Old 06-25-2011, 01:27 AM   #101
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: My 66 Service Truck Build Thread
Right now during the dryer summer months, I want to get my cab patched up and protected.
I'd also like to at least do a quick spray on the box just to get it looking a smidgen better. It's pretty chipped up, and the black is brushed on.
I don't want to bother doing a lot of sanding, so I'll do a quick over and then do this as Mark talked about here:
Originally Posted by markeb01 View Post
I had the same problem with my wifes 68 F250. I used U-Pol catalyzed primer as shown at the link below:
http://autobodystore.net/Merchant2/m...egory_Code=PRI
It can be rolled on, so there's no overspray to deal with and goes on very thick so there's a lot of film thickness to block out. It's been sitting outside unprotected for about 3 years now and looks like the day I put it on.
Originally Posted by jyaughn View Post
so with that primer you just roll it on and sand it off and all the pit holes will be filled?
Yes, in fact I used the same stuff on the top of my rear fenders. After 10 years on a gravel road the tops were littered with star chips. Rather than completely stripping to bare metal, I thoroughly feather edged all the chips, which left the surface clean but wavy. I rolled on the primer, let it cure, blocked it out and shot on the finish paint. Even when wet the fenders shine perfectly smooth. This stuff goes on thick and doesn't shrink, so it doesn't cause any problems later on. If you've got deep pits it's always imperative to get all the rust and crud out. If I had rusty pits I would scrub them with metal prep first to neutralize any rust before priming.
66 C20 Service Truck:
Old 06-25-2011, 03:45 AM   #102
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Yeah, I need to rush out there and get busy myself. Was only 105 in the shade today, a sure sign the hot weather is on it's way...
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 07-06-2011, 05:42 PM   #103
LostMy65
LostMy65's Avatar
Great thread for future reference when i go to do the brakes:
http://67-72chevytrucks.com/vboard/s...d.php?t=460791
Another thread for future reference:
http://67-72chevytrucks.com/vboard/s...248460&page=93
Old 07-06-2011, 09:25 PM   #104
bollybib
bollybib's Avatar
Originally Posted by LostMy65 View Post
Maybe someone can help me with this latest issue;
While working on my 66, I seem to get really sore and tire much quicker than when I worked on my 65 back in 84.
Did something change on these trucks from 65 to 66?
Nice write up, lots of links to other threads and interaction with others. You search a lot I can see. Maybe you'll find the 65, maybe not. Sounds like you have found a good substitute with your 66 in the present. & I wonder what is in that circle under the paint ?
However, I can't help you with your issue re: 66 vs 65 but it sure made me laugh.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 07-08-2011, 04:27 PM   #105
LostMy65
LostMy65's Avatar
Yes, I try not to start a new thread asking questions that can be answered with just a little searching.
Old 07-09-2011, 01:19 AM   #106
LostMy65
LostMy65's Avatar
Found me a beautiful straight clean box for $100
The catch is I had to unbolt it from the frd
He just wanted it gone. I was fine with that.
Now I won't have to try and restore my old beat-up box.
Old 07-09-2011, 01:35 AM   #107
KroAutomotiveInc
KroAutomotiveInc's Avatar
love the service box very cool!
KroAutomotiveInc is offline   Reply With Quote
Old 07-10-2011, 01:40 AM   #108
Captainfab
60-66 Nut
Wow, that looks good. If it is as nice as it looks in the pic, you stole that box.
Old 07-10-2011, 08:52 PM   #109
66-PMD-GMC
66-PMD-GMC's Avatar
OMG! You touched a Ford......
Did you get vaccinated afterward...
Seriously, you should see a Doctor and make sure you didn't catch anything..
Gotta go.. need to wash my hands after typing the F word...
Projects..
440CID 2X4 Pontiac
Old 07-15-2011, 01:25 AM   #110
LostMy65
LostMy65's Avatar
These guys took my 79 donor away.
I wish I would of got a pic as they still had it hanging from their claws way up in the air.
Old 07-15-2011, 03:45 AM   #111
pdxhall
pdxhall's Avatar
I get that same soreness and tire easily when working on my 66. Since that makes 2 of us it must be the 66 trucks. LOL
pdxhall is offline   Reply With Quote
Old 07-16-2011, 01:08 AM   #112
LostMy65
LostMy65's Avatar
Yea, there isn't any other reasonable explanation.
Old 07-16-2011, 01:09 AM   #113
LostMy65
LostMy65's Avatar
Got the old box off today.
I cut each side off and will be keeping them for tool cabinets.
Old 07-16-2011, 01:13 AM   #114
LostMy65
LostMy65's Avatar
I always like how these trucks look even without a bed.
That isn't rust on the back of the cab, that's the original county orange.
Old 07-19-2011, 03:06 PM   #115
LostMy65
LostMy65's Avatar
My Cab Corners arrived today from Dan's here in Portland.
They sent me two different brands.
TriPlus for the Driver's side and I don't know for the Passenger's.
I will be exchanging the passanger's side for a Tri-Plus brand.
The off brand is just way too cheaply made. The metal is terribly obviously thinner.
The shape of the body lines are very under shaped.
The TriPlus is far superior.
Old 07-19-2011, 03:40 PM   #116
LostMy65
LostMy65's Avatar
Pressure washed the frame rear section.
I'll be doing the rear gas tank upgrade and cab corners while I have the box off.
Old 07-19-2011, 04:06 PM   #117
pdxhall
pdxhall's Avatar
What kind of tank are you planning to use? Just wondering because I'm at about that stage on my 66. The plan right now is to use a 64-66 mustank tank. I've seen a couple used in our trucks and they are almost a drop in and very little hangs below the frame. They are only 16 gal., though, and also the sender needs to be modified to 0-90 ohms.
Old 07-19-2011, 04:36 PM   #118
LostMy65
LostMy65's Avatar
I have two tanks to choose from.
My first choice will be a huge 79 suburban tank I got off my donor - similar to the blazer:
http://67-72chevytrucks.com/vboard/s...d.php?t=474448
If I don't like how it's coming together, I got one off of the F250 that I got the service box off of. It's looks to be about half the depth of the suburban tank.
I'll try and load some pics of the tanks this afternoon.
Old 07-19-2011, 05:25 PM   #119
66-PMD-GMC
66-PMD-GMC's Avatar
I thought the 60's trucks used 30 ohm fuel gages??
I need a tank bad. I hate it in the cab.. makes me real fricking nervous!
Projects..
440CID 2X4 Pontiac
Old 07-19-2011, 09:54 PM   #120
LostMy65
LostMy65's Avatar
Here's the Frd F250 gas tank.
I see now it won't fit between the rails.
If I have to go below the rails, I might as well use the huge suburban tank because it fits between the rails, so I'm guessing it won't hang any lower than the frd tank mounted below the rails.
79 Suburban tank:
Old 07-20-2011, 02:31 AM   #121
pdxhall
pdxhall's Avatar
66-PMD. you're right. my bad, it is 30 ohm.
Old 07-20-2011, 02:33 AM   #122
pdxhall
pdxhall's Avatar
66-PDM...you're right, my bad, it is 30 ohm.
Old 07-20-2011, 03:18 AM   #123
padresag
65=30ohms, 66=90 ohms is how i believe is how it goes
ron
padresag is offline   Reply With Quote
Old 07-22-2011, 12:28 PM   #124
LostMy65
LostMy65's Avatar
I found two clean doors. Driver's and
Passenger's.
$325 for both.
After driving around looking at rusty
bottom doors, I figured I had better get
both of these.
I'll get some pics up later.
I'm tempted to buy the hood also.
I posted in the parts forum asking what it might be worth.
Old 07-26-2011, 02:07 AM   #125
LostMy65
LostMy65's Avatar
Saved for future reference:
Originally Posted by SFTorange View Post
Thanks Guys! Having the cab back on the frame makes me feel like the end is in sight. For the interior colors, I gave the following codes to my paint shop, and they were able to match them. I'm out of town for the week, but I'll post the actual codes they used when I get home. The exterior color is the factory Saddle Poly code 22683. I think the colors look great, I couldn't be happier.
Medium Fawn: 60% gloss
DuPont: #9171-L
Ditzler: #DL-22571
Rinshed-Mason: #65B84
Dark Fawn: 0% Gloss
DuPont: #9202-L
Ditzler: #DIA 22568
