Old 12-20-2010, 12:40 AM   #101
markeb01
Senior Enthusiast
markeb01's Avatar
Re: show your67 72 chevy spot light trucks
Originally Posted by 67chevy1series View Post
i would like to replace my handle assembly and the little badge at the top where it says unity or gm i need the part numbers , idont know them . i want to go on the unity site and look up so i can order them
The Unity crest is part number 6295-U
http://unityusa.3dcartstores.com/629...ent_p_484.html
The GM crest is part number 6295-GM
http://unityusa.3dcartstores.com/629...ent_p_473.html
And the GMC crest is part number 6295-GMC
http://unityusa.3dcartstores.com/629...ent_p_474.html
The only handle parts I find listed for the vintage lamps online are the following. Note – these are a direct interchange with the original vintage handles, but they are not exact duplicates. Vintage handle housings have a clip and two screws over the wire where it leaves the housing. The later design has a smooth raised ridge in this area. It’s actually cleaner and neater, but not authentic if that matters. Also the newer parts come with Phillips head screws where the originals were slotted. Early and late screws are the same thread size so they can be interchanged.
http://unityusa.3dcartstores.com/675...bly_p_615.html
http://unityusa.3dcartstores.com/838...Kit_p_552.html
I don’t know the difference between these last two bare handle housings:
http://unityusa.3dcartstores.com/831...ing_p_507.html
http://unityusa.3dcartstores.com/600...ing_p_506.html
I have dealt with Unity directly and they were very friendly, helpful, and supportive. But after pricing the parts and before placing an online order, you might want to check with Accesoryland. It’s a mom and pop shop so he’s a little slow to respond, but very helpful and knowledgeable. He has a large inventory of obsolete parts, and also has direct access to the Unity factory inventory. Here is his web link:
http://www.dandrfoods.com/accessoryl...spotlights.htm
Old 12-20-2010, 12:44 AM   #102
67chevy1series
67chevy1series's Avatar
thank you markebo1
67chevy1series is offline   Reply With Quote
Old 12-20-2010, 12:16 PM   #103
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Woah,rick! Your TELLING me Im going to put my spotlight on my truck?
John
1999 Toyota Tacoma 4x4
Old 12-20-2010, 12:20 PM   #104
markeb01
Senior Enthusiast
markeb01's Avatar
Originally Posted by Alex Hayley View Post
How much light do these lights put out?
For vintage 6” round applications there were two types of sealed beam bulbs offered. The original standard sealed beam and a newer halogen version. Here are the part numbers and characteristics of each:
Standard - 4435 clear spotlight, 35 watts, 75,000 candlepower, with 100 hours of lamp life. This bulb can be easily distinguished by the dark dome over the bulb filament inside the sealed beam, as seen here:
Halogen - GE H7635 Clear Halogen Lamp, 50 watts, 160,000 candle power, 100 hrs lamp life. And yes the Halogen bulb is considerably brighter. This came standard on most spotlights produced in the 70’s and 80’s. that no longer had the screw-on crest/emblem on top. The crest was replaced with a lackluster riveted plate. The halogen bulb is readily identifiable by the lack of a dome over the lighting filament as seen here:
Both bulbs are the same physical size and interchangeable.
ya i was just checkin becauce i was told i cant have it facing to the traffic
Some states don’t allow functional spotlights on privately owned vehicles at all. For the two states I’m familiar with (California & Idaho) the laws basically say you cannot shine an illuminated light at any moving vehicle.
For anyone interested here are links to the applicable vehicle codes in those two states, pertaining to owning and using vehicle mounted spotlights:
California: http://www.dmv.ca.gov/pubs/vctop/d12/vc24404.htm
Washington: http://apps.leg.wa.gov/RCW/default.aspx?cite=46.37.180
Old 12-20-2010, 03:45 PM   #105
67chevy1series
no i was asking if you are going to
Old 12-20-2010, 03:59 PM   #106
oldblue1968chevy
Need help
Almost done, where do all of these parts go?
ESP the brass washer! lol
John
Old 12-20-2010, 04:08 PM   #107
oldblue1968chevy
oops forgot the pix
John
Old 12-20-2010, 04:27 PM   #108
markeb01
Senior Enthusiast
markeb01's Avatar
The split collar on the left goes on first, and fits flush against the headpost housing inside the outer body bracket. The split should line up with the split under the adjusting screw.
After the shaft is inserted into the body, there is normally a tapered rubber washer slid over the shaft to act as a seal against the inside of the post. A typical item can be seen in this photo. If you don't have one a perfect replica can be created by slicing up a piece of fuel tubing:
The ring with the small hook goes on next, if your application requires one to support the wire after it leaves the handle. The long L bracket is for industrial applications where extra support is desired inside. I’ve never used one personally. Finally the chrome collar with the set screw goes on to lock the inside of the shaft tight in the body.
The handle assembly goes on last, and the wedge and screw hold it in place. Some outer tubes have a flat spot for the wedge providing a fixed orientation between the handle and the lamp head. Later models have no flat and a different shaped wedge, which can be tightened in any position.
Old 12-20-2010, 04:30 PM   #109
oldblue1968chevy
Ok, thanks mark, Im not quite to that point. But where on EARTH does that lil brass ring with the slit cut into it
John
Old 12-20-2010, 04:32 PM   #110
markeb01
Senior Enthusiast
markeb01's Avatar
In response to a recent request, here are some exploded views of the headpost assembly for anyone that might have interest:
Old 12-20-2010, 04:39 PM   #111
oldblue1968chevy
Here is what I think your telling me to do at least..lol
Thanks!!!! I cant wait to get this done and either mounted on my truck or sold LOL
John
Old 12-20-2010, 05:00 PM   #112
67chevy1series
you got it now the thin peice of metal goes against the cab and then the fatter peice goes against the skinny peics and then the handle assembly
Old 12-20-2010, 05:03 PM   #113
markeb01
Senior Enthusiast
markeb01's Avatar
Yes, although it appears you have not yet installed the outer tube which is a slip fit into the head housing and the collar snugs up to it. When mounted, the split collar seats completely in the outer body bracket.
Old 12-20-2010, 05:13 PM   #114
oldblue1968chevy
So I need to pry it open and stuff the brass collar into there?!!?
I am confused..again lol
John
Old 12-20-2010, 05:14 PM   #115
markeb01
Senior Enthusiast
markeb01's Avatar
Here are a few pics showing a *correction* I believe this is a 1955-1959 Chevy truck outer mounting bracket with and without the collar, and with the outer tube installed:
Old 12-20-2010, 05:31 PM   #116
oldblue1968chevy
Ahhh I got it
The brass thing goes on the exterior mount! Ahhh lol I feel stupid now
THANKS
John
Old 12-22-2010, 04:40 PM   #117
Mxracer202
Mxracer202's Avatar
do you think ill have a problem since mine has the round outside seal instead of the square one, i want it to sit beside the door of the vehicle instead of the roof.
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline   Reply With Quote
Old 12-22-2010, 04:54 PM   #118
67chevy1series
do you have a picture of what you are talking about
Old 12-22-2010, 05:44 PM   #119
oldblue1968chevy
Yeah, a pic would help alot
John
Old 12-22-2010, 05:56 PM   #120
Mxracer202
Mxracer202's Avatar
Originally Posted by 72shortbed12 View Post
Here s a couple more. I forgot to take one of the toggle switch thats mounted on the dash above the parking brake pedal.
the top pic
Old 12-22-2010, 05:57 PM   #121
Mxracer202
Mxracer202's Avatar
third page yellow truck with the top mounted light sorry to make you chase this but i dont have a pic of it right now
Old 12-22-2010, 06:01 PM   #122
67chevy1series
your picture ditn come through but i know what you are talking about , it shouls still work and if it doesnt make your own out of a bicycle tube
Old 12-29-2010, 10:15 PM   #123
Mxracer202
Mxracer202's Avatar
ok thank you, I guess if it didnt fit I could just cut it into a square, and customizzzze it!!
Old 08-28-2011, 01:13 AM   #124
67chevy1series
time to bring it back to from the dead! i finally got my spot working! heres a pic for you picture monsters.the battery was a little low....
Old 08-28-2011, 01:33 AM   #125
454stepside
truck i am putting together for a customer glad i found this post lol i need to know what holds the bulb in tight and if you can get parts
454stepside is offline   Reply With Quote
