Old 01-17-2011, 09:00 PM   #101
Pop's C-10
Pop's C-10's Avatar
Re: 1952 chevy home made frame build
killer build
Pop's C-10 is offline   Reply With Quote
Old 01-17-2011, 09:11 PM   #102
hotrodjoe1952
hotrodjoe1952's Avatar
Originally Posted by Thinkblue4 Evr View Post
Thank You to everyone for the positive feed back
The wheel base is the stock 116 inches.
that is cool, i am now wondering why a guy on here set his up at 117"
http:www.electronicshve.com
Your Ultimate Choice for all your Electronic need's!
hotrodjoe1952 is offline   Reply With Quote
Old 01-25-2011, 10:33 PM   #103
Thinkblue4 Evr
Thinkblue4 Evr's Avatar
We have gotten a lot done since the last time i posted and we are starting to see some results and i have to say it looks pretty sweet. Im not gonna say anything because a picture says 1000 words.
1952 Chevy 3100
1986 Corvette Suspension
350 motor Tune Port Injected
Thinkblue4 Evr is offline   Reply With Quote
Old 01-25-2011, 10:41 PM   #104
Deabt54
Deabt54's Avatar
Looking good buddy, and I just posted some more pics of my rear section.
Deabt54 is offline   Reply With Quote
Old 01-26-2011, 12:13 AM   #105
Thinkblue4 Evr
yah i saw that yours is looking good to.
1952 Chevy 3100
Old 01-26-2011, 01:02 AM   #106
Kim57
Kim57's Avatar
Looks great.
Kim
Kim57 is offline   Reply With Quote
Old 01-26-2011, 09:16 PM   #107
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
That's really going to be a nice looking frame!
ChuckDriver is offline   Reply With Quote
Old 01-26-2011, 09:24 PM   #108
sgtusmc
sgtusmc's Avatar
I don't see any bare spots on the frame. All I see is red, So guess your done with it. It looks really great.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 01-26-2011, 09:35 PM   #109
Thinkblue4 Evr
Thanks everyone we are pretty much done with the frame and just need to put the shock mounts on the rear we havent decided if we are going to run coilovers or the mono leaf.
1952 Chevy 3100
Old 01-26-2011, 11:37 PM   #110
NONHOG
NONHOG's Avatar
With as nice as the frame looks, can't wait to see how the rest of the truck looks.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-27-2011, 01:33 AM   #111
Thinkblue4 Evr
Well right now the rest of the truck is in pieces but i hope it turns out as nice as the frame is. everyone has a vision i think and in my vision it will be nicer than the frame is.
1952 Chevy 3100
Old 01-27-2011, 06:28 PM   #112
Thinkblue4 Evr
Here is the ride height we are looking at it will be a little lower.
1952 Chevy 3100
Old 01-27-2011, 08:30 PM   #113
Kabwe
Certified Car Nut
Kabwe's Avatar
The frame came out really nice, great work on it.
Kabwe is offline   Reply With Quote
Old 01-28-2011, 11:51 PM   #114
z71xl
I just started building the frame for my 54 gmc, waiting on my 87 corvette front and rear end so i can figure out my ride height. I took all the measurements off a stock frame...what did u use for measurements? Whats your ride height set at? Hoping mine looks as good as yours when done!
z71xl is offline   Reply With Quote
Old 01-29-2011, 09:56 AM   #115
Fat Mike
Fat Mike's Avatar
How did you attach your running boards and your battery box? I just wonder because everything was enclosed on the backside.
Fat Mike is offline   Reply With Quote
Old 01-30-2011, 12:38 AM   #116
Thinkblue4 Evr
We got a factory assembly manual and it had a drawing of all the specifications of the frame and we built it off of that and made almost everything to the stock dimensions. the ride height i really havent measured but i like it and it looks good. Thanks for the positive comments.
1952 Chevy 3100
Old 01-30-2011, 12:40 AM   #117
Thinkblue4 Evr
The tube steel is 1/4 inch thick so we just drilled and tapped it and it seems very strong.
1952 Chevy 3100
Old 01-30-2011, 12:45 AM   #118
Fat Mike
Fat Mike's Avatar
Thank you for the info!
Old 01-30-2011, 01:31 AM   #119
dicer
Wow, great stuff.
And this should show others how to build a custom truck, and not goof up an original frame to boot.
I would like to know what kind of paint your using? For the frame and body etc.
Also what is the thickness of the steel tube for the frame rail sections? 3/16 ths???
And are the other dimensions approximate to the factory rail and beam sections?
Very excellent job, is it all welded wire feed?
dicer is offline   Reply With Quote
Old 01-30-2011, 03:02 PM   #120
Thinkblue4 Evr
Originally Posted by dicer View Post
Wow, great stuff.
Yah hopefully the guy that originally started this truck reads this because it was a mess. We used Rustoleum for the frame and we are going to use tcp global hot rod flatz for the paint.
the frame is 1/4 inch thick and we used the same dimensions as an original factory frame. My dad tig welded everything on the frame and wire fed and tig on the cab.
1952 Chevy 3100
Old 02-03-2011, 11:39 PM   #121
Thinkblue4 Evr
Playin with photo shop
if it looks familiar i borrowed it from Mylow53
1952 Chevy 3100
Old 02-13-2011, 10:07 PM   #122
z71xl
Whats the measurent from the ground to the bottom of the running board? Finally got all my suspension components minus the flat out front crossmember. I got all the dimensions from a stock frame and all the steel, just cant wait to get started!
Old 02-13-2011, 10:13 PM   #123
z71xl
What degree do you have for the kickdown on the front of the frame? Am I wrong or does it start just rear of the crossmember?
Old 04-17-2011, 11:30 PM   #124
Thinkblue4 Evr
sorry i havent updated in a while but ive been busy startin football again. any way we havent done alot but started doing body work on the cab and havent gotten the hang of it yet. also got some parts to rebuild the door hinges. will post some pics probably tomorrow or the next day.
1952 Chevy 3100
Old 04-17-2011, 11:32 PM   #125
Thinkblue4 Evr
All of our frame dimensions are stock but i think its 3 degrees or something around there. and it starts just before the rear axle.
1952 Chevy 3100
