Old 04-11-2010, 09:20 AM   #101
jojo
printing is my trade
jojo's Avatar
Re: Chucks SWB Fleetside
lookin good bud!!
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 04-11-2010, 02:50 PM   #102
VA72C10
VA72C10
VA72C10's Avatar
Nice group of parts there!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-11-2010, 05:02 PM   #103
sourkraut
sourkraut's Avatar
love the dash!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 04-11-2010, 05:36 PM   #104
highperf4x4
Yeah that dash looks good in there. I wish now that I had gone with the tach dash when I replaced mine.
highperf4x4 is offline   Reply With Quote
Old 04-11-2010, 09:34 PM   #105
thelonerife
thelonerife's Avatar
Thanks guys. I like the dash too. I would like it to have air pressure rather than vac but I'll use it like it is. I don't know if I posted this or not but I found another swb frame for this project. The one it sits on right now has a spot that I'm not sure about. I am still deciding how far to take it down for cleaning and painting. I have a sandblaster that I haven't used yet. I also found that a spraycan gasket remover works very well especially when it pressure washed off. I got it down to the black paint on the frame. The frame had been blasted but not taken apart. The part where the cab was wasn't blasted all the way. I used this gasket remover and pressure washer technique there and it worked well. I just ran out. I'll post some pics after I get farther along and the new owner of the stepside takes it home. Then I'll have some room.
thelonerife is offline   Reply With Quote
Old 04-11-2010, 10:20 PM   #106
highperf4x4
That sounds like a ton of fun except for that sandblasting part.
Old 04-14-2010, 10:54 PM   #107
thelonerife
Yeah sandblasting sure does clean it up nice but I'm not sure that this one needs it. Its pretty clean other than a few spots that are hard to get to. I think I'll try to take it apart and clean it up, paint it and put it back together. The frame is not very dirty or rusty. Just a little surface rust here and there. I came home today and took off some un-needed stuff. the crossbar at the rear for the spare tire mount. (gonna put the tank from the burb frame in there). The clutch pivot bracket, and the exhaust hangers that someone welded to the frame. I also took the brake lines and fuel lines off all in one piece. I left the hangers on them so I wouldn't lose them lol. I am possibly going to use the lines off of the burb frame since the it had 79K mi. I also will likely use the fuel lines after I look at them.
I cleaned it a little more with the gasket remover and pressure washer. I'm gonna try to wire wheel and sand it soon. I cleaned the tops of the cab mounts and sprayed some primer on them.
Old 04-17-2010, 10:58 PM   #108
thelonerife
Well, this morning I took the wire wheel to what you see above (where the cab sits)and got the black paint off and the rest of the grime that was under the frame. It took longer than I thought it would. Or I'm getting old. Got it primed. I'll take the frontend off later and clean all that up. still deciding on drop.
Old 04-17-2010, 11:00 PM   #109
highperf4x4
Wow that looks great!
Old 04-17-2010, 11:12 PM   #110
SATownChevy
SATownChevy's Avatar
looks pretty good, i just did the same thing this last week. I used black undercoating for mine. I had to take off the front suspension and trailing arms to flip the frame over. there are a lot of nooks and crannies everywhere on the frame.
View pics of my truck - 1968 Chevy C10 SWB - Photobucket
I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
SATownChevy is offline   Reply With Quote
Old 04-17-2010, 11:24 PM   #111
thelonerife
I'll have to take the front and rear off too. I just didn't want to do it this weekend as I'm leaving tomorrow to go out of town and my basement is already a mess. Someone already blasted this frame but they only got what you can see topside. And all the little nooks and crannys on the front are still greasy.Primed,but greasy lol.
Old 04-17-2010, 11:29 PM   #112
SATownChevy
i used a lot of oven cleaner to get mine all clean. it really cuts through the grease and grime. then just hit it with the hose and its all clean. took me a lot of passes but i got a clean frame now. the wire wheel helped too.
check out my build thread, the link is in my sig. it might give you an idea or two
Old 04-17-2010, 11:34 PM   #113
VA72C10
VA72C10
VA72C10's Avatar
Good progress!!!
Old 04-17-2010, 11:57 PM   #114
highperf4x4
There's an awful lot of "high octane" in here.
Old 04-18-2010, 12:01 AM   #115
thelonerife
I used a couple cans of gasket remover. Its expensive so I might try the oven cleaner. Which kind works best?
Old 04-18-2010, 12:03 AM   #116
SATownChevy
i got the best kind, the $1 per can kind. Check out your local dollar stores
Old 04-23-2010, 09:37 PM   #117
thelonerife
This is the current state of the truck. The frame it was on is going to scrap. I sold the rear and trailing arms from it. I will finish the cleaning and painting of the other frame and get the cab put on soon.
Old 04-23-2010, 09:40 PM   #118
thelonerife
I got a tilt column off of ebay. And I got the cpp brake booster,master cyl. and prop. valve in today. Just hung it on the cab to keep it out of the way. Heres a before and after. Looks a little better huh?
Old 04-23-2010, 09:42 PM   #119
SATownChevy
its a muliti-use pool table/work bench
cleaning the frame is definitely a work out but it pays
Old 04-23-2010, 09:43 PM   #120
SATownChevy
agree with you on the brakes, i got the chrome set.
Old 04-23-2010, 11:21 PM   #121
sourkraut
sourkraut's Avatar
that master cylinder sure is pretty! i dont know if i missed it or what but was there something wrong with you other frame?
Old 04-23-2010, 11:54 PM   #122
thelonerife
It had a place on it that looked like it had been bent. The frame also had a 73-up frontend. I just didn't like the thought of building on a frame that was questionable. I wish that the po had been more honest about it. Live and learn. This is a pic of the bend. the top rail goes down too far. And it also had a gap problem on the pass. side (door to fender) while the drivers side was okay.The replacement frame is in a lot better condition. I got it from Brian(southern c10) as part of the deal that we made on my stepper.
Old 04-24-2010, 12:52 AM   #123
sourkraut
sourkraut's Avatar
I see, that is cool you were able to get a good one!
Old 04-24-2010, 02:05 AM   #124
highperf4x4
Looks good!!
Old 04-28-2010, 11:48 PM   #125
thelonerife
I got the frontend off and got the frame rails cleaned and primed.
