If not here is another method.
http://www.67-72chevytrucks.com/vboa...d.php?t=564518
Originally Posted by harleychop View Post
Anybody have pics to show hoe you mated the brake pedal pushrod to the power booster?
Old 05-18-2016, 04:51 PM   #102
reed62
reed62's Avatar
Originally Posted by Captainfab View Post
Here is the newest version of the power brake booster adapter bracket that I've been making since 1993. This bracket is fabricated from laser cut 10ga mild steel and fits 1960-62 Chevy and 1960-63GMC Pickups, Suburbans and panels and is 100% bolt on using holes already in your firewall. The booster side of the bracket has a 3 3/8" x 3 1/2" hole pattern. Boosters with this pattern are commonly found on S10's and full size pickups, Suburbans, Blazers and Tahoes from 1988 to at least 1998. You can also find compatable boosters on early to mid 70's Impala's. Of course you will have to join the booster pushrod to your stock MC pushrod that attaches to your brake pedal. This can be done by either threading both ends and using a coupling nut, or by just welding them together once you determine the correct length.
I have had the original version ('63-'66) of this bracket on my '66 Suburban and have driven over 120,00 miles with no issues. I have also installed these on a couple of local pickups with good results as well. If you are wanting to add hydroboost to your pickup, Suburban or Panel I also offer a mounting plate for the hydroboost HERE
The price on the bare steel brackets is $55.00 plus a flat $12.35 shipping in the US. If you are located elsewhere contact me for shipping charges. You can also get this bracket in a satin black powder coat for an additional $6.50. Mounting hardware is included.
Hey Capt Fab,
I need to purchase one of these brake booster brackets for my 62 truck. Let me know how to do this...
Randy
reed62 is offline   Reply With Quote
Old 05-18-2016, 11:22 PM   #103
Captainfab
60-66 Nut
I will send you a PM with ordering and payment info.
Originally Posted by reed62 View Post
Hey Capt Fab,
Randy
Old 08-08-2016, 12:48 AM   #104
Captainfab
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
Old 10-16-2016, 10:55 PM   #105
Classic v6 GMC's
Classic v6 GMC's's Avatar
PM me payment info and total for a 60-62 Brake Booster Adapter, Power Steering Adapter Plate and the tube and flange.
Thanks,
Andy
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 10-16-2016, 11:09 PM   #106
Captainfab
60-66 Nut
I sent you a PM
Thanks,
Andy
Old 10-17-2016, 12:52 AM   #107
MikeG.
PM sent
MikeG. is offline   Reply With Quote
Old 10-17-2016, 11:24 PM   #108
Captainfab
60-66 Nut
PM returned
Originally Posted by MikeG. View Post
PM sent
Old 10-21-2016, 11:57 AM   #109
El Paso c10
Thumbs up Re: '60-'62 Power Brake Booster Adapter Bracket
I would like to place an order for a 1962 no clutch bracket, please let me know how I can get this process started.
El Paso c10 is offline   Reply With Quote
Old 10-22-2016, 12:24 AM   #110
Captainfab
60-66 Nut
I replied to your PM
Old 02-13-2017, 01:46 PM   #111
MASTERBrian
I'm sending you a PM for my 1960 Suburban...can't wait to get this part going!
MASTERBrian is offline   Reply With Quote
Old 02-14-2017, 12:24 AM   #112
Captainfab
60-66 Nut
I replied to your PM.
Old 02-27-2017, 02:21 AM   #113
Racinaround
Racinaround's Avatar
Im ready for a Bracket for a 61
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 02-28-2017, 12:24 AM   #114
Captainfab
60-66 Nut
Old 03-08-2017, 10:59 PM   #115
hop sing
hop sing's Avatar
Good evening ,, need to order a master cylinder bracket for a 64 and also a p/s bracket ,just got one question for you what's the best donor power steering gearbox to try and get ? and will donor pitman arm work thx Hop you can invoice me at kirktgee63@gmail.com on pay pal thx for your time Hop
Save a tree support your local drag strip !!!
hop sing is offline   Reply With Quote
Old 03-09-2017, 01:11 AM   #116
Captainfab
60-66 Nut
You do realize that this for sale thread is for a '60-'62 booster bracket correct? And you do need a '63-'66 standard booster bracket?
There is no best steering box. All truck based steering boxes are interchangeable from the '68-'86 C series and the '87-'91 R series trucks, Suburbans and 2wd K5 Blazers. The one difference is the fitting style change in about 1980. There was a variable ratio box offered as a option but there is no way to ID that steering box that I know of. Yes you must use the pitman are designed for the power steering box. I am assuming you need just the steering box adapter plate and not the tube and flange also?
I will send you a PayPal invoice.
Old 10-17-2017, 11:58 PM   #117
Captainfab
60-66 Nut
All of my booster brackets now come with slotted booster mounting holes to also accept aftermarket universal boosters with the 2-3/8" x 2-3/8" center to center mounting studs.
Old 01-10-2018, 01:08 AM   #118
Captainfab
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
Old 04-16-2018, 12:05 AM   #119
60apache
60apache's Avatar
Originally Posted by creep View Post
Bracket fit beautifully!
what booster did you use?
60apache is offline   Reply With Quote
Old 04-16-2018, 12:17 AM   #120
Captainfab
60-66 Nut
He says right here in the post below that pic.
http://www.67-72chevytrucks.com/vboa...3&postcount=41
Old 04-16-2018, 10:29 PM   #121
60apache
60apache's Avatar
thanks, what is the thinnest booster that I can use with your bracket? I bought a bracket from you years ago and have changed my system a few times since. Yours is the closest to the firewall I have found and gonna get another one from you.
Old 04-16-2018, 11:24 PM   #122
Captainfab
60-66 Nut
I do not know what booster is the thinnest. You will have to find a single diaphram booster from the list of compatible boosters. You do realize that the thinner single diaphram boosters give less braking assist that a same diameter dual diaphram booster, correct?
Old 04-19-2018, 10:18 PM   #123
60apache
60apache's Avatar
yes, I just want the cleanest look. what is your best suggestion on the booster?
Old 04-20-2018, 12:09 AM   #124
Captainfab
60-66 Nut
I would go with any of the many, many compatible dual diaphram boosters or with a hydroboost as you asked about in your PM to me.
Old 04-21-2018, 01:09 AM   #125
60apache
60apache's Avatar
do you have a link to the compatible boosters?
