#101 |
Re: Guilty Customs teams up with WellBilt Kustoms to build a 67 C20
Energy suspension red poly sway bar bushings:
![]() And the pics I was so excited to post!!!! Funny thing is, its not even work I did! lol. Engine back from the builder: ![]() ![]() ![]() ![]() ![]() |
#102 |
Local Redneck Authority
oooooooooooooo That looks fast!
Tell me, are there any other drive accessories that will be used? Just wondering about the serp belt setup with the reverse drive WP. It doesn't look like much belt would be touching the pulley. Very nice work on the entire build! |
#103 |
VA72C10
![]() Join Date: Mar 2008
Looking good. Nice progress...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#104 |
67cheby
![]() Join Date: Sep 2008
would you happen to have the part # on those radiator core support bushing... mine are energy suspension just like yours but my radiator core support ones look more like the cab one, a lot thicker than yours and they set my support up to high
#105 | |
Thanks for the comments! |
#106 |
We got the whole cab mount kit. If you bought the whole kit, mine are probably the same as yours. I had a friend just throw those on there before we took pictures of the frame to show we had red bushings. So I dont even know if the ones in the picture actually go there. But once I bolt them in, I'll shoot you over the number thats on my bushing for that spot.
#107 |
67cheby
or if you could just tell me how thick that front core support bushing is , that would be a great help, i will just cut mine down to match it
#108 |
Hey guys...sorry I have been lagging on updating the build. Alot has been going on these past couple weeks, along with a great tragedy. Let me start off with telling you guys that story.
A couple of the units where my shop is located caught fire last week, and really set me back. We lost our power, our phone, internet connections, and our water supply. We just got our phone and internet working late last night, and just got our water back on. One of the affected units was a close friend of mine's shop, and he was actually the guy who's going to be doing the body work and primering on the c20. The fire started at the unit next to his. The guy who owns that unit had dumped some hot coals into a trash can out of his bbq which he used earlier that day ![]() I will be starting a paypal account for donations if any of you are interested in donating any money to help him get back on his feet. Anything you can give helps! there's power in numbers, and we all appreciate anything! Here are a couple pictures after the fire got put out. ![]() ![]() |
#109 |
Learning As I Go
oh that sucks poor doggy
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
#110 |
And here are some progress pictures for you guys.
Front brake calipers painted high temp silver and clear coated: ![]() Making cardboard templates for the new firewall: ![]() The reason the whole firewall is cut out is because the owner and I both agree'd that instead of filling in the holes on the factory wall, and tapering the two sections like most people do, cutting it all out and making a new one out of one solid smooth piece will look much cleaner. It was definately worth the work I think. And once everything is put together, I think it will really bring out the cleanliness of the trucks lines and what we have done to smooth out some of the factory edges. *if that makes sense at all* ![]() ![]() ![]() ![]() If you look at the center tranny tunnel section, on the right side, the factory sheetmetal comes out and has a flat square looking section which totally throws off the clean, and symetrical look of the custom firewall. So we decided that we would cut that section out, and smooth it to look like the left side. Before: ![]() Section removed: ![]() ![]() Section filled in to match left side: ![]() We also had to cut the lower right side of the trans tunnel and reshape it so that the radius isn't boxy from the flat section we removed. All in all, I think it came out pretty good, and it really goes with the totally smooth firewall. |
#111 |
Patched up the rusted cab corners as well as welded on the new lower rocker panels:
![]() ![]() Did the finishing touches on the upper cab seam: ![]() Finished up the roof drip rail shaving: ![]() Another rusted spot patched up: ![]() Customer dropped off the polished power steering pump and Zoops bracket, so we put that on the engine. ![]() I'll have more pictures posted up this weekend for you all to see. Next major thing thats getting started this week is the fitment and graphing of that 1955 Chevy dash into the cab. Should be TONS of fun! ![]() Anyways...let me know what you guys think! ![]() |
#112 |
VA72C10
Looking good!
#113 |
Going Down?
![]() Join Date: Jun 2009
Agreed!!
After seeing that clean firewall, it makes me want to go back in and do mine like that!
Just another day in Paradise Rebuild thread http://67-72chevytrucks.com/vboard/s...d.php?t=354512 |
#114 |
![]() Join Date: Mar 2010
Looks good.....Keep up the good work
#115 |
C-10 Club Member
Fab work looks outstanding......
Sorry to hear about your buddies loss..... ![]()
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
#116 |
Prestige Worldwide
![]() Join Date: Feb 2001
#117 |
Here are some pictures of the finished firewall. After all the welding and tons of grinding:
![]() ![]() ![]() ![]() Rusted top corner fixed: ![]() More of the floor fixed: (Still needs more welding, and grinded smooth) ![]() ![]() ![]() Fuel cell into frame. Man what a polished fuel cell does for the apperance of the chassis! ![]() ![]() |
#118 |
VA72C10
looking good
#119 |
very nice fab work.. subscribed!
* 1968 GMC Swb - 98% done (current restoration) * 1971 Chevy Lwb - Retired Dump Hauler * 1982 K10 Longbox - New Dump Hauler |
#120 |
Hey guys, Updated pictures will be up today.
We finally got all the rusted spots on the floor patched up, ground down, and we seam sealed everything. Also finished shaving all the un-used holes, and the whole glove box section on the 55 chevy dash. Came out great! Only need a skim coat of filler to even everything out. today were test fitting it into the cab, and deciding what were going to do to taper the dash into the tops of the doors. We also got the inside of the cab and back of firewall all line-x'd for sound deading. |
#121 |
Hey fella's. Got some new parts for the project since we are back on the build.
What do you guys think about the newest addition to where this thing is going??? ![]() ![]() ![]() What could be better then a polished Tunnel Ram and NOS????? RIGHT? |
#122 |
Gearhead
Man thats goona look incredible when its all assembled!
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#123 |
Sofa King Crazy!!
That frame looks killer! I'll be checkin in on this one! Hope your buddy can recoup all he has lost.
You found the Tater. ![]() My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. ![]() 1972 2wd Blazer "Porterbuilt and Sloshed" ![]() |
#124 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Nice addition...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#125 |
Here are a few updated pics of the cab and chassis.
![]() ![]() ![]() ![]() Before we started hacking it up: ![]() |
