Old 03-07-2012, 12:26 PM   #101
oldcouple
oldcouple's Avatar
Re: My 1957 Chevy Truck "Journey"
Not too bad really, looks like someone tried to squeeze thru the barn door and hooked it. It should weld up fine. The grinder, a 4" one can be your friend.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 03-08-2012, 09:05 PM   #102
57picupnewbie
'57 Rosa
57picupnewbie's Avatar
Originally Posted by ambryatim View Post
Well, I decided that I would take a look at the cab to see how bad it is and how much work it might need.
I have to replace the cab corners and will also have to replace at least the the rockers on the driver side and maybe the step on the passenger side. I started on the driver side and used a 4" cup wire wheel to check the damage and this is what I found.
Driver side...they hit something.
The white vertical stuff is filler.
They used it to fill the gap between the door and the jam!!! Man that is very upsetting.
Passenger side.
Not as much filler but, still not good.
I was trying to catch a shot of the build up...angle is from the bottom looking
up.
Rear of the cab.....I can feel small dings and dents not real major a little hammer and dolly work and it should be good.
Driver "A" pillar section.
I have a question about this area...does it look like it has been repaired or does it look like original???
Looks like I will be getting a 101 class in body work....if any one has pointers on how to tackle these areas and a good technique to use for hammer and dolly work. I am all EARS....cause lord knows I need all the input and pointers I can get. Have read this to get an idea of some of the repairs, but hands on input is greatly appreciated.
The area you are refering to on the "A" Pillar is wher the section was braised at the factory. If you follow that section up toward the roof section right in the top corner you will find another section that is braised where the "A" Pillar and the Roof Panel join.
My '57 Truck Build "Rosa" (Current Project) http://67-72chevytrucks.com/vboard/s...21#post4118721
2003 Dodge Dakota 4X4 (Daily Driver)
Only two defining forces have ever died for us: CHRIST died for our salvation and VETERANS died for our freedoms. Glorify CHRIST and thank VETERANs
Dru~ USN Retired
57picupnewbie is offline   Reply With Quote
Old 03-08-2012, 09:25 PM   #103
ambryatim
ambryatim's Avatar
^^Thanks that is good to know.
ambryatim is offline   Reply With Quote
Old 03-08-2012, 09:41 PM   #104
ambryatim
ambryatim's Avatar
Well, I had previously made some engine mounts and did not like the way they sat when installed. So, I made some new ones. I have seen some like these for sale but, all the materials were free.....it was all made from scrap metal from around our shop. Maybe a little overkill on the tubing but oh, well.
The parts I cut out.
I need to finish welding them tomorrow...ran outta time today. And I will have to paint them too.
Old 03-10-2012, 09:19 PM   #105
71'tahoe
71'tahoe's Avatar
Cool project!
71'tahoe is offline   Reply With Quote
Old 03-10-2012, 09:38 PM   #106
ambryatim
ambryatim's Avatar
Thanks....Slow going but, its going...
Originally Posted by 71'tahoe View Post
Cool project!
Old 03-17-2012, 11:22 PM   #107
ambryatim
ambryatim's Avatar
I found the measurements that I was looking for regarding the older Camaro mounts that some have been using.
For one it is 2" from the base to the center of the bolt hole on them mount the other was 2-3/16" from the base to the center of the bolt hole.
Now with those measurements I could not get my engine to sit level.....left to right. The only way I could get it level was to make the mount that was 2-3/16" taller....2-5/8"....now I have another problem.
In order to get my 3* downward angle I have to lift the tail of the tranny too high....almost to where the tail shaft hits the cab....it is about 2" from the cab floor...I test fitted the drive line and it hits the cross-member behind the cab....granted the rear axle is hanging lower than it will be at ride height but, it still will not work.
I think I am going to have to shorten the mounts to get it where it needs to be. I am open to suggestions too...I tried the heights for the mounts others have used but for some reason I could not get it to work. I just wonder if there engines are not centered and they are using the camaro mounts and it is actually offset like the engine in the camaro was to begin with???
Here are some pics for your viewing pleasure.
Old 03-18-2012, 12:31 AM   #108
Kim57
Kim57's Avatar
These things can be a real pain some times.
Looking at the pics it seems the passenger side frame where the engine mount goes isn't as steep as the drivers side. If you want your engine centered in that area your mounts may need to be different lengths.
As far as the tail shaft getting close to the cab mine did also. I'm just going to add a slight hump and not worry about it.
You will probably have to modify your cross member to make it all work.
Sorry I don't have better answers for you.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-18-2012, 12:47 AM   #109
ambryatim
ambryatim's Avatar
Thanks Kim...
Yea, the camaro clips are not symmetrical on the cross-member at all.....I know in the camaro's these engines favored the passenger side to make room on the driver side to clear all the stuff over there. I have been looking at some stuff on LSTech to where people have swapped these in the second gen camaro's but, what they are doing/using I cannot get to work.
I like the clearance that I have...but not too sure about modding that cross member....If I can clear everything up front I might lower it some....not sure though at this point.
Kim
Old 03-18-2012, 10:36 AM   #110
Kim57
Kim57's Avatar
I would watch the oil pan location more than anything else.
If you're going to have your truck lowered it may present a problem.
I made sure I got mine level with the bottom of the cross member and went from there.
Holley makes a swap pan that has a shallower sump but I found it a bit pricey.
Kim
My build thread
Old 03-18-2012, 11:02 AM   #111
ambryatim
ambryatim's Avatar
Yea, it still has the truck pan on it and I am looking to get an LS1 pan.....If I kept the truck pan on then I would have to go up quite a bit more and that would make even more issues. At its current height it would actually be above the cross member by about an inch or so, with an LS1 pan on there.
I am kinda like you ......I want to stay with the cast aluminum pan....do to the structural rigidity that the pan adds to the bottom end. Might not be much but it is more than a shetmetal pan.
Old 03-19-2012, 11:53 PM   #112
50seven
50seven's Avatar
I wouldn't try and get that motor down so deep in the crossmember. There are many people who raise a sbc because it looks so deep in the bay....... when they put a gen I sbc in the stock camaro clip local. I would imagine there is plenty of vertical real estate for you to raise that LS1 aswell. probably save you a lot of headaches and maybe look better from the topside when you are done to?
My son has an LS1 and they have oil leak issues something to do with the pan. Apparently a labor some fix to? If you do change the pan maybe look up the pan leak issue fix at the same time?
Gonna be killer. I like the stance and the front wheels location looks perfect.
50seven is offline   Reply With Quote
Old 03-21-2012, 02:05 PM   #113
57picupnewbie
'57 Rosa
Here is the factory picture of it showing spot welds and all. Hope this helps.
Dru~ USN Retired
Old 03-21-2012, 03:10 PM   #114
ambryatim
ambryatim's Avatar
^^^ Thanks for that....I now have one of those books.
Old 04-24-2012, 07:25 PM   #115
ambryatim
ambryatim's Avatar
Ok, after making a mountain out of a mole hill. I finally got my engine mounts and positioning sorted out.
I ended up measuring the stock mounts for a camaro (frame mount) and it was 1-1/8" from the bottom to the center of the bolt hole...then I measured the "elephant ear" mount that bolts to the engine and found that mine were 2-15/16" to the center of the bolt hole.
Note: Mine were actually for a truck, I found that out later and found that the height for the camaro version is close to 2" to the center of the bolt hole.
So, what I did was take that measurement and add it to the frame mount...which yielded 3-1/8" total height. The engine mounts on the LS conversion kit are 2-3/16" from base to center of the bolt hole....then add the 1/4" for the mounting plate to get 2-7/16" so I just made my counts right at 2" from base to center of bolt hole...which lifted the engine a little over an 1" from the stock camaro location.
It looks good to me and it is offset to the passenger side just like in the camaro and I am going to have to redo the trans cross member due to the offset.
So, I used a laser and plumb bobs and hung on off the diff, trans tailshaft and check to make sure all is in line and it was dead on.
Here are a few pics of the mounts and the position of the trans in the tunnel, I will definitely have to mod the trans tunnel but, I was going to do that anyway.
Oh, and another thing....I have found a T56 at a good price I hope to be able to get it this weekend. From all the measurements on the T56 that I have found on the net...it looks like I will have to cut into the front brace right behind the trans tunnel....I will know more when I get the trans.
This is the truck pan and I will replace it with the LS1 pan before I am finished.
Old 04-24-2012, 07:38 PM   #116
Kim57
Kim57's Avatar
Cool. It's always a big step when you get the engine mocked up.
Kim
My build thread
Old 04-24-2012, 09:00 PM   #117
JML55
JML55's Avatar
Looks really good.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 04-24-2012, 09:05 PM   #118
ambryatim
ambryatim's Avatar
Kim
Yes it is!
Originally Posted by JML55 View Post
Looks really good.
Thanks JML55
JML55 good to see you back on the board....How is your truck coming along?
I failed to mention that the mounts that I made are the same height on both sides.
Old 04-24-2012, 09:06 PM   #119
Red Foreman
Red Foreman's Avatar
Yep its looking real good!
RIP John (Lambis), my beloved Father & best Friend.
My Build 56 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=486721
Red Foreman is offline   Reply With Quote
Old 04-24-2012, 09:07 PM   #120
ambryatim
ambryatim's Avatar
Thanks Red...yours is looking good too!!! Especially that engine!
Old 04-25-2012, 04:04 PM   #121
ambryatim
ambryatim's Avatar
Ok, I have a question.
Has anyone installed power brakes under the floor with a standard transmission??
I am needing to purchase a brake pedal setup seeing how my original disappeared and I was looking at the speedway motors unit.
But, it states automatic only not for use with factory clutch pedal.
Then I found these.....but, man that is pricey!!! I don't need all that stuff just the pedal assembly.
What would be my other alternative?? Any one have a clutch and brake pedal assembly they want to get rid of??
Old 02-08-2013, 12:43 PM   #122
Wheelie
Im at the same point too. You can have it on the chassis is you decide to use a cable or hydraulic throw out bearing because the Z bar and clutch fork will be gone. I am going to use hydraulic on mine since they make em for the muncie. HTH
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 08-05-2013, 11:44 PM   #123
ambryatim
ambryatim's Avatar
Have not posted here in a long time. Well, I hope to get to working on the truck soon. We had an addition to the family in November...now that makes 3 and there birthdays are all the same week of November and they are 10, 6 and new born...LOL! Well, nothing has been done to the truck since last April I am waiting for this good ol Texas heat to calm down a little...happy wrenching guys.
T
Old 08-12-2013, 08:49 PM   #124
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Hang in there... I sat on mine for 24 years and finally decided to get back on it 2 months ago... big progresses in the last 60 days.
Family comes first.
87Lowrider is offline   Reply With Quote
Old 02-18-2014, 02:42 AM   #125
elser2
hi, what is the title of this book with the spot weld locations?
elser2 is offline   Reply With Quote
