Old 03-30-2011, 08:30 AM   #101
justpball
justpball's Avatar
Re: West TX Z build up thread
You could sell your bigger ones and go with the 2 1/8 gauges and then they would match
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-30-2011, 10:26 AM   #102
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
I would but I spent too much already buying them. I doubt I can get them sold and within price range to buy a new set. Autometer is expensive.
West Texas Z is offline   Reply With Quote
Old 05-16-2011, 09:54 AM   #103
West Texas Z
Well, the engine swap is in progress, replacing seals and gaskets as we speak. I should have the truck back by wednesday at the latest. Will provide vids later.
Old 05-16-2011, 10:29 AM   #104
luifer76
luifer76's Avatar
Very nice truck man, question tho are you using a electrical or mechanical speedo?
luifer76 is offline   Reply With Quote
Old 05-16-2011, 02:21 PM   #105
West Texas Z
I'm using a mechanical one.
Old 05-16-2011, 03:48 PM   #106
luifer76
luifer76's Avatar
i got the same set up on one of my trucks i got the mechanical 5 inch phantom gauges but my speedo cable does not plug or screw to the back of the gauge, what are you doing with yours? is there a adapter or speedo cable that auto meter offers?
Old 05-16-2011, 05:01 PM   #107
West Texas Z
I'm glad you asked, yes there is: http://cgi.ebay.com/ebaymotors/ws/eB...m=230601382016 Good luck bud! Let me know how it go's.
Old 05-16-2011, 05:04 PM   #108
West Texas Z
My new engine set up:
Modified Chevy 350
World Product Sportsman II heads 2.020''x1.600''
Manley Street-Flo forged steel valves intake,1.600''exhaust, 11/32''x7
Hardened steel locks.
Hardened steel guide plates.
Hardened Pushrods
Lunati cam .515/.515, duration 246/246 @ 050''1.6 rockers
Edelbrock Performer RPM Air Gap intake.
Holley 750 Double Pumper with Pro Form Main body
Chrome Holley Performance Fuel Pump
K&N Xtream air filter
Taurus Electric Fan
CSR Electric Water Pump
Dyno-Max ceramic coated headers with 3'' piping
Flowmaster Super+44 series dumped before the axle.
Accel Super Conductor distributor
New Accel 8MM wires
Electric Vacuum Pump
Grove Components brackets
Turbo TH350 transmission
TCI Street Fighter stall converter
Shift kit B&M Megashifter.
Old 05-16-2011, 05:10 PM   #109
luifer76
luifer76's Avatar
dude you are a life saver thanks a lot i been thinking and thinking what was i gonna do to get the speedo working You're the man.....
Old 05-17-2011, 09:34 AM   #110
West Texas Z
lol Altec is the man to thank, I didnt know my self. He gave me the heads up.
Old 05-17-2011, 09:52 AM   #111
luifer76
luifer76's Avatar
thank's Altec.....
Old 05-17-2011, 05:50 PM   #112
Altec
Getcha Pull
Altec's Avatar
thank's Altec.....
Not a problem!
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 05-20-2011, 10:19 AM   #113
West Texas Z
I got some bad news yesterday. My mechanic was cleaning off the engine block and installing new gaskets and seals when he heard a metal "clank" in the oil pan. He decided to remove the oil pan and he found some extra performance goodies :sarcasm: Apparently the oil pickup broke off inside and was getting beat to hell with the crank inside the block and metal shards were getting bounced around inside. I'm glad he found the damage before he dropped the engine in. He reported that the damange isnt too bad and I would need my crank honed and polished along with new main caps. He reported that he should have me up and going in about a week....sigh, more $ to spend. I'll keep ya'll up with updates.
Old 05-20-2011, 01:08 PM   #114
luifer76
luifer76's Avatar
Dude that sucks but at least you caught it before dropping the engine in....
Old 05-20-2011, 02:58 PM   #115
3r!c84
Badass
3r!c84's Avatar
how do you hook up the air/fuel gauge to the motor?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-20-2011, 03:35 PM   #116
West Texas Z
I'm not sure, Pball would have to answer that. I dont have a Air/Fuel gauge. I'm sure you have to be fuel injected for that.
Old 05-20-2011, 03:52 PM   #117
3r!c84
Badass
3r!c84's Avatar
Oh!! Haha my bad, I thought you posted that. Sorry . Btw sorry about the motor. That really sucks man
-00 Saturn 5spd
1/4:13:90
Old 05-20-2011, 03:54 PM   #118
Mikec10
Mikec10's Avatar
you have to have an O2 sensor somewhere close to the beginning of your exhaust system. If you have true duals, it would require two o2 sensors.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears.
Mikec10 is offline   Reply With Quote
Old 05-20-2011, 04:30 PM   #119
West Texas Z
its all good......and thanks. I hope we figure it out soon and it doesnt cost me an arm and leg.
thanks for the info, again, I would have never known how that works. lol
Old 05-20-2011, 06:19 PM   #120
Altec
Getcha Pull
Altec's Avatar
Pretty sure A/F gauges only use one O2 sensor mounted on one of the banks. Since it is reading ratios, it doesn't care about how much total volume there is.
That is a real bummer about the pick up. Guessing some one changed the oil pump, and reused the pick up? I used a new pump, and pick up with my 7qt pan. Wasn't taking chances... Also have a metal coupler that is tacked in place on the drive shaft. If I loose oil pressure someone is going to have a bad day...
I wonder why the caps need replaced? Did you ask?
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Old 05-25-2011, 07:04 AM   #121
justpball
justpball's Avatar
Yea I have FI, it just ties into the O2 wire
87 Crew SWB
Build for the crew
90 burb 2wd
Old 02-21-2012, 06:22 PM   #122
West Texas Z
Just wanted to update, The truck got an engine transplant and it blew the pistons and rods after 2 weeks. Going with a new crate engine now. I'll keep yall up to date.
Old 02-21-2012, 08:33 PM   #123
3r!c84
Badass
3r!c84's Avatar
Damn! Your not Doing somthing right man ): sorry for your luck! Are the alum heads damaged that you used?
-00 Saturn 5spd
1/4:13:90
Old 02-22-2012, 12:31 AM   #124
West Texas Z
I'm not sure, but I'll pull them off next week. I'm just going to salvage everything I can and sell it.
